mike(at)vision499.com Guest
Posted: Tue Feb 02, 2016 5:04 am Post subject: Firewall |
I'm in the process of installing the stainless steel firewall, should I seal the edge and if yes what do I use?
Mike
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
wschertz343(at)gmail.com Guest
Posted: Tue Feb 02, 2016 5:18 am Post subject: Firewall |
Mike
I assume that you put the fiberfrax between the plywood and the SS sheet. One thing that I did that I am very happy with is to put a large metal washer at each point where something is attached to the firewall, with a cutout of the fiberfrax around the washer to prevent the compression and buckling of the SS sheet when the items are tightened down. A high temp (red) RTV could work to seal the edges.
Bill
Sent: Tuesday, February 02, 2016 6:03 AM
Subject: Firewall
Mike
aeromomentum(at)yahoo.com Guest
Posted: Tue Feb 02, 2016 5:32 am Post subject: Firewall |
Hi Mike,
Before you install the stainless steel you may also want to paint the firewall with intumescent paint. You can buy this type of fireproof paint on ebay and many places online. You may also want to paint the inside of your cowling with this paint.
You can use DAP Firestop silicone to seal any firewall penetrations and the edge of the stainless. You should be able to get this at Lowes or Homedepot. I assume you are using fiberfrax or similar behind the stainless.
Mark Kettering
On Tue, 2/2/16, mike <mike(at)vision499.com> wrote:
Subject: Firewall
To: kis-list(at)matronics.com
Date: Tuesday, February 2, 2016, 8:03 AM
#yiv2888674618
.yiv2888674618mceResizeHandle {position:absolute;border:1px
solid
black;background:#FFF;width:5px;height:5px;z-index:10000;}#yiv2888674618
.yiv2888674618mceResizeHandle:hover
{background:#000;}#yiv2888674618 img .filtered99999
{outline:1px solid black;}#yiv2888674618
img.yiv2888674618mceClonedResizable, #yiv2888674618
table.yiv2888674618mceClonedResizable
{position:absolute;outline:1px dashed black;z-index:10000;}
Hi All
use?
Mike
sstearns2(at)yahoo.com Guest
Posted: Tue Feb 02, 2016 9:21 am Post subject: Firewall |
I did exactly the same thing. Large area washers behind the big bolts and normal washers behind the small bots. I bonded the washers on with the fiberfrax adhesive and I have 4 ply pads on the front of the firewall in the engine mount attach areas.
If I did it again I would make very large washers, maybe 2" in diameter, to use under the engine mount attach bolts.
I used red RTV around the edge of the firewall.
I also plan to coat the inside of my cowl with this...
http://www.homedepot.com/p/ForceField-FireGuard-E-84-5-gal-Intumescent-Primer-FFGD-E84-g05/203582028?cm_mmc=shopping-_-googleads-_-pla-_-203582028&ci_sku=203582028&ci_gpa=pla&ci_src=17588969&gclid=CKmZ5srE2coCFUOVfgod4nkGtQ&gclsrc=aw.ds
It is a primer coat, but it expands when exposed to flame to form a thick insulation. There are some very impressive videos on you tube. I would also put a couple coats on the firewall and maybe on the underside of the forward fuselage where the cooling air comes out.
Scott
Subject: Firewall
Mike
#yiv9330359423 .yiv9330359423mceResizeHandle {position:absolute;border:1px solid black;background:#FFF;width:5px;height:5px;z-index:10000;}#yiv9330359423 .yiv9330359423mceResizeHandle:hover {background:#000;}#yiv9330359423 img .filtered99999 {outline:1px solid black;}#yiv9330359423 img.yiv9330359423mceClonedResizable, #yiv9330359423 table.yiv9330359423mceClonedResizable {position:absolute;outline:1px dashed black;z-index:10000;}
