yaknorway52(at)gmail.com Guest
Posted: Sun Mar 06, 2016 1:15 am Post subject: Champion spark plug |
Anyone have experience's with champion spark plug RVL 38S on the M-14p?
Ps: Auto ignition kit is not in the question, or an option for saving cash. Have a KIT for sale if anyone would like that.
Br
Havard
Yak Norway
http://m.aircraftspruce.com/catalog/eppages/champsprkplugs20.php
Sendt fra min iPhone
Quote: | Den 6. mar. 2016 kl. 09.03 skrev Yak-List Digest Server <yak-list(at)matronics.com>:
Today's complete Yak-List Digest can also be found in either of the
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-03-05&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-03-05&Archive=Yak
Yak-List Digest Archive
Total Messages Posted Sat 03/05/16: 1
Today's Message Index:
1. 01:21 PM - Re: I'm Looking for an M14P (danbooker)
________________________________ Message 1 _____________________________________
Time: 01:21:53 PM PST US
Subject: Re: I'm Looking for an M14P
You still looking for an engine? Getting ready to swap mine. It's running great,
but I got a factory new one in a crate I want to install before it gets old
and corrodes!
Daniel Booker
"Stealth-Eagle Aviation"
2312457798
danbooker(at)hotmail.com
http://forums.matronics.com/viewtopic.php?p=453442#453442
richard.goode(at)russiana Guest
Posted: Sun Mar 06, 2016 2:49 am Post subject: Champion spark plug |
Hello Havard,
I'm curious as to why you seem to be unhappy with the automotive plug
conversion kit. I suspect there are over 300 (Dennis – you probably have an
accurate figure) in use around the world, and I've never heard of anyone,
until you, who is not absolutely delighted with them. My personal view is
that they are the best thing you can do for these engines for the money!
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
Posted: Sun Mar 06, 2016 5:11 am Post subject: Champion spark plug |
Other than the fact that it will cost you about $1900.00 for one set of 18 plugs, ($112.75 each), I have no other knowledge about these plugs.
The issue with the ignition system on the M14 is the wiring harness. Not the spark plugs. Replacing the wiring harness with the automotive conversion kit eliminates the "Achilles heal" of the M14 AND by default let's us use a less than $4 spark plug.
There are over 650 automotive conversion kits shipped world wide.
Dennis
Quote: | On Mar 6, 2016, at 5:48 AM, Richard Goode <richard.goode(at)russianaeros.com> wrote:
RVL 38S
Posted: Sun Mar 06, 2016 6:03 am Post subject: Champion spark plug |
Hi Richard,
I had mounted the auto kit and experienced more radio noise, more and faster arching on distributor caps, breaker points. Checked the cables and the resistence on the cable i got is higher than original wire type cable, with the result in arching and noise. Maybe if used wire type auto cables its better.
Have now got the original harness rewired with wire style cables by M-14P. Mounted new caps and breaker points. Have flown great last 50 flight hrs. Last weekend flying 8 tours. Last tour ended with the classic coil problem. Got missfire After airbourne. Did check all the plugs(now original) with pressure tester. Found 4 to be not good, replaced them with new and made a test flight but same issue when airbourne. Know i had to take mag check airbourne to get it to missfire. When runnend on both it was pretty nice, but not perfect so did take the mag check and pointed on no2 it missfire like hell😄
Br
Havard
Sendt fra min iPad
[quote] Den 6. mar. 2016 kl. 11.48 skrev Richard Goode <richard.goode(at)russianaeros.com>:
Hello Havard,
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Hi Dennis,
I had mounted the auto kit and experienced more radio noise, more and faster arching on distributor caps, breaker points. Checked the cables and the resistence on the cable i got is higher than original wire type cable, with the result in arching and noise(I Think). Maybe if used wire type auto cables its better.
Have now got the original harness rewired with wire style cables by M-14P. Mounted new caps and breaker points. Have flown perfect last 50 flight hrs. Last weekend flying 8 tours. Last tour ended with the classic coil problem. Got missfire After airbourne. Did check all the plugs(now original) with pressure tester. Found 4 to be not good, replaced them with new and made a test flight but same issue when airbourne. Know i had to take mag check airbourne to get it to missfire. When runnend on both it was pretty nice, but not perfect so did take the mag check and pointed on No 2 it missfire like hell.
Br
Havard
Sendt fra min iPad
Quote: | Den 6. mar. 2016 kl. 14.10 skrev A. Dennis Savarese <dsavarese0812(at)bellsouth.net>:
Dennis
> RVL 38S
Posted: Sun Mar 06, 2016 2:25 pm Post subject: Champion spark plug |
What brand and model radio do you have?
Dennis
To: yak-list(at)matronics.com
Sent: Sunday, March 6, 2016 8:50 AM
Subject: Re: Yak-List: Champion spark plug
--> Yak-List message posted by: =?utf-8?Q?H=C3=A5vard_Dale?= <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)>
Hi Richard,
Br
Havard
Sendt fra min iPad
[quote] Den 6. mar. 2016 kl. 11.48 skrev Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>:
--> Yak-List message posted by: "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
Hello Havard,
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Posted: Sun Mar 06, 2016 8:11 pm Post subject: Champion spark plug |
Hi,
Becker AR 4201 radio
Med Vennlig Hilsen
Yak Norway
www.yaknorway.no
Mobil: +47 952 50 103
Org No:916588054
2016-03-06 23:24 GMT+01:00 A. Dennis Savarese <dsavarese0812(at)bellsouth.net>:
[quote] What brand and model radio do you have?
Dennis
*To:* yak-list(at)matronics.com
*Sent:* Sunday, March 6, 2016 8:50 AM
*Subject:* Re: Champion spark plug
yaknorway52(at)gmail.com>
Hi Richard,
its better.
Viperdoc
Posted: Sun Mar 06, 2016 8:23 pm Post subject: Champion spark plug |
I have the same radio and have interference problems also. That radio is poorly shielded as I understand. Was designed for gliders.
Or so I have been told.
Doc
On Mar 6, 2016, at 10:05 PM, HÃ¥vard Dale <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)> wrote:
[quote]Hi,
Med Vennlig Hilsen
Yak Norway
www.yaknorway.no
Org No:916588054
2016-03-06 23:24 GMT+01:00 A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>:
[quote]What brand and model radio do you have?
Dennis
From: HÃ¥vard Dale <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)>
Subject: Re: Champion spark plug
Hi Richard,
Br
Havard
Sendt fra min iPad
Hello Havard,
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: [url=tel:%2B44%20%280%29%201544%20340120]+44 (0) 1544 340120[/url]
Fax: [url=tel:%2B44%20%280%29%201544%20340129]+44 (0) 1544 340129[/url]
_________________ Viperdoc |
Looigi
Joined: 20 Apr 2015 Posts: 81 Location: Christchurch, New Zealand
Posted: Sun Mar 06, 2016 9:37 pm Post subject: Re: Champion spark plug |
A friend of mine is also having interference issues since he fitted an automotive ignition plug conversion. His Yak 52 doesn't have a radio, but the noise is over the standard Russian intercom.
He has changed the magnetos with a known good one but still no better.
Has anyone found a solution to this issue? He doesn't want to go back to the old leads and I am going to be fitting a kit to mine once the Russian leads die.
Cheers
Chris
Posted: Sun Mar 06, 2016 10:06 pm Post subject: Champion spark plug |
Hi,
Yes some told me that also, but checked some and Found the radio commonly used in noisy Aircraft.
Radio noise also on my friends Yak 52W with Icom 210A and NAT intercom. Also modified with auto ignition.
Anyhow, for me the auto kit is no more present in my Yak and the question here is og someone had experience's with the champion spark plugs.
Also if some have a new KIT with the original plugs i Could be intrested in buying that:-)
Br
Havard
Den 7. mar. 2016 kl. 05.21 skrev Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>:
[quote]I have the same radio and have interference problems also. That radio is poorly shielded as I understand. Was designed for gliders.
Doc
[quote]Hi,
Med Vennlig Hilsen
Yak Norway
www.yaknorway.no
Org No:916588054
Dennis
Hi Richard,
Br
Havard
Sendt fra min iPad
Hello Havard,
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Posted: Sun Mar 06, 2016 10:15 pm Post subject: Champion spark plug |
A suggestion from me is to re-wire original system with new wire style cables. Its a Good reason why original system is completly shielded.
Br
Havard
Quote: | Den 7. mar. 2016 kl. 06.37 skrev Looigi <cdoburton(at)gmail.com>:
Cheers
Chris
http://forums.matronics.com/viewtopic.php?p=453488#453488
jan.mevis(at)informavia.b Guest
Posted: Sun Mar 06, 2016 10:58 pm Post subject: Champion spark plug |
The original Russian cables are 5mm thick. The modern ignition cables are
thicker, so you can¹t pull them thru the wiring harness.
Otherwise I would have kept it.
The modern plug cables also pass higher frequency components to the plug.
Therefore, more energy goes to the plug and you get a hotter spark.
As for the radio noise: a careful installation of a good radio could fix
that.
In EASA country, every Yak owner will have to replace the old Baklans or
other 25 kHz separated radio¹s with a modern 8.33 kHz separated model soon
(2017, I think).
I personally am very satisfied with Dennis¹ plug wiring solution. I have
done several installations of it but also often changed the Russian
radio¹s.
Years ago, I had a Russian Ziabrik radio on my 50. This was a terribly bad
radio, still 50 kHz separated.
So I changed it for a Briz (or something like that). Only a slight
improvement.
Then I installed a Becker 4201 on my noisy Yak 50 and it worked
flawlessly. But I also changed the whole radio wiring, inclusive
PTT-cables, antenna and antenna cables etc.
Today I have a 8.33 kHz Filser Funkwerk ATR833.
Still the 8mm spiro-wound plug wires + NGK plugs AND an electronic
ignition in place of the right mag (Mark Bitterlich¹s design).
Very hot sparks, 120 kiloJoules, and more than one spark each time
(capacitive discharge, multiple spark system).
Radio works perfectly, engine sparks perfectly too and has consistently
higher CHT¹s since the electronic ignition.
(at)Dennis: I installed colder NGK¹s, the BR7HS instead, => gives me more
equal CHT temperatures on my M14R 450 PS.
Jan
Yak 50 F-AZUK
On 07/03/16 07:15, "Håvard Dale" <owner-yak-list-server(at)matronics.com on
behalf of yaknorway52(at)gmail.com> wrote:
Quote: |
<yaknorway52(at)gmail.com>
Br
Havard
>Russian leads die.
> Cheers
> Chris
pa3arw(at)ziggo.nl Guest
Posted: Mon Mar 07, 2016 4:50 am Post subject: Champion spark plug |
Chris and all,
I am using the automotive kit already for the last 6 years or so on my Yak52
and have no problems with it.
The radio I have been using until last year was a Becker 4201. Since august
last year I have a new radio because of the necessity for us in Europe to
change to 8.33 channel separation. This new radio is a Becker 6201. Pin
compatible(almost) with the 4201. Intercom is a PS Engineering PM1000.
Measurements I have done showed that the noise generated by the automotive
ignition kit is less than the original one. I have no noise whatsoever on my
radio and/or intercom.
You are talking about interference. With all do respect it has nothing to do
with interference but solely with the proper installation of the intercom
and the radio. From a electrical noise point of view the Yak by definition
is a terrible environment. DC generator, mechanical DC regulator, tacho
generator etc. In general noise enters a radio through the antenna.
When the noise enters the radio through the power supply it can be solved
easily by means of a filter which is readily available from Spruce. In your
case whereby you have noise on the intercom it can be solved satisfactory by
means of the use of a power filter on intercom's power input.
So what can be do more?
It all has to do with proper installation of the intercom and the radio.
Nowadays the modern radio's we use have digital IF and are less sensitive
for noise. They are well designed and the majority have DSP noise
suppression.
In order to find out whether noise is coming in the radio through the
antenna the best thing to do is to unscrew the antenna from the radio and
short circuit the connector(mostly a BNC). DO NOT PUSH THE PTT AT THIS POINT
BECAUSE YOU WILL PROBABLY BLOW UP THE FINAL AMPLIFIER OF THE TRANSMITTER.
If the noise is still there it will for almost certainly come into the radio
through the power supply. In that case install a powersupply noise
suppressor filter and a capacitor on the "plus" coming from the generator.
If the noise comes into the radio through the antenna there is really not a
lot you can do but in all cases my recommendation would be to install noise
suppressor filters on both magnets as well, i.e. on the leads which go to
the mag switch. These wires radiate a lot of noise and this radiated noise
can easily be suppressed by a capacitor. Normally these wires should be
shielded but in due time the shielding may have come loose from earth or are
terribly damaged.
Also make sure the radio is installed properly, that means, use the right
shielded cable. Do not connect ground to the shielding on both sides but
ONLY connect the shielding on the radioside. Ensure a good earth.
The problem with noise coming through the antenna is that noise is AM
modulated, which is the same type of modulation of the signals we generate
and receive with our radio. In other words our VHF radio is well equipped to
receive this type of noise. The design of the radio is there for also
important. Poorly designed radio's are much more susceptible to noise than
properly designed ones.
In our Yak environment I would go for the bigger names like Becker,
Funkwerk, Garmin, King etc. In this case it is fair to say:the cheaper the
radio the more chances you have for noise problems.
Hope this helps you a little bit.
Hans O.
PH-YAK
die.
Cheers
Chris
Posted: Mon Mar 07, 2016 4:53 am Post subject: Champion spark plug |
Two possible fixes which has been used in the past is; first, make absolutely certain the shielding on the P lead is in fact soldered properly to the P lead button, all the way around. Second, you can try installing the following filter on each P lead.
http://www.aircraftspruce.com/catalog/elpages/lsMagFilter.php
Using the filter's mounting tab, you can mount the filter behind one of the nuts on the accessory case rear, circular plate. Essentially, there will be one filter at about the 10 o'clock position and one at the 2 o'clock position on the rear plate. The filter is installed in series to the P lead. Be sure to solder the shield again to the P lead button.
Dennis
Sent: Monday, March 7, 2016 12:37 AM
--> Yak-List message posted by: "Looigi" <cdoburton(at)gmail.com (cdoburton(at)gmail.com)>
Cheers
Chris
< --> http://www.matronics.com/Navigator?p; --> http:========================http://www.ma======================
Posted: Mon Mar 07, 2016 5:29 am Post subject: Champion spark plug |
Excellent point about proper installation, also as Hans and Craig have pointed out.
Dennis
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Sent: Monday, March 7, 2016 1:57 AM
Subject: Re: Re: Champion spark plug
--> Yak-List message posted by: Jan Mevis <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)>
that.
(2017, I think).
radio¹s.
improvement.
Jan
Yak 50 F-AZUK
On 07/03/16 07:15, "HÃ¥vard Dale" <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) on
behalf of yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)> wrote:
Quote: | --> Yak-List message posted by: =?utf-8?Q?H=C3=A5vard_Dale?=
Br
Havard
> Den 7. mar. 2016 kl. 06.37 skrev Looigi <cdoburton(at)gmail.com (cdoburton(at)gmail.com)>:
>Russian leads die.
> Cheers
> Chris
ontribution" target="_blank">http://www.matronics.com/contributionhttp://www.= --> <a href="http://www.matronics.com/contribution" target=====
