art(at)zemon.name Guest
Posted: Mon Mar 07, 2016 5:41 am Post subject: Wire Raceway |
Charley,
That looks like really good stuff. Thank you! You have my imagination bubbling about places to use each of those products.
-- Art Z.
On Sun, Mar 6, 2016 at 9:31 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | For wire raceway, I found this stuff:
https://www.techflex.com/prod_ccp.asp
and
https://www.techflex.com/prod_f6w.asp
As long as you leave a bit of extra length, the 1st can expand substantially for future wire additions.
The 2nd allows wire to be added without being pulled through the tube, and allows wire to exit at any point along the run without cutting open the tube.
Very flexible, can turn sharp corners, weighs next to nothing, very thin 'wall', and good abrasion resistance. I used the split stuff to run down the sides of my RV-7 from behind the instrument panel to the fuel line/cable chase at the main spar. The unsplit stuff I've used to bundle runs from subD connectors behind the panel. The 3/4" diameter version will expand enough to go over a populated subD, if the shell is removed & the wires bent 90 degrees.
FWIW...
Charlie
http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
