Herbgh(at)nctc.com Guest
Posted: Fri Apr 22, 2016 5:42 pm Post subject: 10 gal tank... |
anyone have a notion where a 10 gal poly tank can be bought? I will
check with Bryan on Monday if need be..Herb
rickofudall
Posted: Sat Apr 23, 2016 11:34 am Post subject: 10 gal tank... |
Herb, Take a look at the tank used in the Challengers. I don't remember the size off  hand but I do know it's bigger than the 5 gallon used by Kolb.
Rick Girard
On Fri, Apr 22, 2016 at 8:37 PM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
| Quote: | --> Kolb-List message posted by: Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)>
anyone have a notion where a 10 gal poly tank can be bought? I will check with Bryan on Monday if need be..Herb
FORUMS -
WIKI -
b Site -
     -Matt Dralle, List Admin.
“Blessed are the cracked, for they shall let in the light.�   Groucho Marx
pcarillonsr(at)neo.rr.com Guest
Posted: Sat Apr 23, 2016 5:52 pm Post subject: 10 gal tank... |
On 4/22/2016 9:37 PM, Herb wrote:
You might try Summit Racing near Akron Ohio lots of tanks.
Summitracing.com Then type in fuel cells. Many different ways
to search for the tank your looking for on the site.
Jack Carillon FSII Akron Oh.
Posted: Sun Apr 24, 2016 5:32 am Post subject: 10 gal tank... |
Jack
The tank I need is just a larger version of the 5 gal tank that Kolb
uses...
I think Bryan at the factory will have them or know where to get same...
Herb
On 04/23/2016 08:51 PM, Jack wrote:
Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left.
Posted: Sun Apr 24, 2016 5:35 am Post subject: 10 gal tank... |
gonna fit it in a Firefly ! Â Â Â gotta be quite the same material and very lite....Herb
On 04/23/2016 02:33 PM, Richard Girard wrote:
| Quote: | Herb, Take a look at the tank used in the Challengers. I don't remember the size off  hand but I do know it's bigger than the 5 gallon used by Kolb.
Rick Girard
undoctor(at)rcn.com Guest
Posted: Sun Apr 24, 2016 7:06 am Post subject: 10 gal tank... |
The 10 gallon tank for a Challenger is what Don G. built the space for in the FlagFly. It fit beautifully behind the seat
Dave Kulp
Sent from my Verizon Wireless 4G LTE smartphone
Date:04/24/2016 9:31 AM (GMT-05:00)
Subject: Re: Kolb-List: 10 gal tank...
--> Kolb-List message posted by: Herb <Herbgh(at)nctc.com>
Jack
uses...
Herb
| Quote: | --> Kolb-List message posted by: Jack <pcarillonsr(at)neo.rr.com>
_-============================================================
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
Posted: Sun Apr 24, 2016 7:28 am Post subject: 10 gal tank... |
I went to their site...Quad Cities...but found no listing for parts....I will call them tomorrow...thanks..Herb
On 04/24/2016 10:06 AM, undoctor wrote:
| Quote: | The 10 gallon tank for a Challenger is what Don G. built the space for in the FlagFly. It fit beautifully behind the seat Â
Dave Kulp
Subject: Re: 10 gal tank...
--> Kolb-List message posted by: Herb <Herbgh(at)nctc.com> (Herbgh(at)nctc.com)
Jack
uses...
  Herb
> --> Kolb-List message posted by: Jack <pcarillonsr(at)neo.rr.com> (pcarillonsr(at)neo.rr.com)
>Â Â Â Jack Carillon FSII Akron Oh.
neilsenrm(at)gmail.com Guest
Posted: Sun Apr 24, 2016 8:45 am Post subject: 10 gal tank... |
Herb
I got two 6 gallon tanks from Travis at Kolb a few years ago they are the same as the 5 gallon tanks just taller. At one point the 6 gallon tanks were a bit thinner but the ones I have are the same as the 5 gallon tanks. They are more likely to fit without any modification.
Rick Neilsen
Redrive VW Powered MKIIICÂ
On Sun, Apr 24, 2016 at 9:31 AM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Jack
 The tank I need is just a larger version of the 5 gal tank that Kolb uses...
 Herb
| Quote: | --> Kolb-List message posted by: Jack <pcarillonsr(at)neo.rr.com (pcarillonsr(at)neo.rr.com)>
   Summitracing.com  Then type in fuel cells. Many different ways to search for the tank your looking for on the site.
FORUMS -
WIKI -
b Site -
Posted: Sun Apr 24, 2016 8:55 am Post subject: 10 gal tank... |
The tank in Dave's Flag Fly is the one I need...Herb
On 04/24/2016 11:45 AM, Rick Neilsen wrote:
| Quote: | Herb
Rick Neilsen
| Quote: | --> Kolb-List message posted by: Herb <[url=mailto:Herbgh(at)nctc.com]Herbgh(at)nctc.com (Herbgh(at)nctc.com)[/url]>
Jack
 Herb
| Quote: | --> Kolb-List message posted by: Jack <[url=mailto:pcarillonsr(at)neo.rr.com]pcarillonsr(at)neo.rr.com (pcarillonsr(at)neo.rr.com)[/url]>
FORUMS -
WIKI -
b Site -
mojaveclimber
Posted: Sun Jul 24, 2016 1:12 am Post subject: Re: 10 gal tank... |
Air-Tech sells a 10 gallon tank, one can replace the 5 gallon tanks with the
larger tanks. I'm very happy with the retrofit I did on my Mk 3
