Switch quality
Laz
PostPosted: Sat Apr 23, 2016 4:59 am    Post subject: Switch quality Reply with quote
I am building a RV8 and Have a couple of Carling but  switches SPST.  I am not impressed with their fast on tabs.  I know they will probably work just fine, but I am thinking of using some Honeywell switches that have screw on terminals.  I also have a space issue that the screw on terminals would help.
Are these Honeywell switches a good choice?
billhuntersemail(at)gmail
PostPosted: Sat Apr 23, 2016 5:49 am    Post subject: Switch quality Reply with quote
What Honeywell switches?
Bill Hunter
On Apr 23, 2016 8:06 AM, "Michael Lazarowicz" <tllaz330(at)gmail.com (tllaz330(at)gmail.com)> wrote:
jan(at)CLAVER.DEMON.CO.UK
PostPosted: Sat Apr 23, 2016 6:13 am    Post subject: Switch quality Reply with quote
If you are talking about this lot … I would say they are good …
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Hunter
Sent: 23 April 2016 14:48
Subject: Re: AeroElectric-List: Switch quality
Bill Hunter
Honeywell_AML_and_MML_switches.pdf
 Filename:  Honeywell_AML_and_MML_switches.pdf
 Filesize:  191.12 KB
 Downloaded:  499 Time(s)
Laz
PostPosted: Sat Apr 23, 2016 6:15 am    Post subject: Switch quality Reply with quote
It is a NT 1-2,  It has the plastic back with screw terminals.
Hope that helps
On Saturday, April 23, 2016, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Bill Hunter
ceengland7(at)gmail.com
PostPosted: Sat Apr 23, 2016 6:24 am    Post subject: Switch quality Reply with quote
Those are terrible and will cause the wings to fall off. To be safe, box
them up and send them to me.
Wink
Seriously, screw terminals are more likely to come loose than the fast
on tabs, because any counter-clockwise pressure on the ring terminal
(tension on the wire) will try to loosen the screw. And proper ring
terminals take the same space as fast on terminals. If you're thinking
of just hooking the wire under the screw head, don't go there. Five
years from now, when you're making changes to the panel wiring, you'll
be cussing yourself as you lie on your back under the panel with your
legs in the air, trying to find the screw you dropped into the bowels of
the a/c.
Now if you want the Honeywells for the looks, or you believe you need
space-certified internal quality, then go for it.
Laz
PostPosted: Sat Apr 23, 2016 9:26 am    Post subject: Switch quality Reply with quote
No its a clearance problem.  The tabs on the Carling switches I have go straight out the back.  When you add the female  connector it adds almost an Inch.  I just need the room and the NT Honeywell switch is just a couple ob bucks more than the Carling ones. There are also two versions of the Honeywell , One has silver contacts the NT does not.  That could really be overkill.
On Sat, Apr 23, 2016 at 10:26 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
Those are terrible and will cause the wings to fall off. To be safe, box them up and send them to me.
Wink
Seriously, screw terminals are more likely to come loose than the fast on tabs, because any counter-clockwise pressure on the ring terminal (tension on the wire) will try to loosen the screw. And proper ring terminals take the same space as fast on terminals. If you're thinking of just hooking the wire under the screw head, don't go there. Five years from now, when you're making changes to the panel wiring, you'll be cussing yourself as you lie on your back under the panel with your legs in the air, trying to find the screw you dropped into the bowels of the a/c.
Now if you want the Honeywells for the looks, or you believe you need space-certified internal quality, then go for it.
ngeorge(at)continentalmot
PostPosted: Sat Apr 23, 2016 10:30 am    Post subject: Switch quality Reply with quote
Mike -
We're sorta partial to fast-ons around here...
Neal George
rv10pro(at)gmail.com
PostPosted: Sat Apr 23, 2016 10:46 am    Post subject: Switch quality Reply with quote
Just a contrarian view on Wings falling off, I work for an airline with 52 aircraft and each with 104 c/b's with washers and screws.  No wins have ever even gotten loose nor do the machine screws when correctly installed and torqued. Space limitations and wire loom routing would never work with Fast-ons. YMMV.
John Cox On Apr 23, 2016 07:30, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Wink
stephencliverichards(at)g
PostPosted: Sat Apr 23, 2016 10:50 am    Post subject: Switch quality Reply with quote
I believe you can get right angle fastons if this would help I have not used them myself
Clive
Sent: ‎23/‎04/‎2016 18:32
Wink
donjohnston
PostPosted: Sat Apr 23, 2016 1:37 pm    Post subject: Re: Switch quality Reply with quote
ceengland7(at)gmail.com wrote:
On 4/23/2016 7:54 AM, Michael Lazarowicz wrote:Seriously, screw terminals are more likely to come loose than the fast
on tabs,
Then I better replace my wing bolts, landing gear bolts, elevator bolts, cylinder bolts etc., etc., etc.
Because they are all attached with threaded connectors.
rnjcurtis(at)charter.net
PostPosted: Sat Apr 23, 2016 3:03 pm    Post subject: Switch quality Reply with quote
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
on tabs,
“APPLES & ORANGES, SIR”
Roger
PostPosted: Sat Apr 23, 2016 3:11 pm    Post subject: Re: Switch quality Reply with quote
Search for Flag Faston Connectors.
http://www.te.com/usa-en/product-1-280050-2.html
Gold plated switch contacts are for lighter loads.
Silver plated switch contacts are for heavier loads.
Joe Gores
PostPosted: Sat Apr 23, 2016 7:57 pm    Post subject: Switch quality Reply with quote
> on tabs,
And all the bolts that attach parts that are subject to rotation have
castle nuts and cotter keys, right?
My original post was intended to be a bit light hearted, but it's not a
falsehood. Yes, if everything is done properly, screw terminals will be
secure. But try half installing a blade terminal on its blade, and half
tightening a screw on a ring terminal. Then see which is more prone to
loosening when the wires are wiggled. I know none of us who are perfect
pilots and perfect a/c assemblers would ever make such a mistake, but
'stuff happens'.
The real point is that quality blade connectors are plenty good enough
for aviation use.
Laz
PostPosted: Sun Apr 24, 2016 4:53 am    Post subject: Switch quality Reply with quote
Tanks to everyone fore tier input,  I did not mean to start a debate over screw verses fast on tabs.  My real issue was with the Manufacturer quality of the switches.  I have a couple of Carling's and eve  though they make screw on terminals the Honeywell just appeared to be better made.  IN the bis=g scheme of things, the cost of the 7 switches are just a tiny drop compared to what  Garmin has removed from my bank account.  This is my first shot at this kind of wiring.  My 1946 T-craft has no electrical and the Old A7 mag switch is a study in bad design all by its self.
On Sat, Apr 23, 2016 at 11:57 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
on tabs,
And all the bolts that attach parts that are subject to rotation have castle nuts and cotter keys, right?
My original post was intended to be a bit light hearted, but it's not a falsehood. Yes, if everything is done properly, screw terminals will be secure. But try half installing a blade terminal on its blade, and half tightening a screw on a ring terminal. Then see which is more prone to loosening when the wires are wiggled. I know none of us who are perfect pilots and perfect a/c assemblers would ever make such a mistake, but 'stuff happens'.
The real point is that quality blade connectors are plenty good enough for aviation use.
Laz
PostPosted: Sun Apr 24, 2016 7:32 am    Post subject: Switch quality Reply with quote
My fat thumb on small phone .  not Tanks but thanks.
On Sunday, April 24, 2016, Michael Lazarowicz <tllaz330(at)gmail.com (tllaz330(at)gmail.com)> wrote:
On Sat, Apr 23, 2016 at 11:57 PM, Charlie England <[url=javascript:_e(%7B%7D,'cvml','ceengland7(at)gmail.com');]ceengland7(at)gmail.com[/url]> wrote:
--> AeroElectric-List message posted by: Charlie England <[url=javascript:_e(%7B%7D,'cvml','ceengland7(at)gmail.com');]ceengland7(at)gmail.com[/url]>
--> AeroElectric-List message posted by: "donjohnston" <[url=javascript:_e(%7B%7D,'cvml','don(at)velocity-xl.com');]don(at)velocity-xl.com[/url]>
on tabs,
PostPosted: Sun Apr 24, 2016 11:33 am    Post subject: Switch quality Reply with quote
At 10:31 AM 4/24/2016, you wrote:
My fat thumb on small phone . Â not Tanks but thanks.
There isn't really a 'debate' . . . it's a 'choice' for
achieving design goals. Different goals call for different
choices. My observations and experience with fast-ons
in general aviation dates back to Cessna's incorporation
of the Carling Rockers in the 60's.
They proved to be an acceptable solution to Cessna's
design goals for a satisfactory yet inexpensive alternative
to the legacy screw-terminal devices which greatly
improved manufacturing labor costs.
I began promoting the fast-on switches and fuse-blocks into
OBAM aviation about 1990 . . . it took hold and I don't
think anyone has looked back. The really cool thing about
a fast-on switch is that you can replace it literally
by feel alone. No itty-bitty short screw with lock washer
and screwdriver slot to thread through a ring terminal
that just won't hold still.
Without a doubt, the Honeywell products are fine
switches that have a history dating back much
further than the transition to fast-ons in the
single engine market. In terms of MTBF,
the Honeywells may well have a greater laboratory
service life that the Carling . . . but when the
average light aircraft switch gets operated perhaps
200 times a year, is your money well spent to get
a switch 'rated' for 30,000 cycles as opposed to
20,000 cycles?
Further, if your design is failure tolerant, then
the switch replacement is a cost-of-ownership as
opposed to a risk issue . . . on that train of
thought, the Carlings with fast-ons are way out front.
