docclv(at)windstream.net Guest
Posted: Wed Jun 15, 2016 5:45 pm Post subject: Attaching RV10 wings |
Do not attach the wings with the plane sitting on its landing gear. Make
sure the fuselage is level in all aspects (Follow the instructions) or
you will not have it rigged right and the plane will not fly level and
straight with hands off the stick. Doc #41087 N123CV
jdriggs49(at)MSN.COM Guest
Posted: Wed Jun 15, 2016 6:08 pm Post subject: Attaching RV10 wings |
Since you are installing wings on a RV-10 there is nothing to it. The wings only go on one way. I had two people help me, tho you can do it with just one strong helper. Get some bolts just a bit smaller than the ones holding the wings on. Grind the tips down to facilitate sliding them in temporarily. I believe the plans tell you how to do this. I had no problem doing one wing at a time as the wheel stance is quite wide. The attachment is so precise that there isn't anything to line up or jig up. Bolt them on and they are perfectly aligned. The plans have you do so WITH the gear on and leveling is not a problem as they only go on one way. This is not true of some of the other RV models.
Follow the directions!
Quote: | On Jun 15, 2016, at 8:49 PM, Doc <docclv(at)windstream.net> wrote:
Do not attach the wings with the plane sitting on its landing gear. Make sure the fuselage is level in all aspects (Follow the instructions) or you will not have it rigged right and the plane will not fly level and straight with hands off the stick. Doc #41087 N123CV
dmaib@me.com
Posted: Wed Jun 15, 2016 6:29 pm Post subject: Re: Attaching RV10 wings |
jdriggs49(at)MSN.COM wrote: |
Follow the directions is the best advice you can get.
No problem putting the wings on with the airplane sitting on the gear on the RV-10. Follow the directions.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Kellym
Posted: Wed Jun 15, 2016 6:34 pm Post subject: Attaching RV10 wings |
Say What?As others have said, there is NO mention of leveling the
fuselage in Section 44, mounting the wings. The holes for all but the
rear spar and fuel tank bracket are precision pre-drilled, so you can't
screw up the alignment following the plans.
KCHD |
Deems Davis
Posted: Wed Jun 15, 2016 7:12 pm Post subject: Attaching RV10 wings |
On Wed, Jun 15, 2016 at 6:44 PM, Doc <docclv(at)windstream.net (docclv(at)windstream.net)> wrote:
Quote: | --> RV10-List message posted by: Doc <docclv(at)windstream.net (docclv(at)windstream.net)>
Posted: Wed Jun 15, 2016 7:50 pm Post subject: Attaching RV10 wings |
The RV-10 doesn't have to be rigged. It is pre drilled and doesn't need to be level in any aspect to install the wings.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
