n5pb(at)AOL.COM Guest
				 Posted: Thu Aug 18, 2016 3:56 pm    Post subject: Lightning-List Digest: 0 Msgs - 08/17/16 |
				I haven't heard from hardly anyone at all on the net here. I hope everyone is doing well.  It's hot and humid here in Brooksville, FL.  My "Jet " is flying well, except for a oil pressure issue.  It was reading low 27-28 in cruise flight.  Pete said to check all the connections especially those going to ground for any corrosion.  I did all that to no avail.  Then I ordered new pressure sender units. (2 actually)  when I installed them that read low, 24 at idle....normally it should be 34 or so.  I changed the oil and oil filter as well and reinstalled the old oil pressure sender.  The issue went away....strange.
   BTW, does any know if the new oil pressure senders need to be "Calibrated" and if so, how do you do it.
   I hope everyone who went to Air Venture had a good time.
   When's the next newsletter coming out.
   When's the Lightning home coming this year?
   Bear.
   N82PB
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
