graeme bird
Posted: Sat Oct 15, 2016 10:11 am Post subject: Whoops - loss of flap pin |
Interesting flight back from Sandown UK this afternoon. It seems I lost a flap pin somewhere (into the tube I think). On takeoff from a bumpy field had a sudden strong port wing down tendency. I assumed the flaps were different and wondered if the mono port wing leg had collapsed. But, I was in the air and when retracted seemed fairly normal. On arrival back at my base strip I tried a few things at altitude and a couple of simulated approaches. It seemed just about controllable if into wind. So I landed in a square field at the end of our narrow strip so it could skew around if required. Phew, all ok, the leg did collapse and it skewed slightly in the last few yards but no grass contact with the prop and no damage to the wing end. I assume that the pin wasn't well locked in and had ratcheted out on repeated use. The tube still controlled the flap but it could move about an extra few degrees and no longer could be extended enough to lock the leg down. Perhaps some big G movement might have flicked it. Keeping that pin lubricated better might be a good idea and some loctite on the threads.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
brian.davies(at)clara.co. Guest
Posted: Sun Oct 16, 2016 1:53 am Post subject: Whoops - loss of flap pin |
Hi Graeme,
I am glad that you got down safely. I assume you are referring to the pin
screwed into the root of the flap and that you have confirmed that it is
missing. Are you able to confirm that it came unscrewed rather than sheared
off? Although this all ended safely the failure of this pin is a pretty
serious event and it is worth sharing the details so please let Malcolm
McBride or Andy Draper of the LAA know the results of your investigation.
Best regards
Brian Davies
spcialeffects
Posted: Sun Oct 16, 2016 2:41 am Post subject: Re: Whoops - loss of flap pin |
Hi Graeme, these pins at time of fitting should have been loctited into place. I think you bought the kit part built didn't you? did you build the flaps?
Regards Frank Kit 165
Posted: Sun Oct 16, 2016 7:12 am Post subject: Whoops - loss of flap pin |
Message from Pete Jeffers:
Brian I have difficulty sending to the forum when in the US so request you
read and forward this to the forum when you receive it.
Hi Brian and all,
As a Europa Inspector for the LAA for many years I do have to report that I
have found at least two other wing/flap screwed and locktited pins to be not
tight. ie I have managed to unscrew them with my fingers only. In the past I
have treated these instances as one offs but this event with G-UMPY
highlights the possible need for a mandatory or MPD to cover this issue. I
do highlight that I have found loose not only the flap drive pin but also
the main leading and trailing edge pins.
Pete Jeffers
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Sun Oct 16, 2016 7:31 am Post subject: Whoops - loss of flap pin |
If I recall the pins should be screwed in with neat redux (420 A&B) on the XS wings. May be this is an update in the manual from the classic build? The only way you could get the pins out on my aircraft is to heat the pins. But it is with raising this and need to be checked. If it is broken off more investigation is needed.
Richard Wheelwright
[quote] On 16 Oct 2016, at 16:12, Brian Davies <brian.davies(at)clara.co.uk> wrote:
Hi Brian and all,
Pete Jeffers
_________________ Richard Wheelwright
G-IRPW
First Flight 24th July 2013 |
fireflier
Posted: Sun Oct 16, 2016 7:34 am Post subject: Whoops - loss of flap pin |
Hi All
I notice that people are making reference to loctiting the wing pin/flap pins into place. My understanding and reference to the manual chapter 26 page 3 these pins have to be secured using a small quantity of araldite 420 on the pin threads and also the threads in the hole.
This is something that should become a regular maintenance check item, as the consequence of loosing these pins could have resulted in a completely different outcome.
Kind regards
Donald
G-PUPY
Hi Brian and all,
Pete Jeffers
_________________ Fireflier |
dg.watts(at)talktalk.net Guest
Posted: Sun Oct 16, 2016 7:45 am Post subject: Whoops - loss of flap pin |
Hi All,
Personally I put reasonable force into testing these all pins at each annual, as their inspection is called for in the Europa Annual Checklist and I also do likewise at each 50 hour service/inspection.
Dave Watts
G-BXDY Classic Monowheel 2,300 hours
Hi Brian and all,
Pete Jeffers
graeme bird
Posted: Sun Oct 16, 2016 11:28 am Post subject: Re: Whoops - loss of flap pin |
it didn't shear off. As the flap moves through an angle there is a turning moment on this one. This is not true of the other pins. The rear wing pin has a nut on the back and a pin through it. I haven't checked starboard flap pin yet. It maybe that the turning tends to tighten that side and loosen the Port. And it maybe that due to alignment perhaps there was some pressure on it.
I can only assume that in this case redux was omitted or sparse. I cant recall if the socket it goes is a bearing and whether lubrication should have been regularly applied. The other pins are greased.
kit4 (Wagstaff) TBD
Roland
Posted: Mon Oct 17, 2016 12:17 am Post subject: Re: Whoops - loss of flap pin |
Graeme,
many thanks for sharing this. Although mine is an XS, I will check the pins thoroughly more often since I trailer my Europa to the airfield and so have access to them.
Roland
PH-ZTI
XS TG 914
kingsnjan(at)westnet.com. Guest
Posted: Mon Oct 17, 2016 1:34 am Post subject: Whoops - loss of flap pin |
Graeme,
I fail to see how there is any turning moment on the flap drive pin. Both the flap and the flap cross tube pivot around a common axis.
However, because of the wings dihedral, if the floating bearing in the end of the flap cross tube is seized or very tight, this may possibly induce some turning moment especially if the bearing surface of the pin inside the bearing was not lubricated.
Personally, I hope there is no knee jerk reaction to this failure resulting in a mandatory mod. My flap drive pins were reduxed in and if the problem I had getting my rear wing pins out for that mod are any example, there is no way my flap drive pins are ever going to back out of their own accord.
Best Regards
Kingsley in Oz
Quote: | On 17 Oct. 2016, at 5:28 am, graeme bird <graeme(at)gdbmk.co.uk> wrote:
Graeme Bird
G-UMPY - Mono Classic/XS FFW 912S, Woodcomp 3000/3W CS, trutrak Gemini 2 axis ap, pflarm, ads-b out, 8.33khz, mode S, FP 5, Aera500 & SD on Nexus,
250 hours & 4 years on the Mono, 880 total
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=461350#461350
graeme bird
Posted: Mon Oct 17, 2016 9:03 am Post subject: Re: Whoops - loss of flap pin |
I can now confirm it was a build issue and not a design problem. The starboard pin was fully in and had not moved, but not glued in. I shall also be checking these regularly now and will also keeping lubricated along with the bearing.
kit4 (Wagstaff) TBD
