brainsflight(at)yahoo.com Guest
Posted: Sun Jul 09, 2006 6:18 am Post subject: Question for finished builders |
I had a quick question, or actually a survey I guess, of finished builders who painted their airplanes before their 1st flight or waited until later (and benefits either way).
The reason I ask is that I am considering a minimalist approach to get my airplane in the air (safely), fly off the required time, then over some time do the final detail work like paint, etc.
Brian "Brain" Kissinger
www.brainsflight.com
701 factory kit
fuselage on gear
finishing tail section
wings skeletons complete
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
planejim(at)bellsouth.net Guest
Posted: Sun Jul 09, 2006 8:25 am Post subject: Question for finished builders |
Brian,
I've built three airplanes over the years, two of which were painted. I painted the first of the two after flying it a while. It had a thin coan of Chromate while flying it before taking it out of service to paint it. Had to "Strip" the Chromate off before painting. This was the most work on that plane.
The second plane I painted is the one I'm flying now. I painted it before ever flying it. It was easier doing it that way. The drawback is the problem of touch up when you have to disturb the nice new paint job for corrections. I've had to do that too.
With all that said, I think if I've just built a kit plane to specs, I'd paint it before flying it. Just my oppinion!
Jim Hoak
Posted: Sun Jul 09, 2006 8:44 am Post subject: Question for finished builders |
Brian,
It's a good thing to paint before first flight if you can manage it. I
flew 85 hours before deciding to paint and would estimate it will cost
me more than 100 hours
extra in the preparation and clean up going forward to paint. I've been
at this since April and only have the small parts nearly done. I'd
probably still have done
it this way because that's the way I work, but if you can manage to get
a coat of paint on it before the fact, you'll save a lot of time.
Also, paint in cool weather
if you can 70-80 degree days or air conditioned air will save you rework.
Larry McFarland - 601HDS
Brian kissinger wrote:
Quote: | I had a quick question, or actually a survey I guess, of finished
www.brainsflight.com <http://www.brainsflight.com>
701 factory kit
fuselage on gear
<http://us.rd.yahoo.com/mail_us/taglines/postman7/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com>
dredmoody(at)cox.net Guest
Posted: Sun Jul 09, 2006 11:45 am Post subject: Question for finished builders |
A close friend of mine who is building an RV7-A (with my scant help) is planning to finish his plane, get it inspected and certified, fly off the required hours then choose a commercial aircraft painter and fly it to them. We've seen lots of planes that were not painted flown to local fly-ins so I guess it's fairly routine to do that. If you decide to make some significant modification during or after the test period it would nice not to have to repaint, wouldn't it?
Ed Moody II
Rayne, LA
601XL / 2nd wing
Quote: | From: Brian kissinger (brainsflight(at)yahoo.com)
Subject: Question for finished builders
jean-paul.roy4(at)tlb.sym Guest
Posted: Sun Jul 09, 2006 2:23 pm Post subject: Question for finished builders |
Brian, I've been thinking about it also and I came out with an answer (my answer).
If I don't paint it before I fly it first, I'll never see an end to it. Plus this adds to the dismantling and re-assembly time.
When it'll take off, it will be painted. Mind you, it is only MY opinion.
Jean-Paul
NYTerminat(at)aol.com Guest
Posted: Sun Jul 09, 2006 8:13 pm Post subject: Question for finished builders |
I painted mine in pieces before final assembly. No regrets.
Bob Spudis
N701ZX CH701 60 hrs
In a message dated 7/9/2006 10:19:29 A.M. Eastern Daylight Time, brainsflight(at)yahoo.com writes:
Quote: | had a quick question, or actually a survey I guess, of finished builders who painted their airplanes before their 1st flight or waited until later (and benefits either way).
xl(at)prosody.org Guest
Posted: Sun Jul 09, 2006 10:22 pm Post subject: Question for finished builders |
I wanted to fly so I did not do anything that wasn't necessary.
No paint (except the cowl), no upholstery, no wheel pants.
I do get the 'when are you going to paint it?' and 'someday you'll
install wheel pants, right?' comments. But, I'm flying and that's
what matters to me. Yeah, the plane shows my personality.
I'd rather fly than paint, and I like the bare metal - that's the
primary reason. Painted planes look good too - but different.
If you plan to paint it, do it before you fly.
You won't want to take the time after the first flight.
It goes without saying that this is my opinion - and what do I know???
Joe E
N633Z (at) BFI
CH601XL, 365 hours and still no paint
started May 2003, at AWO ready to fly Dec 2003
build time = 1077.5 hours
Jabiru 3300, Sensenich 64x49 wood prop
http://www.cleanh2o.com/633z/
Thanks, Brian "Brain" Kissinger
nfivesl(at)yahoo.com Guest
Posted: Mon Jul 10, 2006 4:25 am Post subject: Question for finished builders |
Joe:
Tell me you did not paint a naked lady on your
airplane! (that was rhetorical). Joe, you inspired me
a few years ago when you built your airplane in a tent
in your yard. You continue to inspire me and I
appreciate your posts. I think I may leave mine
unpainted for a while also. Thanks!
Scott Laughlin
www.cooknwithgas.com
--- xl <xl(at)prosody.org> wrote:
Quote: | I wanted to fly so I did not do anything that wasn't
necessary.
pants.
frank.hinde(at)hp.com Guest
Posted: Mon Jul 10, 2006 6:10 am Post subject: Question for finished builders |
Yup my HDS went 400 hours and 7 years and only ever got the fiberglass
painted.
Trouble is the Wife won't let me move the RV to the airport until it has
paint...Having never painted before this task was daunting but it's a
lot of fun learning how...I have everything painted except the wings so
far
Frank
JAPhillipsGA(at)aol.com Guest
Posted: Mon Jul 10, 2006 6:51 am Post subject: Question for finished builders |
Brian, how you paint, when and with what is a personal touch and is really the only large imprint you will make on your plane. I was at the hanger for a flight Saturday morning and afterwards some adjustments. The fellow next door was working on his RV 9. His plane is complete structure and he's wiring now. He received a call that a pal of his was arriving in a bit in his RV9 so I was expectant. The plane arrived and at a distance looked ok. Now I am no airplane building master, but the fit and finish of this plane was very poor. Bucked up skin edges on the fuselage, un even rivets lines and heads, long thick ugly paint runs, rough edges that looked like they were cut with a hack saw. Even had a trim line side that looked like a child had put it on with a Magic Marker. To say the least it was very disappointing. My hanger neighbor's plane is a marvel of perfect finish and attention to detail as his many years in the aircraft industry would reflect. After the RV had departed he to indicated his disappointment in the plane as well. Long story, short answer. If the outside looks like crap the prudent pilot would reason that the insides were questionable as well. Best regards, Bill of Georgia
Posted: Mon Jul 10, 2006 8:07 am Post subject: Question for finished builders |
How sad....Thats an expensive airplane to do such a poor job on.
I think though Bill your right in that there is a world of difference betwen an aircraft that has been built and one that has been thrown together. I have seen many zodiacs that look like they were hammered into shape...Not in my airplane thanyou very much.
I had two most memeral experiences.
1) I had just finished the Zodiac...My local A&P (with IA of course) showed up at my hangar on his way home from work...Now this guy was an exercise in intimidation...Harley biker dude, rough gruff, he was good and he knew it. He also had a heart of gold but I didn't know that then. He grunted hello...just invited himself into my hangar and slooowly walked around my airplane...Leans back against his El Camino and starts rolling a joint..I mean cigarette...And I think...Here it comes, the lecture about shade tree no hopers slamming together airplanes lecture..he siad..."Frank I have to say...Pregnant pause....You made a beautiful job job of building this airplane!"
Needless to say I couldn't stop the grin spreading across my face!...His Name was Mike Farmer...4 years later i had the privilage of recieving the phone call that he wanted to see me to sit with him at his death bed... he was quite a guy and became one of my best friends.
2) All my expert (and I mean expert) builder friends show up on their bikes..and my freshly painted fuse (RV7a) is outside the shop. Turns out they wer'nt sure where I lived but happed to be tooling down my road and aw the plane in my yard...Of course they all turn round and in they come. One of these guys is an expert painter/airbrusher...He stood there and gushed, "Frank it looks great, its not perfect but no paint job ever is and I think you done a very nice job!"
For me at least these are points in my building career that mean a lot...Kinda weired but I enjoy creating an airplane more than I enjoy flying it really...But maybe that was because the HDS was SLOW!...I think the 7a might be a little different....
Oh well enough waxing andback to work
Frank
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of JAPhillipsGA(at)aol.com
Sent: Monday, July 10, 2006 7:50 AM
Subject: Re: Zenith-List: Question for finished builders
Posted: Mon Jul 10, 2006 9:41 am Post subject: Question for finished builders |
Frank, as hard as you work and fret over your airplanes I am sure this RV you've built will be an eye pleasing performer. Best regards, Bill of Georgia
ggower_99(at)yahoo.com Guest
Posted: Thu Jul 13, 2006 11:39 am Post subject: Question for finished builders |
Bill,
That makes a lot diference in building hours... When we finished our 701, we could understand why the factory estimated building hours never match with the real hours invested in building. Same "inside" the airplane that outside.
Over detailing an airplane could never make his first flight
Saludos
Gary Gower.
Do not archive.
JAPhillipsGA(at)aol.com wrote:
Quote: | Brian, how you paint, when and with what is a personal touch and is really the only large imprint you will make on your plane. I was at the hanger for a flight Saturday morning and afterwards some adjustments. The fellow next door was working on his RV 9. His plane is complete structure and he's wiring now. He received a call that a pal of his was arriving in a bit in his RV9 so I was expectant. The plane arrived and at a distance looked ok. Now I am no airplane building master, but the fit and finish of this plane was very poor. Bucked up skin edges on the fuselage, un even rivets lines and heads, long thick ugly paint runs, rough edges that looked like they were cut with a hack saw. Even had a trim line side that looked like a child had put it on with a Magic Marker. To say the least it was very disappointing. My hanger neighbor's plane is a marvel of perfect finish and attention to detail as his many years in the aircraft industry would reflect. After the RV had departed he to indicated his disappointment in the plane as well. Long story, short answer. If the outside looks like crap the prudent pilot would reason that the insides were questionable as well. Best regards, Bill of Georgia |
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Mon Jul 17, 2006 8:21 am Post subject: Re: Question for finished builders |
My 10 cents I started building (701) in 1991. Prior to assy of anything I would scotchbrite, alumprep, (alodine sometimes), and prime. My wings have been finished and stored for over 6 years and are painted on the outside (rag wiped) with zinc chromate (rattle can for all internal parts). I know that if I wipe this off to use a different primer I will have a nice shiny clean alum surface underneath. Over the years I have switched to Primers more compatible with modern finish paints. However, today I have the fuse nearly finished. wings, rudder, stab, flaperons and slats all finished and I don't have a single component that is not primed. I consider the inside finished except for the cabin area which I will finish paint. I'd die if I had to paint everything in one shot. I'm so used to painting as I go along now that it's just part of the building process. For me I believe that this is the way to go. By the way, most everything is different shades of grey right now and without a finish paint job it looks quite nice compared to a bare metal job ........Geoff
