Securing Split PVC Conduit
art(at)zemon.name
PostPosted: Mon Dec 26, 2016 7:06 pm    Post subject: Securing Split PVC Conduit Reply with quote
Folks,
I am using some split PVC conduit in my plane and two of the runs are pretty close to vertical, about 4 feet long. Sitting in my garage, with the wires not yet secured at the bottom, the conduit keeps trying to slide downward in the 2 inch square channels through which it runs. I think that I ought to secure it somehow and wonder if you have any ideas that will keep it in place.
Maybe I can wrap a thin cable tie around it and get it to slip into a groove?
Or maybe wrap it with silicone self-sealing tape and the put an AN742 clamp around it?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
PostPosted: Tue Dec 27, 2016 6:18 am    Post subject: Re: Securing Split PVC Conduit Reply with quote
Is conduit necessary inside of a channel?
Joe Gores
art(at)zemon.name
PostPosted: Tue Dec 27, 2016 6:44 am    Post subject: Securing Split PVC Conduit Reply with quote
When there are sharp things sticking into the channel, yes
On Tue, Dec 27, 2016 at 8:18 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
neal.george(at)gmail.com
PostPosted: Tue Dec 27, 2016 9:13 am    Post subject: Securing Split PVC Conduit Reply with quote
A dab of RTV?
Neal George
[quote] On Dec 26, 2016, at 10:05 PM, Art Zemon <art(at)zemon.name> wrote:
Folks,
halbenjamin101(at)gmail.c
PostPosted: Tue Dec 27, 2016 11:31 am    Post subject: Securing Split PVC Conduit Reply with quote
Hi Art,
You could probably use safety wire wrapped around the split loom and hang it using tape to hold the safety wire.
Hal Benjamin RV4
Folks,
holger-d(at)shadowbrush.c
PostPosted: Tue Dec 27, 2016 3:07 pm    Post subject: Securing Split PVC Conduit Reply with quote
I’ve used lacing tape for that purpose in the past. So friendly to do-overs.
Holger
On Dec 26, 2016, at 7:05 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
ashleysc(at)broadstripe.n
PostPosted: Fri Dec 30, 2016 8:26 am    Post subject: Securing Split PVC Conduit Reply with quote
Hi Neal and Art;
Google "wire ties with mounting holes."
Morris Products makes several types.
Cheers! Stu.
Sent: Tuesday, December 27, 2016 9:11:53 AM
Subject: Re: Securing Split PVC Conduit
A dab of RTV?
Neal GeorgeSent from my iPhone
On Dec 26, 2016, at 10:05 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
-- Art Z.
art(at)zemon.name
PostPosted: Sun Jan 01, 2017 11:36 am    Post subject: Securing Split PVC Conduit Reply with quote
Holger,
I think this will work perfectly. Thank you! The lacing will slip into the grooves on the conduit. I can attach nylon cable tie anchors to the airplane and lace the conduit to the anchors.
    -- Art Z.
On Tue, Dec 27, 2016 at 5:04 PM, Holger Selover-Stephan <holger-d(at)shadowbrush.com (holger-d(at)shadowbrush.com)> wrote:
Holger
Folks,
PostPosted: Sun Jan 01, 2017 3:32 pm    Post subject: Re: Securing Split PVC Conduit Reply with quote
Clean the aluminum with solvent prior to sticking on the cable tie mounts or else they will eventually fall off.
Joe Gores
