kenryan
Bob McC
Posted: Mon Feb 06, 2017 8:49 am Post subject: fluid level sensor |
Looking up the chemical resistance of the plastic from which this sensor is manufactured it appears to have excellent resistance to all forms of gasoline, benzine, astm fuels and astm oils as well as ethylene glycol and brake fluid.. So yes, it would appear suitable for use in a header tank. However a query to the manufacturer requesting their opinion would yield the safest answer. Tell them the application is for level in a fuel storage tank NOT an aircraft header tank.😄
Bob McC [quote] --------
_________________ Bob McC
Falco #908
(just starting) |
Posted: Mon Feb 06, 2017 11:25 am Post subject: fluid level sensor |
At 09:19 AM 2/6/2017, you wrote:
| Quote: | | Can you guys tell me if this (153064) would be an appropriate sensor for my 5 gallon header tank to turn on an LED if the tank is not full? |
Polysulfone enclosure material for this device is
very compatible with motor fuels.
I proposed using this sensor as a component of
an upgrade to a series of low liquid level sensors
I worked on for Electro-Mech WAaaayyy back when . . .
We crafted a series of optical liquid level sensors
that were widely used on Beech products. It looks
like they still make some version of them . . .
http://tinyurl.com/hgs24nt
When the Premier was still under development, I
became aware of dismal failure rate in these
devices. Given the simplicity of the product,
it was rather astounding. Dean Matson and I
were co-developers of the original concept and
we were working together at Beech's Targets
division when the news came to us.
To make a long story short, this program proved
to be a fine example of what can happen when a
small, tightly coupled design, development and
manufacturing operation gets bought out and
'upgraded' with all the albatrosses and millstones
of the parent corporation after a buyout.
I suggested that the fast-turn solution for the
failures was to modify a GEM sensor to fit into
the stock Electro-Mech enclosure. Had this
problem surfaced in the same regulatory and
business environment I enjoyed in 1985, we could
have put the fix into production in a couple
months at most. But in 2004 . . . well . . .
I was pretty busy fighting other fires then and
I don't know what they wound up doing to fix
the EM product . . . but the short answer to your
question is that the GEM sensor is well suited to
the application you are proposing.
For those interested in the history of this technology
in aircraft, I've posted a few snapshots of my own
experience with it at http://tinyurl.com/h586hp9
hilltopkid
Posted: Mon Feb 06, 2017 2:55 pm Post subject: fluid level sensor |
Ken,
For what it's worth, here is the information on the two level switches we bought for our Subaru back in 2009. I just dialed the phone number for e-Components International and got voice mail which appeared to be the same person, Tammy, which we dealt with back then.
Manufacturer: Fozmula Limited Griffiths House, Hermes Close, Tachbrook Park, Warwick, CV34 6UF, United Kingdom
Tel: +44 (0) 1926 466700 | Fax: +44 (0) 1926 450473 |
http://www.fozmula.com/
Tammy was the local rep we dealt with at:
e-Components International Inc.
307 Spring Hill Road
Lancaster, VA 22503
United States
ph: 804-462-5679
fax: 804-462-0556
sales(at)e-components.net (sales(at)e-components.net)
We bought:
S85/03 1/4" NPTF capacitive Fozmula switch for engine coolant
S86/03 Capacitive Fozmula switch 1/4" switch for gasoline
Dee
DeWitt (Dee) WhittingtonRichmond, VA
804-677-4849 iPhone
804-358-4333 Home
On Mon, Feb 6, 2017 at 10:19 AM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
_________________ DeWitt (Dee) Whittington
Richmond, VA |
jim(at)PoogieBearRanch.co Guest
Posted: Mon Feb 06, 2017 4:51 pm Post subject: fluid level sensor |
One other potential approach for your consideration... Belite
Electronics makes lightweight, low-cost instrumentation for ultralight
and experimental aircraft. They have developed a line of fuel sensors
and gauges that are pretty cool. You can go to
http://www.beliteaircraft.com, then go to their "electronics" page to
see all the gauges.
They sell capacitance fuel probes that are much lighter and less
expensive than the "commercial" ones, and will custom make them to your
length if desired. And they make several different single- and dual-tank
gauges (including the "Radiant" gauges that were featured in Kitplanes
and AvWeb feature articles).
But the one I really like is the "Low Profile Fuel Probe," which is a
MEMS-based "pressure-reading" transducer that effectively measures the
mass of the fuel in the tank. It can be purchased with a "fuel computer"
that calibrates and translates the fuel probe's output into 0.0 volts
(empty) to 5.0 volts (full), with intermediate calibration points at
1/4, 1/2, and 3/4 levels. It can also be purchased without the fuel
computer, for use with the "Radiant" fuel gauges that already have the
calibration/translation feature built in.
I plan to use the low-profile fuel probe (without computer - $100) and
the Radiant dual-tank gauge ($300) as the primary fuel level indicator
for the Bearhawk Patrol I'm building. I'll have sight glass tubes as a
backup, but they are harder to see from the pilot's seat. The two probes
and the gauge together will add only a few ounces to the empty weight -
probably about as much as the wiring from panel to wing tanks!
But that solution would probably be major overkill for your intended
purpose of monitoring the fuel level in the header tank. For that, I
would use the Low Profile Fuel Probe (with fuel computer - $200) and the
single-display Fuel Gauge ($80).
Some of you are probably be creative (and skilled) enough to forgo the
fuel computer or even the gauge, creating your own circuit to measure
the sensor output and decide when to turn on a "warning light" when the
level drops below your desired level. But me – I'm too much of a
"newb" to even attempt such a thing, so I'll stick to a "professionally
designed" system.
Jim Parker
kenryan
Posted: Tue Feb 07, 2017 1:03 pm Post subject: fluid level sensor |
Thanks for the responses. I'll probably use the Gems but it's good to know there are other options.
On Mon, Feb 6, 2017 at 3:48 PM, <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)>
see all the gauges.
designed" system.
Jim Parker
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
ceengland7(at)gmail.com Guest
Posted: Tue Feb 07, 2017 2:37 pm Post subject: fluid level sensor |
Don't forget to check ebay before purchasing; there are often much better deals there on the Gems type sensors.
Charlie
On 2/7/2017 3:00 PM, Ken Ryan wrote:
| Quote: | Thanks for the responses. I'll probably use the Gems but it's good to know there are other options.
see all the gauges.
designed" system.
Jim Parker
rick(at)beebe.org Guest
Posted: Wed Feb 08, 2017 9:02 pm Post subject: fluid level sensor |
FWIW, I have the Belite RADIANT dual fuel gauge in my GlaStar and I love
it. I'm using it with the capacitance senders that came with the plane
and it works great. The gauge is very readable, very light, and was easy
to install and configure.
--Rick
On 2/6/2017 7:48 PM, jim(at)PoogieBearRanch.com wrote:
see all the gauges.
