dean.psiropoulos(at)veriz Guest
Posted: Sat Feb 11, 2017 3:22 pm Post subject: Icom junction box |
Someone was asking on this forum about issues with the Icom antenna junction
box installed in their plane. I put in one of those in between my SL-30
Nav/Com and my belly antenna on the RV-6A. I've had a lot of scratchy and
not so great transmissions/reception on that Radio. I didn't think that
maybe if would be that junction box. I like the idea because it makes it
easy to plug in my hand held and use my outside antenna. But I've never had
to do that so if the junction box is causing crappy tx/Rx on that radio I'll
take it out of the loop. I know the SL-30 is a great radio so this has
puzzled me since I finished the RV. Did whomever it was figure out whether
the Icom junction box was causing radio Tx/Rx problems or not? Does the
junction box need to be removed from the loop or is there some I can do to
fix it?
Dean Psiropoulos
RV-6A N197DM
Tarpon Sprgs, FL
Posted: Sun Feb 12, 2017 11:06 am Post subject: Icom junction box |
At 05:09 PM 2/11/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Dean Psiropoulos" <dean.psiropoulos(at)verizon.net>
fix it? |
It's a simple experiment to take it out and see
if the complaints go away. I'm not encouraged about
'fixing' a poorly performing example of this
product. Best advise is to take it out and add
pilot accessible junctions and coax jumpers
to get your hand-held connected to ship's antenna.
kenryan
Posted: Sun Feb 12, 2017 12:10 pm Post subject: Icom junction box |
Bob, regarding the coax junctions, what are the specs to look for?
On Sun, Feb 12, 2017 at 10:02 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 05:09 PM 2/11/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Dean Psiropoulos" <dean.psiropoulos(at)verizon.net (dean.psiropoulos(at)verizon.net)>
fix it? |
alec(at)alecmyers.com Guest
Posted: Sun Feb 12, 2017 12:18 pm Post subject: Icom junction box |
I've never met your radio, but I'd put a small amount of money on a wager that your problem lies in a badly terminated cable - a badly crimped, loose or corroded BNC connector, somewhere.
99% of failures are either the fuse or the connector
On Feb 12, 2017, at 15:05, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
fix it? |
