Rick S.
Posted: Tue Jul 11, 2006 6:37 pm Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
John,
Your not far off...I checked the FAA data base and there were 58 RV-10's registered, I think, there were two pages of them, some may be waiting for a DAR??? But none the less, almost 60 of them in the database.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Dick Sipp
Posted: Tue Jul 11, 2006 6:56 pm Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
You may well be right Rick, but also unless I am mistaken as soon as someone
applies (not reserves) for the N number it goes on the registry. So there
might be lots of folks who have applied for thier number but still have a
ways to go before flight. When I built the 4 I had the number a year early.
Dick Sipp
40065 110DV reserved
top & wiring
Tdawson(at)avidyne.com Guest
Posted: Tue Jul 11, 2006 7:32 pm Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Registered can be a long way from flying . . .
(Except in Doug Peterson's case!)
TDT
johnwcox(at)pacificnw.com Guest
Posted: Wed Jul 12, 2006 7:12 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
No actually it is a two step process. My N number N49CX is reserved but
you will not find it on the registry because I have not requested the
Airworthiness Inspection yet.
John
Posted: Wed Jul 12, 2006 7:26 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
It's a three-step process:
1) Reserve N-number. There airplane is not yet "registered", but the
number is recorded in the "registry" as reserved. If fact, there may
not even be an aircraft, it might just be someone hoarding numbers.
2) Register your aircraft.
3) Get your inspection.
Don't wait until you're ready for an inspection to submit your
registration, or you will be cooling your heels for 3-4 weeks while the
FAA processes it. No inspection without an approved registration form
in hand.
TDT
40025
jesse(at)itecusa.org Guest
Posted: Wed Jul 12, 2006 7:27 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
The N-number, as I understand it, is just reserved and not marked to the
RV-10 until you send in the application for registration. Yes, you can do
this whenever, but I don't think it is usually done until getting close to
flying. I think it would be fairly safe to say that those 58 planes are
either flying or getting pretty close to the DAR time.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Wed Jul 12, 2006 7:31 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Uh, we're registered, but unless I can teach a 5 month-old how to
install engine baffling, we won't be flying for a little while . .
So you're down to 57 . . .
TDT
Jack.Phillips(at)cardinal Guest
Posted: Wed Jul 12, 2006 7:43 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Depends on if you want a number that is "popular". I've already
reserved the number for my RV-10, even though I won't order the tail kit
until next week. Mine will be N142KW, just because I want to be able to
call out "Tequila Whisky turning final, runway 23 Left"
Jack Phillips
Pietenpol, NX899JP
RV-4, N18LR
RV-10 (Someday), N142KW
NYTerminat(at)aol.com Guest
Posted: Wed Jul 12, 2006 8:05 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Jack,
You had better change your tail # to N142TW if you want to say "Tequila Whisky"
In a message dated 7/12/2006 11:46:03 A.M. Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes:
| Quote: | --> RV10-List message posted by: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Jack Phillips
Posted: Wed Jul 12, 2006 8:15 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
I guess I meant to say below "pretty close to DAR time", not actually
waiting on an inspection.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
brinker(at)cox-internet.c Guest
Posted: Wed Jul 12, 2006 8:44 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Would'nt that be "tango,whiskey" ?
rvbuilder(at)sausen.net Guest
Posted: Wed Jul 12, 2006 9:08 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
“Two Kilo Whiskey” Say it fast. J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brinker
Sent: Wednesday, July 12, 2006 11:40 AM
Subject: Re: RV-10 Builders List / RV-10's to OSH / RV-10
No, 2KW would be “two kilo whisky” or if you say it fast, “Tequila Whisky”
Jack Phillips, PE
Sr. Manager, Disposables Product Development
Clinical Technologies and Services
Cardinal Health
Creedmoor, NC
(919) 528-5212
KBelue(at)drs-tem.com Guest
Posted: Wed Jul 12, 2006 9:27 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
N142KW shortened to 2KW,
Two Kilo Whiskey said fast : Tequila Whiskey
[b] [/b]
Posted: Wed Jul 12, 2006 9:36 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Wish we could use all letters like the Brits:
G-PSST
G-ZOOM
G-DOGS
G-NADS
TDT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Belue, Kevin
Sent: Wednesday, July 12, 2006 1:06 PM
To: 'rv10-list(at)matronics.com'
Subject: RE: RV-10 Builders List / RV-10's to OSH / RV-10
[b] [/b]
sschmidt(at)ussynthetic.c Guest
Posted: Wed Jul 12, 2006 9:46 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
If there are any RV-10’s flying through Salt Lake going to or coming from Oshkosh and weather becomes an issue, I have room for a couple of RV-10’s in my hanger if you need to make a stop.
I am at KBTF (Bountiful Skypark). My cell number is listed below.
I’ll see you guys there.
Scott Schmidt
Cell 801-319-3094
sschmidt(at)ussynthetic.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Wednesday, July 12, 2006 11:08 AM
Posted: Wed Jul 12, 2006 9:54 am Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
Makes sense now lol
gorejr(at)bellsouth.net Guest
Posted: Wed Jul 12, 2006 1:17 pm Post subject: RV-10 Builders List / RV-10's to OSH / RV-10 |
How does one go about reserving an N number? Jim
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Date: 2006/07/12 Wed AM 11:25:08 EDT
in hand.
TDT
40025
