		flysrv10(at)gmail.com Guest
				 Posted: Sun Jun 18, 2017 10:35 pm    Post subject: Antsplat products |
				Hello All,
 Anyone using oil separator made by Antisplat Aero?
 Thanks.
  Rob Kermanj
				 Posted: Mon Jun 19, 2017 3:45 am    Post subject: Antsplat products |
				I know quit a few people are, but there have been problems with the port that dumps the air into the exhaust clogging and blowing out the front crankshaft seal. Unless that problem has been addressed, don't use that part of the system.
 Jesse Saint
 Saint Aviation, Inc.
 352-427-0285
 Sent from my iPad
 On Jun 18, 2017, at 5:13 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Hello All,
 Thanks.
  Rob Kermanj
		Kelly McMullen
				 Posted: Mon Jun 19, 2017 5:03 am    Post subject: Antsplat products |
				IIRC there has been a discussion or two on oil/air separators that folks have been happy with. Seems like Super Slime fighter might have been one.
 -sent from the I-droid implanted in my forearm
 On Mon, Jun 19, 2017 at 4:43 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
  	  | Quote: | 	 		  I know quit a few people are, but there have been problems with the port that dumps the air into the exhaust clogging and blowing out the front crankshaft seal. Unless that problem has been addressed, don't use that part of the system.
 Jesse Saint
 [url=tel:(352)%20427-0285]352-427-0285[/url]
 Sent from my iPad
  	  | Quote: | 	 		  Hello All,
 Thanks.
  Rob Kermanj
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Mon Jun 19, 2017 8:19 am    Post subject: Antsplat products |
				Had a similar issue with my Andair separator.  A press fit baffle came loose and blocked the exit line causing  a lot of engine oil leaks.  A cutter pin holding the baffle fixed the problem.
  	  | Quote: | 	 		  On Jun 19, 2017, at 7:43 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
 I know quit a few people are, but there have been problems with the port that dumps the air into the exhaust clogging and blowing out the front crankshaft seal. Unless that problem has been addressed, don't use that part of the system. Jesse Saint
 352-427-0285
 Sent from my iPad
  	  | Quote: | 	 		  Hello All,
 Thanks.
  Rob Kermanj
		flying-nut(at)cfl.rr.com Guest
				 Posted: Mon Jun 19, 2017 8:34 am    Post subject: Antsplat products |
				I'm not a fan of air/oil separators.        If you have too much oil on the belly from the crankcase breather       then there is a problem lurking in your engine.  The air/oil       separators are a bandaid that covers up the results of excessive       blow-by from broken or worn-out rings.  As has been posted       already, failure of the separator can be terribly expensive.
        A better (in my mind) solution to an oily belly would be to extend       the breather tube down lower in the slipstream. IMHO.
        Linn
        On 6/19/2017 12:17 PM, Rob Kermanj wrote:
       	  | Quote: | 	 		                Had a similar issue with my Andair separator.  A press fit baffle       came loose and blocked the exit line causing  a lot of engine oil       leaks.  A cutter pin holding the baffle fixed the problem.
                    352-427-0285
                    Sent from my iPad
                   	  | Quote: |        Hello All,
                      Thanks.
        Rob Kermanj
 No virus         found in this message.
          Checked by AVG - www.avg.com
          Date: 06/19/17      |
		tomrv4
				 Posted: Mon Jun 19, 2017 8:49 am    Post subject: Antsplat products |
				Is there a reason why a well vented container to catch the blow by mounted low on the firewall could not be used?
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters
 Sent: Monday, June 19, 2017 11:34 AM
 Subject: Re: Antsplat products
 Linn
 Jesse Saint
 352-427-0285
 Sent from my iPad
 Hello All,
 Thanks.
 Rob Kermanj
 Date: 06/19/17 |
  _________________ Tom
San Antonio |
				 Posted: Mon Jun 19, 2017 9:31 am    Post subject: Antsplat products |
				None at all.  Use a tall glass jar       ..... like olives come in .....  and put a stainless scrubby (or       two) in the bottom around the tube.  Depending on the amount of       blow-by you may get some mist of oil near the jar.   Check the oil       level in the jar during your preflight if you can see it through       the air exit ramp.
        Linn
        On 6/19/2017 12:49 PM, Tom Chapman wrote:
       	  | Quote: | 	 		                         <![endif]-->   <![endif]-->
 From:                 owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)                 [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On                   Behalf Of Linn Walters
              Linn
 Jesse Saint
 352-427-0285
 Sent from my iPad
 Hello All,
 Thanks.
 Rob                                   Kermanj
              Date: 06/19/17          |
          Date: 06/19/17      |
		Kelly McMullen
				 Posted: Mon Jun 19, 2017 11:34 am    Post subject: Antsplat products |
				Not necessarily true. There is an art to finding where to terminate the breather tube so that it is in neither high nor low pressure area. If in low pressure area, extra blowby departs the crankcase. I have seen brand new engines, built with rings in spec, that had too much oil out the breather tube. It most certainly was NOT an mechanical problem. IMHO, breathers with or without separators should not be connected to the exhaust system. The relative pressure also determines how much oil you can keep in the sump. A well designed separator should have nothing that can come loose into the airstream. How you deal with the separated oil is a whole 'nuther debate.
 On Mon, Jun 19, 2017 at 9:33 AM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
  	  | Quote: | 	 		                     I'm not a fan of air/oil separators.        If you have too much oil on the belly from the crankcase breather       then there is a problem lurking in your engine.  The air/oil       separators are a bandaid that covers up the results of excessive       blow-by from broken or worn-out rings.  As has been posted       already, failure of the separator can be terribly expensive.
KCHD |
				 Posted: Mon Jun 19, 2017 12:11 pm    Post subject: Antsplat products |
				I'm sure there are installations that       are problematic, but I've not come across one personally.  Most of       the crankcase vents I've dealt with are in the nose of the       crankcase and the routing of the hose back to the firewall       typically drop a little as the hose makes it's way aft which means       that a little oil in the tube always drains aft .... and drips on       the hangar floor.  As you said .... even engines in great shape       may drip.
        This will be my second encounter using the accessory case for the       vent .... my O-360 in my Pitts was the first .... but the inverted       oil system routes all the excess back to the tail.
        Speaking of which, the Grummans have a 'whistle hole' on the tube       up inside the cowl to prevent freezing over the tube and blocking       the vent.  I don't think that's a common practice on the Vans       vents for whatever reason.
        Linn
        On 6/19/2017 3:33 PM, Kelly McMullen wrote:
       	  | Quote: | 	 		         Not necessarily true. There is an art to finding         where to terminate the breather tube so that it is in neither         high nor low pressure area. If in low pressure area, extra         blowby departs the crankcase. I have seen brand new engines,         built with rings in spec, that had too much oil out the breather         tube. It most certainly was NOT an mechanical problem. IMHO,         breathers with or without separators should not be connected to         the exhaust system. The relative pressure also determines how         much oil you can keep in the sump. A well designed separator         should have nothing that can come loose into the airstream. How         you deal with the separated oil is a whole 'nuther debate.
          Date: 06/19/17      |
		Kelly McMullen
				 Posted: Mon Jun 19, 2017 1:07 pm    Post subject: Antsplat products |
				Only Continental engines have the vent on the nose of the case, AFAiK. Lycomings use the accessory case, and they like to blow overboard oil that is above a certain amount. It is easier with the Continentals to have an uphill run of some distance to condense the oil back out of the blowby stream. My planes with Lycoming engines typically did not drip from the vent after shut down. But they did ensure that the belly had a fine mist of oil. If it weren't a common problem, there would not be so many "solutions" on the market.
 On Mon, Jun 19, 2017 at 1:11 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
  	  | Quote: | 	 		                     I'm sure there are installations that       are problematic, but I've not come across one personally.  Most of       the crankcase vents I've dealt with are in the nose of the       crankcase and the routing of the hose back to the firewall       typically drop a little as the hose makes it's way aft which means       that a little oil in the tube always drains aft .... and drips on       the hangar floor.  As you said .... even engines in great shape       may drip.
        Linn
          Date: 06/19/17      |
KCHD |
