Troubleshooting 200G/ Z-17
jpoint(at)wi.rr.com
PostPosted: Tue Jul 11, 2017 7:04 pm    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
All,
The good news from today is that I successfully ran my freshly
overhauled O-200 today in preparation for a FAA inspection in a few
weeks. The bad news is that I am getting no alternator output at all.
The alternator is a B&C 200G PM dynamo, wired per Z-17 (no master
contactor.) Running the engine between idle and 1800 RPM saw no change
in bus voltage, which stayed at the same 13.1V as it did with the engine
not running.
Troubleshooting so far- besides checking all wiring connections, I
verified that the OV relay is working and that I wired it correctly. I
verified that the alternator's raw output was as expected (15-25VAC,
increasing with speed.) I measured voltage at the capacitor (just
downstream of the regulator) and it was the same 13.1 and did not vary
with speed. Disconnecting the regulator I verified that there is zero
volts coming out of the regulator, although I understand from the
troubleshooting documents that it must have bus voltage applied in order
to output, so I'm thinking this doesn't mean much.
Is this as simple as a bad regulator? I'm going to call B & C first
thing tomorrow but I thought I'd check here first.
Jeff Point
Milwaukee
PostPosted: Tue Jul 11, 2017 8:17 pm    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
At 10:04 PM 7/11/2017, you wrote:
--> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com>
All,
The good news from today is that I successfully ran my freshly overhauled O-200 today in preparation for a FAA inspection in a few weeks. The bad news is that I am getting no alternator output at all.
The alternator is a B&C 200G PM dynamo, wired per Z-17 (no master contactor.) Running the engine between idle and 1800 RPM saw no change in bus voltage, which stayed at the same 13.1V as it did with the engine not running.
Troubleshooting so far- besides checking all wiring connections, I verified that the OV relay is working and that I wired it correctly. I verified that the alternator's raw output was as expected (15-25VAC, increasing with speed.) I measured voltage at the capacitor (just downstream of the regulator) and it was the same 13.1 and did not vary with speed. Disconnecting the regulator I verified that there is zero volts coming out of the regulator, although I understand from the troubleshooting documents that it must have bus voltage applied in order to output, so I'm thinking this doesn't mean much.
Yes . . . was your alternator disconnect relay closing when
you moved the switch to ALT+BAT postion?
jpoint(at)wi.rr.com
PostPosted: Wed Jul 12, 2017 3:51 am    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
The only relay I have in the system is the small black relay which connects to the crowbar module, and I did verify that it was working.  I cycled it on and off several times while running the engine (via the circuit breaker) with no change in bus voltage.
Jeff
PostPosted: Wed Jul 12, 2017 4:06 am    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
At 06:50 AM 7/12/2017, you wrote:
Jeff
Hmmm . . . without putting my own hands on it
and probing with the instruments . . . it does
sound like a faulty R/R. Check with B&C
jpoint(at)wi.rr.com
PostPosted: Sun Jul 16, 2017 4:12 am    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
Update- A call to B&C and a new regulator was on it's way to me.  They agreed that, while rare, the symptoms and trouble shooting indicated a bad one.  I got the new one, installed it... and nothing.  The same results.
I've confirmed that the dynamo is putting out AC voltage which varies with engine speed as it should.  I confirmed that the regulator is seeing battery voltage (13.1) with the motor off.  I confirmed that the relay is working.
Interestingly, after a longer runup including 10 seconds at full power, battery voltage at the end was 0.2V higher than when we started the run.  This was measured at the panel voltmeter and confirmed by my electrician friend with his high-doller Fluke meter at the battery.
One data point that I failed to mention- I'm running a Earth-X 680C LiFePo battery, and perhaps this battery with it's built-in electronics is somehow disrupting the normal workings of things?  I would still expect bus voltage to come up to the set point of 14.4 at full power, but it did not.
Jeff
--> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com> (jpoint(at)wi.rr.com)
All,
yellowduckduo(at)gmail.co
PostPosted: Sun Jul 16, 2017 4:56 am    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
Occasionally relays will physically close but not pass current.
Might be worth hard wiring across the relay contacts to confirm.
Might be worth clipping a conventional battery onto the Earth-x to see
what happens.
I think my dynamo will go a lot higher than 25vac if it has no load. My
next step might be to conform the AC output under load perhaps by
clipping an automotive headlamp onto the AC output. I'd expect it to
brighten right up at fast idle.
Ken
results.
relay is working.
Jeff
>> All,
> Bob . . .
PostPosted: Sun Jul 16, 2017 1:30 pm    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
Has this system EVER worked?
PostPosted: Sun Jul 16, 2017 1:54 pm    Post subject: Re: Troubleshooting 200G/ Z-17 Reply with quote
Jeff,
With the engine running, measure the voltage between the regulator red and black wires. Then measure the voltage between aircraft ground and the regulator black wire. Engine still running, measure voltage between the battery positive terminal and the regulator red wire. Let us know what you find.
Joe Gores
jpoint(at)wi.rr.com
PostPosted: Sun Jul 16, 2017 2:29 pm    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
This is a new installation on an almost-finished but not yet flown homebuilt... so no. The 200G did work in its previous installation, but it was sent back to B&C for an inspection following a prop strike accident, at which time it was updated to the latest and greatest guts. The new guts required a new regulator as well, as the old one (which worked in the previous installation) would not work with the updated unit.
Jeff
On Jul 16, 2017, at 4:30 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
jpoint(at)wi.rr.com
PostPosted: Sun Jul 16, 2017 2:33 pm    Post subject: Troubleshooting 200G/ Z-17 Reply with quote
I'll give that all a whirl... but with Oshkosh around the corner it will be a couple of weeks. In the mean time help me out- what would you expect to learn from these measurements?
I also have an old but serviceable Odessey 680 that I will swap out for the Earth-x and see if that makes a difference.
Jeff
See you all in Oshkosh next week.
On Jul 16, 2017, at 4:54 PM, user9253 <fransew(at)gmail.com> wrote:
Jeff,
Joe Gores
http://forums.matronics.com/viewtopic.php?p=471070#471070
PostPosted: Sun Jul 16, 2017 4:02 pm    Post subject: Re: Troubleshooting 200G/ Z-17 Reply with quote
Measuring voltage between the regulator red and black wires will tell if the regulator is working or not.
Measuring voltage between aircraft ground and regulator black wire will tell how well the regulator is grounded.
Measuring voltage between battery positive and regulator red wire will tell if all connections are good and have low resistance.
The more information that we have, the easier it will be to troubleshoot the problem.
Joe Gores
