kearney
Posted: Mon Jul 17, 2017 5:47 am Post subject: Alternator |
Hi
I am looking at the Van's FWF kit and am wondering about the supplied alternator. Does anyone know the make / model of the alternator.
My plan is to use an alternator that is easily replaced so that a failure doesn't mean a long delay on the ground.
Cheers
Les
C-GCWZ Flying
C-GROK Some assembly required
Wedig435
Posted: Mon Jul 17, 2017 8:33 am Post subject: Alternator |
Use a 1 wire GM alternator
About $60 at auto zone lifetime warrantee
Jim Villani
Broker / Salesman
Great Real Estate
Jim(at)Sold702.com
Mammoth Creek Excavation
WeDig435.com
702 379 5524 cell
-------- Original message --------
Date: 07/17/2017 7:54 AM (GMT-07:00)
Subject: Alternator
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca>
Hi
Cheers
Les
C-GCWZ Flying
http://forums.matronics.com/viewtopic.php?p=471103#471103
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; - List Contribution Web Site -
p; -Matt Dralle, List Admin.
_________________ Jim V |
Bob Turner
Posted: Mon Jul 17, 2017 10:48 am Post subject: Re: Alternator |
The alternator supplied with the FWF kit in 2010 was a Plane Power 60 amp unit with an internal regulator.
I don't know if that has changed or not since then.
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Mon Jul 17, 2017 12:29 pm Post subject: Alternator |
Hmm, when I ordered in early 2010 it was still shown as Nippondenso, so I deleted and bought Plane Power on my own.
-sent from the I-droid implanted in my forearm
On Mon, Jul 17, 2017 at 11:48 AM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=471111#471111
A&P/IA, EAA Tech Counselor
KCHD |
unitink72(at)gmail.com Guest
Posted: Tue Jul 18, 2017 7:27 am Post subject: Alternator |
I've done a lot of research on the subject. The best option I've found is the Autozone 14118 from a 1976 Chevy Luv.  60 Amp, turns the right way, and externally regulated. I'm not sure why its not more popular unless there's something I'm missing.
-Josh
On Mon, Jul 17, 2017 at 8:47 AM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
C-GCWZ Flying
Lenny Iszak
Posted: Tue Jul 18, 2017 8:32 am Post subject: Re: Alternator |
Just want to mention this so it doesn't get overlooked in the enthusiasm of getting a more easily replaceable alternator.
If you are using an automotive alternator make sure you add overvoltage protection to your charging system. B & C has a crowbar module or there's a more modern option from Perihelion Designs. If you don't have one of these and your voltage regulator fails it can kill a bunch of your expensive avionics.
Couple that with a lithium battery that has OV protection built in, in an overvoltage situation it disconnects itself from the circuit, there's nothing to absorb the high voltage and then all of your avionics are done before you even think about hitting your master switch.
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
kearney
Posted: Thu Jul 20, 2017 2:37 pm Post subject: Re: Alternator |
Lenny
I agree on the OV protection. If you are using a VP-X, it will kill the field in an OV situation.
Cheers
Les
C-GCWZ Flying
Lenny Iszak wrote: | Just want to mention this so it doesn't get overlooked in the enthusiasm of getting a more easily replaceable alternator.
Couple that with a lithium battery that has OV protection built in, in an overvoltage situation it disconnects itself from the circuit, there's nothing to absorb the high voltage and then all of your avionics are done before you even think about hitting your master switch. |
LarryRosen
Posted: Mon Jul 24, 2017 5:16 pm Post subject: Re: Alternator |
Josh, Where did you get the mounting hardware for the LUV alternator. Did the Van's BRACKET KIT FOR GENERIC NIPPON DENSO ALT work?
unitink72(at)gmail.com wrote: | I've done a lot of research on the subject. The best option I've found is the Autozone 14118 from a 1976 Chevy Luv.  60 Amp, turns the right way, and externally regulated. I'm not sure why its not more popular unless there's something I'm missing.
-Josh
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
