		stephenbehn(at)bigpond.co Guest
				 Posted: Wed Sep 27, 2017 2:43 am    Post subject: Canopy Protective Coating |
				Hello Group,
      Has anyone had success with removing the protective  coating on the canopy bubble other than with your thumb nail. Its easy where the  coating is thick but on the inside it is really thin and almost impossible to  get off.
  Cheers
  Steve Behn
  Lightning 69
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		n5pb(at)AOL.COM Guest
				 Posted: Wed Sep 27, 2017 8:36 am    Post subject: Canopy Protective Coating |
				Steve, I scrapped mine at the factory. they had a scraper which I believe was made out of Plexiglas and worked perfectly.  Check with Nick.
   He might be able to give you more info, since this was several years ago.
   Bear
				 Posted: Sun Oct 01, 2017 8:51 pm    Post subject: Canopy Protective Coating |
				Bear thanks for the suggestion I made up a plexi glass scraper out of a cut  off piece of the canopy, did get a few light scratches using it but was able to  polish them out with metal polish. It was a really slow and tedious job. I am  sure it was so because the film had been on the canopy for a long time and had  hardened on there.  If anyone has an older kit with the canopy still  protected I would remove it and reapply a new thick coat Aircraft Spruce seem to  have it.
  Steve
  Sent: Thursday, September 28, 2017 2:34 AM
  To: lightning-list(at)matronics.com (lightning-list(at)matronics.com) ; nick(at)flylightning.net (nick(at)flylightning.net)
  Subject: Re: Canopy Protective  Coating
  Bear
  -----Original  Message-----
 To:  lightning-list <lightning-list(at)matronics.com>
 Sent: Wed, Sep 27, 2017  7:35 am
 Subject: Canopy Protective Coating
      Hello Group,
  Cheers
  Steve Behn
  Lightning  69
				 Posted: Mon Oct 02, 2017 5:31 am    Post subject: Canopy Protective Coating |
				Steve,
   glad you were able to get the film off.  As I recall, it did take me a little while too to scrape the film off the entire canopy.  I do think the canopy was relatively new and the film hadn't "hardened", but it was tedious.
   Continued luck with your build...
   Bear
   N82PB
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
