bryanmmartin
Posted: Fri Jul 14, 2006 3:18 pm Post subject: Sun Shade |
I have the tinted canopy on my plane. I have no trouble with night
flying in it. The tinting is not that dark, it's about like the
windshield tint on most cars. It probably helps reduce the insolation
during daylight but it still gets plenty hot in there with the canopy
down and no shade.
Quote: |
<randy(at)shadycreekoutlaws.com>
What about the tinted canopies some people use on the XL's...? Do
you think there'd be the same issue? I'm debating this in the back
of my mind, now, for when the time comes...
Randy
XL Wings - Plans Only
http://www.n344rb.com
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Posted: Fri Jul 14, 2006 8:43 pm Post subject: Sun Shade |
Hi Randy,
I am afraid you suffer from a little misunderstanding. Light Sport
Aircraft can fly at night or IFR if properly equiped. It is Sport
Pilots or others limited to Sport Pilot privileges due to lack of a
medical certificate that are limited to VFR day operations.
Paul
XL fuselage.
At 01:14 PM 7/14/2006, you wrote:
Quote: |
Randy,
If you are building your XL in compliance with the Light Sport
Plane criteria, you cannot fly at night so a tinted canopy would be
the way to go. That's the way I am going but I don't think a tinted
canopy is going to keep the heat out as much as a shade so I plan
to have both. I agree with the member who says it's better to use
the Van's sliding shade rather that the suction cup type for the
same reasons he stated.
Bob Stone, Harker Heights, Tx
Building an XL
Do not Archive
Posted: Fri Jul 14, 2006 8:57 pm Post subject: Sun Shade |
Hi Jim,
It seems you and the other guys are all correct about the night and
IFR issue. Apparently it all depends on what type of airworthiness
certificate you have. As a bunch of airplane builders, I think those
of us who frequent this list are most likely to wind up with E-AB or
E-LSA certificates. In that case, the FAR equipment and
certification requirements will rule.
If I remember it all correctly, for night flight a plane must have
operating position lights and (at least according to one inspector I
spoke to) anti-collision strobes. For IFR, you need a reasonably
full panel including some assortment of radio equipment and you need
your pressure instrument system certified every two years.
I guess it makes sense that S-LSA airplanes would have a different
set of rules. It also seems to make sense that the POH is a medium
for the manufacturer to limit his planes beyond the limits placed by
the government. I don't see what the manufacturer can do to you if
you fly your properly equipped S-LSA plane at night except for
possibly limiting his liability should you get squashed flat. I
don't think the FAA would enforce such limits that go beyond the FARs.
Best regards,
Paul
XL fuselage
At 03:26 PM 7/14/2006, you wrote:
Quote: | However, if a manufacturer wants to limit his SLSA aircraft's
legal performance envelope in any way to limit his post-production
liability, he can do so through the POH. Let the buyer beware. You should
not purchase an SLSA without first reading the POH from cover to cover. For
an ELSA, the POH, I believe, is produced by the builder, you, and it is up
to you what you put into the POH.
COMMENTS?
jpellien
Joined: 24 Jun 2006 Posts: 21 Location: Basye, Virginia
Posted: Sat Jul 15, 2006 7:48 am Post subject: Sun Shade |
Paul,
Yes. It all comes down to liability in case something goes wrong and the
lawyers get involved.
Jim
Jim Pellien
Mid-Atlantic Sports Planes
Sky Bryce Airport (VG18)
Basye, VA
www.MASPL.com
703-313-4818
_________________ Jim Pellien
703-313-4818
703-851-9375
www.MASPL.com
"Learn-2-Fly-in-1-Week" |
Tebenkof(at)aol.com Guest
Posted: Sat Jul 15, 2006 7:33 pm Post subject: Sun Shade |
One consideration I have not seen mentioned in the debate about night flight with a Rotax: The FAA may or may not care, in an experimental amateur built aircraft, whether Rotax gives you permission to fly at night with their engine. But it seems to me your insurance company might, in case you care about such things. I bend my airplane in an engine-out night landing and I would expect the insurance company to point out to me that Rotax says no night flight, and they (the insurance company) would say "tough luck". Maybe this is not right. Any thoughts?
Jim Greenough
bryanmmartin
Posted: Sat Jul 15, 2006 8:34 pm Post subject: Sun Shade |
It doesn't make any difference what Rotax says, what matters is what the insurance policy says. If you didn't change the configuration of the plane since the policy was written and the company didn't specifically exclude night flight in that configuration, they are bound by the terms of the contract. They may nit-pick the hell out of every detail of the policy, but they can't change it after the fact.
Remember, this advice is worth every penny you paid for it.
On Jul 15, 2006, at 11:08 PM, Tebenkof(at)aol.com (Tebenkof(at)aol.com) wrote:
Quote: | One consideration I have not seen mentioned in the debate about night flight with a Rotax: The FAA may or may not care, in an experimental amateur built aircraft, whether Rotax gives you permission to fly at night with their engine. But it seems to me your insurance company might, in case you care about such things. I bend my airplane in an engine-out night landing and I would expect the insurance company to point out to me that Rotax says no night flight, and they (the insurance company) would say "tough luck". Maybe this is not right. Any thoughts?
Jim Greenough
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
