		rene(at)felker.com Guest
				 Posted: Fri Nov 24, 2017 8:44 am    Post subject: Ice prevention on fuel vent |
				No expert here….if you do encounter icing check out the fuel tank drain when you get on the ground.  I do not remember seeing any on the vent tube, was not looking, just noted a large chunk on the fuel drain.
 Rene'
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
 Sent: Friday, November 24, 2017 9:29 AM
 Subject: RE: Re: Ice prevention on fuel vent
 By the way, Tim and all the experts in this forum
 If the conditions create ice in the tip of the tube (which is in the air stream), why does it nor create ice inside the wing cavity as well?
 Is it because the ice is created not only by the air temperature, but also by the positive dynamic pressure in the vent tube tip?
 Wondering minds want to know …
 Carlos
 De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de Tim Olson
 Enviada: Friday, November 24, 2017 1:02 PM
 Para: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
 Assunto: Re: Re: Ice prevention on fuel vent
 I should have read again before replying... darn.
 That check valve will work fine, as would any free flow valve, but, the other down side is your fuel vents are 1/4” tubing and that particular valve uses 3/8” fittings, so you will need to buy additional adapters to fit it in, which may require a little more creativity in mounting.  At $27.50 it isn’t super cheap either but looks like good quality. I don’t remember what I paid, but it would be worth checking out what other valves you can find because if you can find one that is 1/8” NPT it may be easier to adapt.  That said, mine is brass and is probably heavier than this one is too.
 On Nov 24, 2017, at 3:53 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
 In the Q+A for this ACS valve, at the Aircraft Spruce website, it says that this valve breakout pressure is 0 psi.
 Will this work for this application?
 Carlos
 Enviado do meu iPhone
 No dia 24/11/2017, às 05:12, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> escreveu:
 Regarding that check valve...I just got around to looking at the link on this
 Aircraft Spruce one, Phil.
 I know you want one with a very very very low operating pressure (vacuum, actually).
 If you get even a couple of psi that it takes to open the valve, your tank will
 have probably imploded by then.   This valve appears to be for fuel flow
 return lines.  It doesn't seem to give a spec.
 I got a valve from McMaster Carr that had a cracking pressure of .3 psi.
 http://www.myrv10.com/N104CD/upgrades/20090525/index.html
 I can't say that the valve you linked to is bad, but I would just caution to
 make sure that it's probably no more than 1psi of cracking pressure.
 Any valve that takes more than that to operate may risk tank
 collapse.
 On 11/23/2017 7:20 AM, Phillip Perry wrote:
		Tim Olson
				 Posted: Fri Nov 24, 2017 8:56 am    Post subject: Ice prevention on fuel vent |
				That's an easy one.  The ice comes from direct contact with the
 moisture in the air, not just because it's cold out.  There
 may be bits of liquid that DO get in the wing cavity during
 flight, if you're in actual liquid rain, and those could freeze,
 but it's unlikely that anything significant would get thru the
 cracks if you're just talking cloud vapor.
 With supercooled water, it will freeze on contact and my guess
 is that even if you hit that while flying, it would freeze before it
 would get significantly far into the wing cavity, maybe even
 sealing the cracks it flows into.
 But, all of the icing is from moisture, not air temp.
 On 11/24/2017 10:28 AM, Carlos Trigo wrote:
  	  | Quote: | 	 		   By the way, Tim and all the experts in this forum
  Carlos
  *De:*owner-rv10-list-server(at)matronics.com
  [mailto:owner-rv10-list-server(at)matronics.com] *Em nome de *Tim Olson
  *Enviada:* Friday, November 24, 2017 1:02 PM
  *Para:* rv10-list(at)matronics.com
  *Assunto:* Re: Re: Ice prevention on fuel vent
  <mailto:trigo(at)mail.telepac.pt>> wrote:
      Carlos
      <mailto:Tim(at)MyRV10.com>> escreveu:
          link on this
          (vacuum, actually).
          your tank will
          fuel flow
          .3 psi.
          just caution to
          collapse.
              Here you go Dave..
              http://m.aircraftspruce.com/catalog/appages/acscheckvalve.php?clickkey=6903
              On Nov 23, 2017, at 3:57 AM, rvdave <rv610dave(at)gmail.com
              <mailto:rv610dave(at)gmail.com>> wrote:
                  <rv610dave(at)gmail.com <mailto:rv610dave(at)gmail.com>>
                  I’ve been looking for a check valve where can you get
                  one with low psi?
                  Dave Ford
                  RV6 for sale
                  RV10 building
                  Cadillac, MI
                  http://forums.matronics.com/viewtopic.php?p=475455#475455
                  <===========================sp; -->
                  htt==========================;           - MATRONI;
                  <http://www.matronics.com/Navigator?RV10-List>http://forums.matronics.com
                  http://wiki.matronics.com
                  ==========================bsp;        - List
                  Contribution Web S;                   -Matt Dralle, List
                  Admin.
		kearney
		gengrumpy
  Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
				 Posted: Fri Nov 24, 2017 6:08 pm    Post subject: Ice prevention on fuel vent |
				In addition to the Van’s recommended small hole drilled on the back side of the line just above the end of the vent line, why not drill the same diameter hole in the tubing underneath the wing fairing, giving a second possible relief should the vent tube opening get plugged??
 grumpy 	  | Quote: | 	 		  On Nov 24, 2017, at 7:02 AM, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> wrote:
  	  | Quote: | 	 		  Tim
 CarlosEnviado do meu iPhone
  	  | Quote: | 	 		                     Regarding that check valve...I just got       around to looking at the link on this       Aircraft Spruce one, Phil.              I know you want one with a very very very low operating pressure       (vacuum, actually).       If you get even a couple of psi that it takes to open the valve,       your tank will       have probably imploded by then.   This valve appears to be for       fuel flow       return lines.  It doesn't seem to give a spec.               I got a valve from McMaster Carr that had a cracking pressure of       .3 psi.              http://www.myrv10.com/N104CD/upgrades/20090525/index.html              I can't say that the valve you linked to is bad, but I would just       caution to        make sure that it's probably no more than 1psi of cracking       pressure.       Any valve that takes more than that to operate may risk tank       collapse.              Tim                     On 11/23/2017 7:20 AM, Phillip Perry wrote:
		parish(at)parishmoffitt.c Guest
				 Posted: Sat Nov 25, 2017 4:56 am    Post subject: Ice prevention on fuel vent |
				Anything sticking out into  the airflow will accumulate ice when in “icing conditions” and “icing conditions” can occur at a temperature higher than you would think. On airplanes that fly in the ice all the time, one of the common ways we evaluate the severity is to look for something small sticking out into the airstream (like the safety wire on the windshield wipers).
 Parish
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene
 Sent: Friday, November 24, 2017 11:43 AM
 Rene'
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Carlos Trigo
 Carlos
 Carlos
 collapse.
