dfritz(at)bpgsim.com Guest
Posted: Wed Jan 03, 2018 2:53 pm Post subject: Canopy Trimming |
What tool are people using to cut the window openings? The curves are
too tight for a cutoff wheel and an oscillating tool works great for
straight cuts but does not want to cut the curves either.
David Fritzsche
rene(at)felker.com Guest
Posted: Wed Jan 03, 2018 3:10 pm Post subject: Canopy Trimming |
I used a combination of the cutoff wheel and small (1") sanding drum on my high speed drill. For smaller holes I used the same types of tools with my Dremel.
Rene'
801-721-6080
Kellym
Joined: 10 Jan 2006 Posts: 1704 Location: Sun Lakes AZ
Posted: Wed Jan 03, 2018 4:13 pm Post subject: Canopy Trimming |
Yes, you can get 1 or 2" cut off wheels for the Dremel. The sanding
drums are good for the final 1/8-1/16" you need to smooth out.
On 1/3/2018 4:09 PM, Rene wrote:
Rene'
801-721-6080
KCHD |
Posted: Wed Jan 03, 2018 8:24 pm Post subject: Canopy Trimming |
The best thing I found was the cutoff wheel, then substituting a jigsaw with
a fiberglass cutting blade for the curves.
maca2790
Posted: Wed Jan 03, 2018 9:09 pm Post subject: Canopy Trimming |
I used the half moon vibrating cutter to do most of the cuts. Just the corner of it like a blade. Then I used a power file in the tight radius bends.
Cheers John MacCallum
RV10
VH DUU
Rene'
801-721-6080
Rocketman1988
