Left inside main Gear Door
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
skyking76t(at)verizon.net
PostPosted: Sun Jan 07, 2018 5:17 pm    Post subject: Left inside main Gear Door Reply with quote
Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale? This is the door attached to the fuselage. No corrosion or damage. Just need door only
Tony
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
taylor527(at)att.net
PostPosted: Sun Jan 07, 2018 5:39 pm    Post subject: Left inside main Gear Door Reply with quote
Hi Tony,I have new or used,new has to be drilled and fitted
Pete
On Jan 7, 2018, at 5:17 PM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
Tony
Dawg
PostPosted: Sun Jan 07, 2018 6:48 pm    Post subject: Left inside main Gear Door Reply with quote
Why?
On Jan 7, 2018, at 18:37, Taylor <taylor527(at)att.net (taylor527(at)att.net)> wrote:
PeteSent from my iPad
Tony
Dawg
PostPosted: Sun Jan 07, 2018 6:55 pm    Post subject: Left inside main Gear Door Reply with quote
Bottom of door corroded off up about one inch and broke off. Skin, reinforcement, and c-channel support. Could probably fix but may be cheaper to buy a door by the time I buy everything plus time. Right side was repaired, I assume by the military, by cutting the corner off and patching but the underlying [parts were still good.
On Sunday, January 7, 2018 9:50 PM, William Geipel <l129bs(at)gmail.com> wrote:
Why?
Tony
Dawg
PostPosted: Sun Jan 07, 2018 6:58 pm    Post subject: Left inside main Gear Door Reply with quote
do we need to drill drain holes on the bottom?
On Jan 7, 2018, at 19:55, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Sunday, January 7, 2018 9:50 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
Why?
Tony
Dawg
PostPosted: Sun Jan 07, 2018 7:24 pm    Post subject: Left inside main Gear Door Reply with quote
No way to do that. On the very bottom tip of the gear door, just below the jack pad, you have the outer skin, behind the skin is a flat reinforcement plate, and a c-channel backer. The c-channel was fine but the skin itself looked like when magnesium corrodes. It just fell apart when I touched it. The plane stays in a hangar too and the door has good paint on it.. The reinforcement was almost in as bad a shape. The skin is riveted to the reinforcement and the reinforcement rivet holes had cracked thru. I cut out the bad skin but would have to do a lot of small rivets to attach a new patch and probably have to look at some type of automotive panel adhesive to help attach the patch to what's left of the reinforcement plate.....paper thin. Be much easier and probably cheaper to install and fit a new or used door. If it was just the outer skin,like on the right gear door, the repair would be a breeze.
I believe this is the end that gets hit when you pull the jack out if not careful. I've never hit it though.
On Sunday, January 7, 2018 9:59 PM, William Geipel <l129bs(at)gmail.com> wrote:
Why?
Tony
N777ZE
PostPosted: Tue Jan 09, 2018 3:21 pm    Post subject: Re: Left inside main Gear Door Reply with quote
I might have one in my basement, see attached photos Might be willing to trade for other spare parts or $$
 Filesize:  1.88 MB
 Viewed:  12734 Time(s)
 Filesize:  1.61 MB
PostPosted: Tue Jan 09, 2018 3:29 pm    Post subject: Left inside main Gear Door Reply with quote
Thanks Josh for responding. Already have one coming from another owner but appreciate it all the same.
On Tuesday, January 9, 2018 6:23 PM, N777ZE <Piper72pilot(at)hotmail.com> wrote:
--> L29-List message posted by: "N777ZE" <Piper72pilot(at)hotmail.com (Piper72pilot(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=477202#477202
http://forums.matronics.com//files/21c78bfc_708c_49ce_8ec8_13f549b6619a_169.jpeg
http://forums.matronics.com//files/e2867b42_d78b_4681_bfe3_f0a522806cfa_173.jpeg
http://w   -Matt Dralle, List Admin.
t="_blank">http://www.matronics.com/contribution
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
