Steve Geard
Posted: Wed Jan 17, 2018 2:34 pm Post subject: M14p, prop shaft oil leak. |
Can anyone help with front prop shaft seal on my M14p please.
During gyroscopic maneuvers my YAK55m is spewing oil everywhere.
We have replaced pretty much every O ring and gasket on the engine, the oil looks to be coming from the propshaft exit on the front of engine.
I have an engineer who has a suitable tool for refitting the shaft and seal.
We are about to take the prop/hub off, and remove the gearbox.
It’s my understanding the gearbox has to be disassembled to gain access to the front bearing and seal.
What else should we look to replace or service whilst we have it all apart.
Plus who can supply the seal, and is it prudent to replace the bearings as well ?
_________________ SteveO |
heaysr(at)telus.net Guest
Posted: Wed Jan 17, 2018 7:43 pm Post subject: M14p, prop shaft oil leak. |
Have experienced the same thing a few years ago.
Do as you said. Remove the prop. Remove the gear case. Ship the gear case to Jill at M-14P.com. They have the nose case prop shaft seals in stock and will remove the oil seal and install an new seal all in good time.
And your oil leak problem will be solved.
Royden
Yak 55M
C-GRED
richard.goode(at)russiana Guest
Posted: Wed Jan 17, 2018 8:10 pm Post subject: M14p, prop shaft oil leak. |
But, quite expensive to ship an entire gearbox to and from New Zealand!
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
