		whodja
  Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
				 Posted: Tue Jan 30, 2018 4:13 am    Post subject: IO-540 alternator-starter bracket |
				Does anyone know who sells the bracket for a boss mount from alternator
 to starter bracket? I have a B and C alternator and OEM Lycoming/Skytec starter.
		LarryRosen
				 Posted: Tue Jan 30, 2018 6:54 am    Post subject: IO-540 alternator-starter bracket |
				Did you try B&C?
  Get Outlook for iOS
   From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of whodja <whodja(at)gmail.com>
  Sent: Tuesday, January 30, 2018 7:13:19 AM
  Subject: IO-540 alternator-starter bracket
   --> RV10-List message posted by: "whodja" <whodja(at)gmail.com>
  http://forums.matronics.com/viewtopic.php?p=477689#477689
   Email Forum -
  -List">http://www.matronics.com/Navigator?RV10-List
  p;   - MATRONICS WEB FORUMS -
  ums.matronics.com
  p;  - NEW MATRONICS LIST WIKI -
  matronics.com
  p;                  -Matt Dralle, List Admin.
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		tshort
				 Posted: Wed Jan 31, 2018 12:00 am    Post subject: Re: IO-540 alternator-starter bracket |
				So far as I know no one makes one.
 I have a plane power 60A alternator and a B&C starter.
 The install instructions for the starter state that no bracket is needed if a B&C alternator (or any alternator that is perfectly balanced) is installed.  [My summary, I don't have the instructions in front of me]
 I'm still in the process of installing things, but am seriously considering not installing a bracket.  I called B&C, and was told that the bracket would provide extra support / vibration dampening and might extend the life of the PP alternator.
 Seeing as how it's not installed with the B&C alt/starter combo, I may just go without...
 Edit ....
 I just reread your post.  Looks like you have the opposite combo as I do.  I might call B&C (or check the install manual) - the bracket may not be necessary based on the install instructions I have for the starter.  I don't see that bracket called out in the wide deck install instructions for the B&C alternator.
		Kelly McMullen
				 Posted: Wed Jan 31, 2018 5:31 am    Post subject: IO-540 alternator-starter bracket |
				Have you talked to Plane Power? This is what is normally in their experimental kit:
 http://planepower.aero/images/AL12-EI60-B.jpg
 They offer both case mount and boss mount kits with all brackets. Is the bracket you need of differing dimensions than a stock
 alternator and starter combo? I used the stock PP kit with a Kelly (now Hartzell) EZ Drive starter with no problem.
  	  | Quote: | 	 		  | Sent from my IBM-360 main frame |
 On Tue, Jan 30, 2018 at 5:13 AM, whodja <whodja(at)gmail.com (whodja(at)gmail.com)> wrote:
  	  | Quote: | 	 		  --> RV10-List message posted by: "whodja" <whodja(at)gmail.com (whodja(at)gmail.com)>
   FORUMS -
  WIKI -
  b Site -
A&P/IA, EAA Tech Counselor
KCHD |
