saddle tank?
pmdental(at)btinternet.co
PostPosted: Sat Mar 17, 2018 1:58 am    Post subject: saddle tank? Reply with quote
Hi everyone, Anyone out there know the approx’ volume of the 2 saddle areas
in the std Europa 62 litre polypropylene tank . That is,- when the fuel is down
to the bridge area. I am trying to understand & calibrate my fuel useage & reserve.
Thanks Paul Munford Europa NG kit 625
Burrilla
PostPosted: Sat Mar 17, 2018 2:12 am    Post subject: saddle tank? Reply with quote
I measured mine while reviewing the calibration of the sight gauge and approximated it at about 9 to 10 litres per saddle while sat on the ground with no turbulence.
In the air could be much less especially if been bounced around or doing unbalanced turns.
Alan
Sent from my iPad
On 17 Mar 2018, at 09:56, Paul Munford <pmdental(at)btinternet.com (pmdental(at)btinternet.com)> wrote:
davidjoyce(at)doctors.org
PostPosted: Sat Mar 17, 2018 2:22 am    Post subject: saddle tank? Reply with quote
I measured mine at very close to 10 litres and that should hold good in the air in roughly level flight as the return line empties into the reserve side keeping it constantly topped up in spite of turbulence. At least it should do, if you have got your plumbing right - ref the directive and other info relating to the GBYSA disaster last year.
Regards, David Joyce, GXSDJ
Alan Sent from my iPad
Hi everyone, Anyone out there know the approx' volume of the 2 saddle areas
ward.t(at)xtra.co.nz
PostPosted: Sat Mar 17, 2018 5:26 am    Post subject: saddle tank? Reply with quote
Hi Paul,9.5 litres either side I work on.
Tim Ward12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Mob +64 210640221
On 17/03/2018, at 6:56 AM, Paul Munford <pmdental(at)btinternet.com (pmdental(at)btinternet.com)> wrote:
PostPosted: Sat Mar 17, 2018 8:25 am    Post subject: saddle tank? Reply with quote
Thanks for such a speedy reply to my query !
Just to be sure, is that 9-10 litres for each side ?
or total for both sides?
Sorry to be a nuisance but I want to be sure.
Thanks again Paul Munford Europa NG kit 625
Sent: Saturday, March 17, 2018 1:23 PM
Subject: Re: saddle tank?
Hi Paul, 9.5 litres either side I work on.
Tim Ward 12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
Burrilla
PostPosted: Sat Mar 17, 2018 9:11 am    Post subject: saddle tank? Reply with quote
Per Saddle i.e. each side is approx 9 -10 litre
Alan
On 17 Mar 2018, at 16:23, Paul Munford <pmdental(at)btinternet.com (pmdental(at)btinternet.com)> wrote:
Tim Tim Ward 12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
PostPosted: Sat Mar 17, 2018 10:00 am    Post subject: saddle tank? Reply with quote
Paul, yes 10 litres each side, but of course one side forms part of the main tank and your fuel gauge is likely to not read empty until you have finished the 10 litres in that side's saddle tank. Regards, David Joyce, GXSDJ
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
PostPosted: Sat Mar 17, 2018 11:58 am    Post subject: saddle tank? Reply with quote
Fully explained,fully understood.
Thanks for your help
Paul Munford G-OVPM
Sent: Saturday, March 17, 2018 5:58 PM
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
