		duanefamly(at)aol.com Guest
				 Posted: Thu May 31, 2018 2:37 pm    Post subject: Fuel Management |
				After only a short time after first flight I am disappointed with the fuel sight gauge down by my right foot. During flight it is difficult to see the level and when I can visualize the level, I don’t seem to trust the reading……and since I have conventional gear setup, it does not read correctly on the ground either.
 So comes the question, what are the rest of the Europa flyers using for fuel management? I have heard of fuel totalizers in some aircraft and of some builders installing fuel senders into the top of the tanks. Was wondering the pros and cons of each from the people that have already done it?
 Mike Duane
 Europa XS conventional gear
 N377EA
 Las Vegas, NV
 Sent from Windows Mail
		graeme bird
				 Posted: Thu May 31, 2018 10:44 pm    Post subject: Re: Fuel Management |
				My conclusion was the same and I went on a journey with this whole thing:
 First I moved the pipe to come up between the seats; this has proved useful for seeing how much fuel I have when in the hangar before I fly although sometimes an air bubble in it and fuel in the vent for the pipe means the reading is misleading. Its affected by where the plane is parked - inclination so I check it at the same place in the hangar. Occasionally I have used it to second check in flight but when the fuel is low (below 18ltrs), its hard to see.
 Then I installed a capacitive sensor in the tank with a gauge. This is kind of useful as a second check and reliable but the scale is way off due to the tank shape. Its also hard to get a good seal on the sender flange. I keep meaning to add a lineariser circuit on it.
 Then I have a differential totaliser (EI 5PL or something); this has been great and a pretty reliable indication of state,  flow, mpg economy etc (so long as fuel added is entered correctly). I tend to fill to the brim regularly to be absolutely sure of state.
 So with the three indicators I got to a reasonable level of confidence. Not sure i'd want to be without any of them now. I suppose the pipe is similar to dipping the tank.
  _________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
		tennant
				 Posted: Fri Jun 01, 2018 5:46 am    Post subject: Re: Fuel Management |
				Hi Mike,
 I have been using a fuel totaliser for over 20 years. I have an old fashioned 912UL so I fitted it after the tank return. It took a while to calibrate but is spot on and I would not want to be without it. No guesswork means you can extend your effective range.
 I originally fitted the sight gauge but took it out after a few years as it was unreliable and I did not Need it anyway.
 Barry
  _________________ Barry Tennant
D-EHBT
At EDLM  -  Germany |
		AirEupora
				 Posted: Fri Jun 01, 2018 7:25 am    Post subject: Re: Fuel Management |
				Hi mike, glad to see your building time.
 I have Bud Yerly's  pipe down the side of the seat.  It works great, but I've gotten to fat and it's hard to see in flight, but I have mirror so I can see it.
 I also have the MGL Voyager with a Calc tank that uses the Red Cube.  After about five flights I have it dialed in the +/- .2 gallon.  Sundays flight was Calc 9.4 actual was 9.17, but I could have put more fuel after it settled, but I had turn the pump off.
 I also never fly over 2.3 hours on a tank.  It's a little scary when the engine quits and you have to switch to the reverse tank.  Been there, none that.  I want an airport off my wing when I do that.  There is suppose to be 2 1/2 gallons in  that side of the tank, but it seems on fill-up that there is less than that.
 Rick Stockton
 N120EJ, Jabiru 3300L
 189 hours
				 Posted: Fri Jun 01, 2018 8:32 am    Post subject: Fuel Management |
				Just out of interest I have seen a pipstrelle here which has one red cube on the feed line to one of the Carbs.  The owner told me that he simple doubles the consumption.
 Has anyone seen this elsewhere?
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Fri, Jun 1, 2018 at 10:25 AM, AirEupora <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)> wrote:
  	  | Quote: | 	 		  --> Europa-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
  Rick Stockton
  189 hours
  http://forums.matronics.com/viewtopic.php?p=480558#480558
   FORUMS -
  WIKI -
  b Site -
            -Matt Dralle, List Admin.
		cakeykev(at)gmail.com Guest
				 Posted: Fri Jun 01, 2018 10:49 am    Post subject: Fuel Management |
				I have a flow sender after the return line. It works well a bit of adjusting the values to start with but once it’s set correctly very accurate. Gives great piece of mind unless you are very unlucky and get a leaking tank.
 Kevin Challis
 On 1 Jun 2018, at 17:32, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Just out of interest I have seen a pipstrelle here which has one red cube on the feed line to one of the Carbs.  The owner told me that he simple doubles the consumption.
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
  Rick Stockton
  189 hours
   FORUMS -
  WIKI -
  b Site -
		erichdtrombley(at)juno.co Guest
				 Posted: Sat Jun 02, 2018 8:19 am    Post subject: Fuel Management |
				Mike,
 I have a single Floscan Series 200 flow meter which is incredibly accurate (typically within a tenth of a gallon). It is connected downstream of the fuel selector valve.  I also have a fuel pressure/head sensor (thank you Jim Butcher) mounted adjacent to the flow meter, and while not as accurate, it does provide a good representation of whats actually in the tank.  Both units are tied into my Dynon Skyview which performs a cross check comparison between the two which is really nice.
 I just recently disconnected the original sight gauge as I was never comfortable with fuel in the cabin, and during the last annual inspection noted some fuel staining on the carpet by the footwell.
 Good luck with the remained of your Phase I flight testing.  Let me know if I can help out.
 Erich Trombley
 N28ET Classic Mono 914
 1 Cup Of This (Tonight) Will Burn Your Belly Fat Like Crazy
 Wise Med
 http://thirdpartyoffers.juno.com/TGL3131/5b12c3437b1514343694cst04vuc
		DuaneFamly(at)aol.com Guest
				 Posted: Sat Jun 02, 2018 10:19 am    Post subject: Fuel Management |
				Thanks Eric,
 I’ll look at theFlowscan during my research.
 Mike
  	  | Quote: | 	 		   On Jun 2, 2018, at 9:18 AM, Erich Trombley <erichdtrombley(at)juno.com> wrote:
  Mike,
  Erich Trombley
  Wise Med
		h&jeuropa
				 Posted: Sat Jun 02, 2018 12:23 pm    Post subject: Re: Fuel Management |
				Mike,
 We have a sight gauge behind the seat, actually on the face of the baggage bay.  It is calibrated for the tail down configuration and is used when filling the tank.
 We have a pair of flow transducers, one for flow into engine and one for return flow that display on our GRT EFIS (GRT requires 2 transducers for a 914 setup).  We have a pressure sensor at the bottom of the tank that gives independent fuel quantity reading.  That sensor is calibrated with the plane in level flight attitude.  This setup is like Erich’s except he has just one transducer.
 We have connected the two tank outlets together to simplify fuel management.  With 914 there is roughly 40 gph being returned to the tank.  Knowing how much is in the reserve side and when to switch and not leave unusable fuel in the reserve can be difficult.  Tied together there is no question.
 We check after flight that the fuel remaining from level flight gauge and flow transducer agrees with what the sight gauge shows when back in the hangar.  That’s a way to have confidence in the gauging and to verify no leaks.
 We think most people do not use the foot sight gauge as it is hard to read, not accurate because of distance from the tank and there are safety concerns with a fuel hose running thru the cockpit.
 We tried a capacitance gauge originally but different fuels 100LL vs MOGAS will indicate differently.
 With only using 5-6 gph, measuring fuel remaining accurately is important.  A 1 gal error is 20 minutes flying.
 Get in touch with Erich.  He’s done a lot of novel things to his Europa.
 Jim & Heather
		budyerly(at)msn.com Guest
				 Posted: Sun Jun 03, 2018 6:21 am    Post subject: Fuel Management |
				I couldn’t agree more with your comments on the EI 5 fuel totalizer with differential module.
 I have a sight gauge as depicted on my website.
 I have had a capacitance gauge from GRT / Princeton
 I have the EI 5 fuel totalizer.
 Painfully, I calibrated my tank (marks on the tank, sight gauge, and a capacitance sender.
 Capacitance:   If I change fuel from AV Gas to Premium Auto, it read in error.  I have marks on the outside of my probe for calibration so I could bench check it, it reads different based on ethanol content, or none, MOGAS or AV Gas as  bench checked and in the aircraft.  What a pain.  If there is too much ethanol (10%) or water it kills my capacitance probe.  I replaced it, now it is intermittent and I again in frustration I pulled it and plugged the hole in the tank top with a bolt.  Great  trend indicator when it worked, I either had gas or not, and nothing accurate in between beyond the first fuel type change.  Bad luck I suppose.   The Europa resistance gauge is fairly accurate as it is designed for the tank shape, but again, is a trend indicator  and not able to be calibrated by the builder.
 My sight gauge has been re-plumbed to prevent fuel trapping as my vent side of the gauge resides in between the tank and the fiberglass module top.  If a bit of fuel trapped in that vent side doesn’t drain down, it moves my gauge by the  size of the trapped fuel.  Now with my slight gauge re-plumb,  it runs almost completely down hill and is damned adequate.  However, I still have to open the cap, blow in the vent  nipple, and then the gauge is accurate after every fill.  I now run the plumbing  completely down hill and fuel trapping is still possible during steep climbs and won’t clear until back to level flight for a while.
 The EI FP5 I own was calibrated out of the box.  I have two flow scans for the 914, one on feed and the other on return.  If I put 15 gallons in the tank, the EI reads zero as the pumps cavitate.
 In my building experience, I followed convention on using one fuel cube/flow scan for the Jabiru or Rotax 912 series.  Since the Jab has no return it is fairly accurate and of course the return, which is unmetered in the Rotax 912 series,  is an estimate on fuel at best.  It does give a total which is lower than actual, which is OK, I guess.
 A couple of years ago we did do a return on the Rotax 912 (80 HP) on Creighton Smiths aircraft and it has proven quite reliable.  His unit was a Flight Data Systems  unit called the FC 10 with dual fuel flows (red cubes).  It worked very  well even with the very low fuel flows of the 912.  I had never heard of Flight Data Systems and the unit is a bit on the cheap looking side, but it works well for less than my EI 5FPL with differential module.
 For those with the GRT EIS engine monitor, it can be rewired to allow two red cubes or flow scans if not purchased with fuel flow in mind.  It is also adjustable but time consuming to get dead on unless you let the factory set it.  Dynon  I understand is using the red cube and my RV friends seem to like it on the O-320.  The LSA guys with only one cube are not impressed with the accuracy on the 912S and those with two report it is OK, but not able to calibrate it for some reason.  I never researched  it.
 Bottom line,
 I have had four fuel quantity determining possibilities:
 My watch ( I have 3 hours at low cruise ((4.5/hr)) and 2.5  at high cruise (5.5/hr))
 My sight gauge.
 My EI fuel flow, and time until empty based on the amount I put in and input.
 My now defunct capacitance panel gauge (which was just replaced with dual EGT) has been hit or miss.
 I am the department of redundant redundancy on fuel and have found the most accurate fuel device is my fuel flow and a watch.
 Bud Yerly
 Sent from  Mail for Windows 10
   From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of graeme bird <graeme(at)gdbmk.co.uk>
  Sent: Friday, June 1, 2018 2:44:54 AM
  Subject: Re: Fuel Management
   --> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk>
  First I moved the pipe to come up between the seats; this has proved useful for seeing how much fuel I have when in the hangar before I fly although sometimes an air bubble in the and fuel in the vent for the pipe means the reading is misleading. Its affected  by where the plane is parked - inclination so I check it at the same place in the hangar. Occasionally I have used it to second check in flight. When the fuel is low (below 18ltrs), its hard to see.
  Then I have a differential totaliser (EI 5PL or something); this has been great and a pretty reliable indication of state,  flow economy etc (so long as fuel added is entered correctly). I tend to fill to the brim regularly to be absolutely sure of state.
  Graeme Bird
  G-UMPY -  Mono Classic/XS FFW 912S, Woodcomp 3000/3W CS, trutrak Gemini 2 axis AP, PAW, PFLARM core, ads-b out, 8.33khz, mode S, FP-5, Aera500, SD on Nexus, SmartA3
  325 hours & 6 years on the Mono, 930 total
  g(at)gdbmk.co.uk
  https://nam01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D480546%23480546&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=KDQyvIk2y1QfYfDSHuotqfvcVJq9GFbm9oJZAV87ZsU%3D&reserved=0
  st Email Forum -
  ook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=9g3BbD4C5ryxDfiV%2Fivn3M7L8GK0EyH4SUGZl77ItlY%3D&reserved=0"> https://nam01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=9g3BbD4C5ryxDfiV%2Fivn3M7L8GK0EyH4SUGZl77ItlY%3D&reserved=0
  p;   - MATRONICS WEB FORUMS -
  ook.com/?url=http%3A%2F%2Fforums.matronics.com&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=v9569lrTiTLhZzcxwFHEsEyLZlBIQDr837j2DyEQ7ic%3D&reserved=0"> https://nam01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=v9569lrTiTLhZzcxwFHEsEyLZlBIQDr837j2DyEQ7ic%3D&reserved=0
  p;  - NEW MATRONICS LIST WIKI -
  ook.com/?url=http%3A%2F%2Fwiki.matronics.com&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=3SZej1AioLVaB4V7phJEdNy1aYiOK03IJuSUPmqQXW0%3D&reserved=0"> https://nam01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.matronics.com&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=3SZej1AioLVaB4V7phJEdNy1aYiOK03IJuSUPmqQXW0%3D&reserved=0
  p;                  -Matt Dralle, List Admin.
  ook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=AMLOQDkXtGKo4WVYnV0FN04gaUtnsBrOELc9TIg1IZ4%3D&reserved=0"> https://nam01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7C81e9b4e0005b492422cf08d5c78ba9a4%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636634325008274906&sdata=AMLOQDkXtGKo4WVYnV0FN04gaUtnsBrOELc9TIg1IZ4%3D&reserved=0
		m.j.gregory(at)talk21.com Guest
				 Posted: Tue Jun 05, 2018 3:11 am    Post subject: Fuel Management |
				Kevin,
 A cautionary tale: you do not need a leaking tank to lose fuel unexpectedly en route.  My friend completed his pre-flight checks just before we set off for a 30-minute hop, but on arrival someone spotted we were leaving a trail of fuel as we taxied in.  We had lost about 20 litres in that short time because the drain valve had not properly re-seated after the check. Had it happened the next day, we should have run out of fuel over the middle of Spain if we had not had an alternative gauge to warn that the totaliser was no longer showing what was in the tank, and given us a chance to land before it all went quiet.
 Of course, the saddle in the Europa tank means that the engine will cough while you still have 9 litres or so in the reserve side, but a means of cross-checking the totaliser would provide more warning of the impending trouble as well as alerting you to the leak – otherwise the initial reaction might be to assume a blocked filter was causing starvation and you still had fuel above the saddle that would feed the reserve side.
 Best regards,
 Mike
 Dr Mike Gregory
 Europa Club safety officer
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Kevin Challis
 Sent: 01 June 2018 19:49
 Subject: Re: Re: Fuel Management
 Kevin Challis
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 Rick Stockton
 189 hours
		creightonious
				 Posted: Tue Jun 05, 2018 6:28 am    Post subject: Fuel management |
				I tried it with just the footwell lndicator.  Bubbles made it inaccurate.  I could purge it by horsing the airplane into a very steep zoom.  The bubbles could be seen climbing the gauge tube but in addition to the anxiety suffered by the passenger, it did not always completely purge the gauge system.
 So I put in a totalizer and 1 red cube thinking I could factor in the return amount.  I couldn’t.
 So in went another red cube in the return line and, hey presto, fuel added equals fuel used.  I have a straight 912 and a long ranger tank.  In a 24 gallon burn (indicated) the added fuel is within 0.3gallon less than indicated.  I consider this a safety margin and have no plans to mess with it.
 The footwell tube is useful for indicating the aircraft is fueled, but in the monowheel tail down stance it is not an accurate quantity gauge.  By the way, since the installation of the long ranger the bubble problem seems to have nearly disappeared.  Go figure.
 Creighton Smith   A-009
 Sent from my iPad
  	  | Quote: | 	 		   On Jun 4, 2018, at 2:34 AM, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
  Today's complete Europa-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the Europa-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-06-03&Archive=Europa
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-06-03&Archive=Europa
                            Europa-List Digest Archive
                      Total Messages Posted Sun 06/03/18: 5
  Today's Message Index:
      1. 07:21 AM - Re: Re: Fuel Management  (Bud Yerly)
      2. 08:02 AM - Re: Gurgling (burping)  (Bud Yerly)
      3. 09:09 AM - Static problem?  (h&jeuropa)
      4. 10:11 AM - Re: Static problem?  (Robert Borger)
      5. 11:46 AM - Re: Gurgling (burping)  (JonathanMilbank)
  ________________________________  Message 1  _____________________________________
  Time: 07:21:16 AM PST US
  Subject: RE: Re: Fuel Management
  I couldn=92t agree more with your comments on the EI 5 fuel totalizer with
  citance sender.
  f a bit of fuel trapped in that vent side doesn=92t drain down, it moves my
  fuel trapping is still possible during steep climbs and won=92t clear unti
  Bottom line,
  (5.5/hr))
  My sight gauge.
  t.
  Bud Yerly
  Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Window
  s 10
  to see.
  Graeme Bird
  Nexus, SmartA3
  g(at)gdbmk.co.uk
  served=0
  erved=0
  ________________________________  Message 2  _____________________________________
  Time: 08:02:34 AM PST US
  Subject: RE: Gurgling (burping)
  Jonathan,
  It is not uncommon for the oil level in the tank to drain down overnight.
  Even on a new engine.  The tank can drain into the crankcase two ways on a
  912UL (S).  If the tank is full, and the return line has oil in it, it siph
  ons down into the crankcase until the siphon is broken.  That is only a sma
  ll amount of oil on the dipstick.
  The other is through the feed line, through the oil cooler and into the oil
  pump.  The oil pump has tight clearances, but thin oil will drain quite ra
  pidly through the pump into the crankcase via the many feed passages.  You
  are right, it could be a seal in the oil pump was not changed on your rebui
  ld or the oil pump shaft has worn beyond limits (check service bulletin 912
  -032).  This internal seal leak doesn=92t show normally, until the oil pump
  case to pump seal begins to leak.  The case to oil pump is just sealed wit
  h 515.  This is an easy fix and all external and right up front for your me
  chanic.  So Look.
  On the other hand, you would have low oil pressure if your pressure relief
  spring/ball were stuck so I doubt that is a problem.
  Lastly, if you have a feed oil line leak at the tank, or internal in the pu
  mp, air is introduced into your feed line to the oil pump.  This prevents o
  il getting to the pump, but doesn=92t really affect the burp.  If your oil
  pressure comes up quickly and when you pull the plugs and spin the engine b
  y hand, you get oil pressure, that is not a factor.  That is a difficult is
  sue to trace.  The only way to check is try using light air pressure on the
  oil tank overflow / vent line and remove listen for the oil moving or remo
  ve the oil feed at the pump and check for air. I really doubt that is a pro
  blem.
  Note:
  I found Mobile one synthetic drained quickly and the Aeroshell Sport plus 4
  less.  I would not be concerned.  BUT:
  50 blades on a 912S is quite a lot of spinning.  (Normal for my old 914.)
  If you pause on each compression, it should only be about 10 blades of spin
  ning to get a gurgle, but that is only based on new (er) 912S engines.  The
  912 and 914 tend to take more spinning to the verge of a heart attack on m
  ine.
  Do check for static leaks on your fittings as a Rotax will not leak oil ext
  ernally unless something is wrong.  If you have oil anywhere on the outside
  of your engine, oil pump, gearbox, or oil cooler, please investigate and s
  olve it.  If all is high and dry, it is probably just that shaft oil seal o
  n the oil pump is leaking internally.  This is not a huge problem, but warr
  ants checking.
  Best Regards,
  Bud Yerly
  s 10
  onics.com> on behalf of jonathanmilbank <jdmilbank(at)yahoo.co.uk>
  Sent: Wednesday, May 30, 2018 5:53:47 PM
  Subject: Gurgling (burping)
  My 912ULS engine has done 250 hours since complete strip-down and rebuild a
  fter I bought it from an acknowledged Rotax engine expert. The three others
  who share the Europa with me are all happy with how sweetly it runs. The c
  ompressions were measured very recently and are excellent (close to 200 psi
  ). The oil pressure is good being in the vicinity of 4 bar. BUT....
  Nine times out of ten the oil drains quickly (overnight) from the tank to a
  level below the flat on the dipstick. This wasn't always so and has become
  worse over time. It used to take about a dozen compressions done quite slo
  wly to push the oil back into the tank, while these days it can often take
  50 or more compressions. Why?
  My supposition is that the oil escapes past the oil pump and the rate of es
  cape depends on the position of the pump lobes when at rest. So if the oil
  pressure remains good in flight, what's changed? Perhaps the oil pressure r
  elief valve is sticking in some way?
  Your experience and knowledge of likely causes would be gratefully received
  https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.m
  atronics.com%2Fviewtopic.php%3Fp%3D480527%23480527&data=02%7C01%7C%7C3d65
  8908e052457c65e808d5c6785195%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6
  36633142417666692&sdata=hMIfL5dMQonZdtqvefaTxJDC7hsrnjywmpu%2BwZNmtDA%3D&
  reserved=0
  F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7C3d65890
  8e052457c65e808d5c6785195%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C6366
  33142417822944&sdata=JvekXzI0ulHysaX%2FODq3XxP%2B%2F4FYaqi3Yj%2Bvcgy2b%2B
  Y%3D&reserved=0
  F%2Fforums.matronics.com&data=02%7C01%7C%7C3d658908e052457c65e808d5c67851
  95%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636633142417822944&sdata=
  bHKdinAh%2FcO2%2FJKX%2BVeVNNEWx0recm3pP6mpbZJTyCs%3D&reserved=0
  F%2Fwiki.matronics.com&data=02%7C01%7C%7C3d658908e052457c65e808d5c6785195
  %7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636633142417822944&sdata=YH
  TCUzUK%2FxeOZQlBKQS7HDWvZMmtu2kWol3yPS%2BztvE%3D&reserved=0
  F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7C3d658908e052457c65
  e808d5c6785195%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636633142417822
  944&sdata=SLnhhGEn%2FyvEFMqqI2pHgYIij6YNzplrGEJDwgbUBX0%3D&reserved=0
  ________________________________  Message 3  _____________________________________
  Time: 09:09:01 AM PST US
  Subject: Static problem?
  Two or three years ago our Garmin GMA 340 audio panel was damaged apparently by
  nearby lightning strike - we saw flash in far distance and then had to use copilot
  ptt.  Garmin repaired for $600 and said it was destroyed by lightning.
  On our trip to Petit Jean we were in some precipitation and getting bounced.  ADSB
  was showing lots of colors but it was just a short distance and ATC had opposite
  direction VFR traffic above us.  Suddenly, no audio again.  When we were
  in the clear we found we could transmit by powering off the GMA 340 and hear
  ATC with it powered on but in PA mode.
  We talked to SteinAir and purchased a new Garmin GMA 240 audio panel partly in
  hopes that the newer technology might be more resistant to being damaged and a
  new 240 was about the cost of repair of the 340.
  Stein, the owner, suggested we might want to add a single static wick to each wingtip
  and the top of the tail and connect them all together to our common ground
  point using #20 or so wire.  The idea to drain off built up charge.
  Has anyone else had a similar problem and whats the opinion on static wicks?
  Jim & Heather
  http://forums.matronics.com/viewtopic.php?p=480604#480604
  ________________________________  Message 4  _____________________________________
  Time: 10:11:25 AM PST US
  Subject: Re: Static problem?
  Jim & Heather,
  I havent had that problem so this is all theory from a 70 year old physicist.
  This is a really complex problem.  You are flying a plastic, non-conductive airframe.
  Flying it through the air is like rubbing a plastic rod with a piece of
  fur.  Its going to generate a static charge. The charge resides on the outer
  surface of the skin.  No charge on the inter surface.  Makes the skin of the
  aircraft like a big capacitor.  Because the airframe is non-conductive that charge
  isnt going to move around much until it reaches a breakdown voltage somewhere
  and you can get a local discharge.  Like through a an audio panel.  Static
  wicks out on the tips of the wings and empennage, even when connected with conductive
  media to the ground, will only dissipate the charge locally around the
  wick.  (Im not sure how well) And, I guess, maybe around the near field of
  the conductor if it were bare wire.  Would those wicks dissipate the charge that
  took out the audio panel?  Maybe, but probably not.  Might those wicks reduce
  the overall charge and prevent a charge build up to ensure that there was never
  sufficient charge to harm the electronics?  Maybe, maybe not.
  And, arent wicks supposed to dissipate the static charge off the airframe into
  the air, not to aircraft ground?  The idea being NOT to get the charge buildup
  in the ground.  I really dont see any benefit from static wicks on a plastic
  airframe.
  Perhaps a better answer would be from Bob N. our electronics guru.  He probably
  has far more direct experience with this type of issue.
  Blue skies & tailwinds,
  Bob Borger
  Europa XS Tri, Rotax 914, Airmaster C/S Prop (130 hrs).
  Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.
  3705 Lynchburg Dr.
  Corinth, TX  76208-5331
  Cel: 817-992-1117
  rlborger(at)mac.com
  Jim & Heather
  ________________________________  Message 5  _____________________________________
  Time: 11:46:24 AM PST US
  Subject: Re: Gurgling (burping)
  Bud,
  The outside of my engine and the oil cooler and tank are all free from all traces
  of leaks and the new hoses fitted a year ago are tightly clamped, so no air
  leaks.
  I've taken your advice and looked at Service Bulletin 912-032, so this is the avenue
  that I'm probably going to investigate. Thanks very much.
  Best wishes,
  Jonathan
  http://forums.matronics.com/viewtopic.php?p=480611#480611
  _________________ Creighton Smith
A 036 |
				 Posted: Tue Jun 05, 2018 8:21 am    Post subject: Fuel management |
				If I might ask, which totalizer did you chose?
  	  | Quote: | 	 		   On Jun 5, 2018, at 7:27 AM, crouto <crouton(at)well.com> wrote:
  Sent from my iPad
 > HTML Version:
 > Text Version:
 > From: Bud Yerly <budyerly(at)msn.com>
 > citance sender.
 > Bottom line,
 > (5.5/hr))
 > My sight gauge.
 > t.
 > Regards,
 > Bud Yerly
 > s 10
 > to see.
 > Graeme Bird
 > Nexus, SmartA3
 > g(at)gdbmk.co.uk
 > served=0
 > erved=0
 > Jonathan,
 > chanic.  So Look.
 > blem.
 > Note:
 > ine.
 > ants checking.
 > Best Regards,
 > Bud Yerly
 > s 10
 > reserved=0
 > Y%3D&reserved=0
 > From: "h&jeuropa" <butcher43(at)att.net>
 > Jim & Heather
 > From: Robert Borger <rlborger(at)mac.com>
 > Jim & Heather,
 > airframe.
 > Bob Borger
 > 3705 Lynchburg Dr.
 > Cel: 817-992-1117
 > rlborger(at)mac.com
 > Jim & Heather
 > From: "JonathanMilbank" <jdmilbank(at)yahoo.co.uk>
 > Bud,
 > leaks.
 > Best wishes,
 > Jonathan
		tennant
				 Posted: Wed Jun 06, 2018 3:03 am    Post subject: Re: Fuel Management |
				As an extension of Mike Gregory's caution.
 It is always wise, when one knows how accurate the totaliser is, to compare fuel loaded to computed expected fuel.
 I filled up one time and realised that I had taken 7 Liter more than expected. Sure enough I had a small tank outlet leak.
D-EHBT
At EDLM  -  Germany |
				 Posted: Wed Jun 06, 2018 4:31 pm    Post subject: Fuel management |
				Creighton uses the FC10.
 Bud Yerly
 Custom Flight Creations
 From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Mike Christine Duane <DuaneFamly(at)aol.com>
 Sent: Tuesday, June 5, 2018 3:59:10 PM
 Subject: Re: Fuel management
  Sent from my iPad
 > HTML Version:
 >   https://nam03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fdigest%2Fdigestview.php%3FStyle%3D82701%26View%3Dhtml%26Chapter%3D2018-06-03%26Archive%3DEuropa&data=02%7C01%7C%7Ca1b6dc38b9d742f580d008d5cb00ee87%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636638127210339272&sdata=WwL9ZxxUsB1b23kWpk1DycCp%2BdrZk%2BCF48rfy7Z3JIo%3D&reserved=0
 > Text Version:
 >   https://nam03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fdigest%2Fdigestview.php%3FStyle%3D82701%26View%3Dtxt%26Chapter%3D2018-06-03%26Archive%3DEuropa&data=02%7C01%7C%7Ca1b6dc38b9d742f580d008d5cb00ee87%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636638127210339272&sdata=RJUElmeZBLsmAUmizjO1ua01WhNIYggbsgUphjaZzgw%3D&reserved=0
 > citance sender.
