Jim Combs
Joined: 24 Jan 2010 Posts: 140 Location: Lexington, Ky
Posted: Fri Jun 22, 2018 5:43 am Post subject: Run-away trim question |
I was asked a question recently about runaway trim.
What would I do if it happened?
I have tried flying the -10 with the trim held to see just what happens. I cruise flight, the out of trim condition happens so fast and the forces on the stick quickly overwhelm the pilots ability to control the aircraft. Realizing what is going on would be a surprise to the pilot and once it happened, flying the airplane becomes the dominate focus item. Stopping the runaway by pulling a fuse or some other action would most likely not happen.
This question does not necessarily apply only to the -10. It could happen on any aircraft.
That being said:
(1) Has anyone ever heard of a runaway condition actually happening? if so what was the outcome?
(2) Is there a stand-alone device that could be put into the trim circuit that is powered by the power going to the trim motor that would (A) prevent the motor from running for an extended time and (B) alert the pilot to the runaway condition. This would be downstream from the switch or controlling electronics.
Jim Combs
N312F (1000+ hours)
_________________ RV-10 -> N312F - Flying as of 12/2008 |
philperry9
Posted: Fri Jun 22, 2018 5:54 am Post subject: Run-away trim question |
You can install the TCW trim controller and it will address the issue of run away trim. I know it will do more, but here are some basics.
1) It will limit the time that the servo is active to just a few seconds. Then disconnect the trim requiring to re-engage the switch to activate the servo for a few more seconds. This prevents a stuck switch to run the servo to full travel and your trim to full defection.
2) It has a sense circuit built into it that senses where there is a short in a wire causing the servo to run. Then provides a switch that allows you to reverse the travel of the servo through a momentary switch to bring the servo back to its normal spot; then it disconnects the servo from the buss. Thus locking the servo in a more neutral position.
3) It also has a two-speed option so you don't have to drive your servo at full speed. This brings the trim adjustments down to a slower and more reasonable speed when you're really scooting through the air.
Phil
On Fri, Jun 22, 2018 at 8:40 AM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Jim Combs
N312F (1000+ hours)
Jim Combs
Posted: Fri Jun 22, 2018 6:04 am Post subject: Run-away trim question |
Thanks, I will check that out.
Jim C
On Fri, Jun 22, 2018 at 9:52 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Quote: | You can install the TCW trim controller and it will address the issue of run away trim. I know it will do more, but here are some basics.
Phil
Jim Combs
N312F (1000+ hours)
Kelly McMullen
Posted: Fri Jun 22, 2018 6:31 am Post subject: Run-away trim question |
Well, I had a complete elevator trim failure, not runaway, and fortunately I discovered I had the problem shortly after lift-off, so did not allow speed to get much above 120.
Due to some dufus builder error, the cotter pin for the bellcrank bolt on the trim assembly fell out, the nut backed off, and the bolt worked its way out, so the bellcrank did not have any leverage and helped nothing. The resulting trim was somewhere around landing configuration nose up. The stick force was under 10 lbs., easy to hold with one hand for the 15 min flight I had back to home drome. Yes, I suppose you could have runaway trim, that the surprise factor would be main event. Between stick force and throttle, you can control the force involved.
No, I would not want to be IFR. However, I found that in my case, my Dynon autopilot had no trouble holding the airplane...although I chose not to do that for more than long enough to see if it could. I didn't want to risk failure of the shear pin, and stress the servo.
Yes, I fixed the problem, with just the difficulty of getting my old, creaky body back in the tail cone and reassembling parts that I couldn't get a good view. Now to go punish that doofus builder.............
Quote: | Sent from my IBM-360 main frame |
On Fri, Jun 22, 2018 at 6:40 AM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Jim Combs
N312F (1000+ hours)
A&P/IA, EAA Tech Counselor
KCHD |
stein(at)steinair.com Guest
Posted: Fri Jun 22, 2018 6:38 am Post subject: Run-away trim question |
Also realize that if you’re using either Garmin or Dynon’s integrated autopilots with the Auto Trim wired through their respective A/P’s, you also get trim motor timing limits (which in effect is the same function) along with the trim speed scheduling. The Safety Trim is an excellent box as a standalone device, but becomes redundant if you have either the Garmin or Dynon integrated A/P (with the respective controllers).
Just my 2 cents as usual.
Cheers,
Stein
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> On Behalf Of Jim Combs
Sent: Friday, June 22, 2018 9:03 AM
Subject: Re: Run-away trim question
Jim C
On Fri, Jun 22, 2018 at 9:52 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote: Quote: |
Phil
On Fri, Jun 22, 2018 at 8:40 AM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote: Quote: |
Jim Combs
N312F (1000+ hours)
Jim Combs
Posted: Fri Jun 22, 2018 6:52 am Post subject: Run-away trim question |
So I looked into the TCW solution and I still consider this to be a single point of failure. Note: I am NOT in any way bashing the TCW solution. It still has power supplied to it and can run the the trim servo IF IT FAILED. But it does have a separate power switch along with the airspeed speed switch. Both of which I like, so I will be installing that in the -10.
I have been driving my trim through a DPDT On - Off - On momentary switch and have had no issues with it. Having the speed select will be a nice addition. I also like the TCW Flap system. So I think some upgrades are in order for the -10.
Jim C
So Kelly, does the IBM 360 heat the house too? Just wondering.
On Fri, Jun 22, 2018 at 10:29 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
Quote: | Well, I had a complete elevator trim failure, not runaway, and fortunately I discovered I had the problem shortly after lift-off, so did not allow speed to get much above 120.
Jim Combs
N312F (1000+ hours)
Jim Combs
Posted: Fri Jun 22, 2018 6:53 am Post subject: Run-away trim question |
I have the Advanced Flight System and A/P. No A/P Trim.
Pondering the ADSB upgrade but that is a different thread.
Thanks, Jim C
On Fri, Jun 22, 2018 at 10:34 AM, Stein Bruch <stein(at)steinair.com> wrote:
[quote] Also realize that if you’re using either Garmin or Dynon’s integrated
Cheers,
Stein
*From:* owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)
matronics.com> *On Behalf Of *Jim Combs
*Sent:* Friday, June 22, 2018 9:03 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Run-away trim question
Jim C
On Fri, Jun 22, 2018 at 9:52 AM, Phillip Perry <philperry9(at)gmail.com>
Phil
rleffler
Posted: Fri Jun 22, 2018 7:07 am Post subject: Run-away trim question |
If you add the Dynon module, you can get the trim control as long as you have the Dynon servos.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Jim Combs <jiminlexky(at)gmail.com>
Sent: Friday, June 22, 2018 10:51:48 AM
Thanks, Jim C
On Fri, Jun 22, 2018 at 10:34 AM, Stein Bruch <stein(at)steinair.com (stein(at)steinair.com)> wrote:
Quote: |
Also realize that if youre using either Garmin or Dynons integrated autopilots with the Auto Trim wired through their respective A/Ps, you also get trim motor timing limits (which in effect is the same function) along with the trim speed scheduling. The Safety Trim is an excellent box as a standalone device, but becomes redundant if you have either the Garmin or Dynon integrated A/P (with the respective controllers).
Cheers,
Stein
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> On Behalf Of Jim Combs
Jim C
Phil
Jim Combs
N312F (1000+ hours)
_________________ Bob Leffler
N410BL - Phase I
Kellym
Posted: Fri Jun 22, 2018 7:37 am Post subject: Run-away trim question |
Hmm, some Dynon things are compatible, don't know if their autopilot
control panel is among those things. Worth asking.
On 6/22/2018 7:51 AM, Jim Combs wrote:
Thanks, Jim C
A/P (with the respective controllers).____
__ __
Just my 2 cents as usual.____
__ __
Cheers,____
Stein____
__ __
__ __
<mailto:owner-rv10-list-server(at)matronics.com>
<mailto:owner-rv10-list-server(at)matronics.com>> *On Behalf Of *Jim Combs
*To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
*Subject:* Re: Run-away trim question____
__ __
Thanks, I will check that out.____
__ __
Jim C____
__ __
<mailto:philperry9(at)gmail.com>> wrote:____
some basics.____
__ __
trim to full defection.____
__ __
the servo in a more neutral position.____
__ __
scooting through the air.____
__ __
Phil____
__ __
<mailto:jiminlexky(at)gmail.com>> wrote:____
I was asked a question recently about runaway trim.____
__ __
What would I do if it happened?____
__ __
or some other action would most likely not happen.____
__ __
It could happen on any aircraft.____
__ __
That being said:____
__ __
happening? if so what was the outcome? ____
__ __
controlling electronics.____
__ __
Jim Combs____
N312F (1000+ hours) ____
__ __
__ __
__ __
__ __
KCHD |
Bob Turner
Posted: Fri Jun 22, 2018 8:14 am Post subject: Re: Run-away trim question |
You absolutely want trim speed control. The stock, full speed, is about right for low (takeoff, landing) speeds but runs way too fast at cruise. I have a Trio Pro autopilot. Not only does it auto-trim when engaged; you can use it to trim manually, too, when the servos are not engaged. It contains a programable with airspeed speed control, too. So my routine is to use the stick switch for takeoff/landing trim (full speed); I use the Trio knob for fine trim adjustments in cruise. I put no top hat on the copilot stick, to prevent accidental trim commands. Right seat pilots have to use a panel mounted rocker switch. I put both AP and trim CBs right in front of the pilot, marked with a colored line. How fast could I pull them, given no warning? I don’t know.
Edit. Forgot to mention, the no top hat on right stick thing is because someone reported a ‘runaway trim’ when their right seat passenger rested a book on the top hat switch.
_________________ Bob Turner
RV-10 QB |
rleffler
Posted: Fri Jun 22, 2018 8:55 am Post subject: Run-away trim question |
It is..... I know several people that have it installed. Some features/functions may vary depending if you have Dynon servos versus Trutrak.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Kelly McMullen <kellym(at)aviating.com>
Sent: Friday, June 22, 2018 11:08:28 AM
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com>
> Thanks, Jim C
> __ __
> __ __
> Cheers,____
> Stein____
> __ __
> __ __
> <mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)>
> <mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)>> *On Behalf Of *Jim Combs
> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
> __ __
> __ __
> Jim C____
> __ __
> <mailto:philperry9(at)gmail.com (philperry9(at)gmail.com)>> wrote:____
> some basics.____
> __ __
> __ __
> __ __
> __ __
> Phil____
> __ __
> <mailto:jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)>> wrote:____
> __ __
> __ __
> __ __
> __ __
> __ __
> __ __
> __ __
> Jim Combs____
> __ __
> __ __
> __ __
> __ __
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; -Matt Dralle, List Admin.
N410BL - Phase I
rnewman(at)tcwtech.com Guest
Posted: Fri Jun 22, 2018 12:15 pm Post subject: Run-away trim question |
Thanks to those that mentioned our Safety trim controller. One bit of trivia regarding the concept of single point failure. Even though our device is “one box” inside the unit there’s actually three separate series circuits which would have to all fail to provide an uncommanded operation of the servo. As a result after 10 years in the field we have had zero issues resulting in unwanted motion even in the face of a variety of builder mistakes and mis-applications.
Bob NewmanTCW Technologies, LLC
610-928-3420
On Jun 22, 2018, at 10:02 AM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Quote: | Thanks, I will check that out.
Jim C
Phil
Jim Combs
N312F (1000+ hours)
Jim Combs
Posted: Fri Jun 22, 2018 1:25 pm Post subject: Run-away trim question |
Bob, Thanks for that bit of feedback. I am a retired electrical
engineer. That bit of information should be shared on your website.
I am planning or ordering that and the flap controller in the next few days
Tim Olson
Posted: Fri Jun 22, 2018 1:47 pm Post subject: Run-away trim question |
Hey Jim, on my RV10 site I have an old write-up from when I put in safety-Trim. There may be more info there that you may want to check out also. I have mine set up with an airspeed switch and also a flap switch which I like very much and did the same on my RV14 as I did the -10.
You’ll be happy with the trim controller and wiring is easier than the relays you probably have now.
On Jun 22, 2018, at 5:15 PM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Quote: | Bob, Thanks for that bit of feedback. I am a retired electrical engineer. That bit of information should be shared on your website.
I am planning or ordering that and the flap controller in the next few days.
Jim C
On Fri, Jun 22, 2018 at 4:13 PM, Tcwtech <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)> wrote:
Quote: | Thanks to those that mentioned our Safety trim controller. One bit of trivia regarding the concept of single point failure. Even though our device is “one box” inside the unit there’s actually three separate series circuits which would have to all fail to provide an uncommanded operation of the servo. As a result after 10 years in the field we have had zero issues resulting in unwanted motion even in the face of a variety of builder mistakes and mis-applications.
610-928-3420
Jim C
Phil
Jim Combs
N312F (1000+ hours)
johngoodman
Posted: Sat Jun 23, 2018 3:49 am Post subject: Re: Run-away trim question |
I have a Vertical Power 200 in my RV-10, and it has runaway trim built in as well as trim speeds. Not sure if the VPX still has it.
John
_________________ #40572 Phase One complete in 2011 |
rleffler
Posted: Sat Jun 23, 2018 4:50 am Post subject: Run-away trim question |
It does. I have a VPX/Pro in my RV-10.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of johngoodman <johngoodman(at)earthlink.net>
Sent: Saturday, June 23, 2018 7:49:59 AM
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
John
http://forums.matronics.com/viewtopic.php?p=481133#481133
Email Forum -
ums.matronics.com
matronics.com
N410BL - Phase I
cooprv7(at)yahoo.com Guest
Posted: Sat Jun 23, 2018 5:35 am Post subject: Run-away trim question |
For what it’s worth, I just have the Ray Allen system but with the rates being high for faster airspeed and potential for runaway trim I put in a trim disconnect switch on the panel I can slap before it gets too bad. Not as quick to respond as the systems in this thread, but cheap and effective.
Marcus
On Jun 23, 2018, at 8:48 AM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
Kelly McMullen
Posted: Sat Jun 23, 2018 5:39 am Post subject: Run-away trim question |
I have VPX. I used use its trim controller. I rewired since then to use the Dynon autopilot control panel's trim feature with auto-trim.
Kelly
40866, 150 hrs in the air.
On Sat, Jun 23, 2018 at 5:48 AM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
KCHD |
Jim Combs
Posted: Sat Jun 23, 2018 6:55 am Post subject: Run-away trim question |
Sir Tim, Thanks!
I did see that and read your write-up. I don't have a flaps up switch but will add one per your suggestion.
I do have a flap position potentiometer that is used to show the flap position on the EFIS.
Thanks, Jim C
On Fri, Jun 22, 2018 at 5:44 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Jim C
610-928-3420
Jim C
Phil
Jim Combs
N312F (1000+ hours)
Posted: Sat Jun 23, 2018 7:19 am Post subject: Run-away trim question |
The Dynon trim system has runaway protection as well.
Jesse SaintSaint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Jun 23, 2018, at 8:36 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
Quote: | I have VPX. I used use its trim controller. I rewired since then to use the Dynon autopilot control panel's trim feature with auto-trim.
Kelly
