morgjj
Posted: Tue Jul 18, 2006 5:42 am Post subject: Electric failure |
Hi all,
I am curious if I am just naive in my thinking and design goals, or if this is a truly a dooms day approach to the whole glass panel idea. I was reading the FAA Aviation News for June and there is an extensive article about training for glass and the approaches/needs/goals. As I read this part, I was trying to decide if it was a realistic situation that is worth the effort.
" In our TAA Aircraft course completion ride, I use a four airport scenario. The first airport is a VFR arrival at a class D airport with touch and go and a VFR departure. The second airport is an ILS to a published missed approach to a holding pattern. This is where I dim the MFD simulating an alternator failure and watch the pilot try to figure out how to do an intersection hold with no on screen map and just the CDI and DBAR on the HSI. Hmmm, same results time after time. The pilots get lost interpreting the DI and figuring out how to set up the “To“ and “From” of the two defining VOR radials. A loss of Electronic Situational Awareness and inadequate working memory of the IFR basics leads to a potentially dangerous situation. I know they were taught it when hey got their IFR ticket, but they obviously are not current using it."
I find this a bit troubling as I am thinking that the situational testing is not really trying to figure out how to truly give a situation that is realistic. With batteries and the proper setup, most glass will give 30 min plus to get on the ground. One could argue that 60 is better, but if you did things correctly, according to training, an alternator failure in IMC is an "Emergency" and such should be declared. With that, if you are in the air more than 30, there are bigger problems than finding an intersection with VOR.
I agree that those are important skills that one should keep up on, and not suggesting that we should pitch the VOR or other Nav aids because we have batteries, but just trying to determine the validity of this and wonder if we as pilots shouldn't ask more pressing questions about training and standards that are more likely to mirror the reality of flight that we are likely to encounter.
The other thing I do find humorous here is that if there is an Alternator failure, wouldn't VOR go to? MFD failure is considerably less likely, especially on two screens setup properly, yet that seems to be the focus for so many folks in training. I have read over and over that the best training is one that parallels what one will encounter in real life, so is it me, or is this type of thinking not realistic? I open the bashing gates to the discussion, but think this is something that we should help shape so that it is realistic. If my design ideas are wrong, then I would like to hear that. I understand that part of the design is determining acceptable risk, and just starting the plane bring some.
Jeff
jclarkmail(at)gmail.com Guest
Posted: Tue Jul 18, 2006 6:17 am Post subject: Electric failure |
Jeff,
I thik I kind of agree with you.
There are two DIFFERENT failures here that might be mixed in the training. If the alternator goes then so does all the OTHER electrical stuff as you say. The more realistic training MIGHT be how to use the Garmin handheld to get to safety (along with the handheld radio). This all assumes a quick failure with no time to communicate with and get assistance from ATC.
Furthermore some of the EFIS systems (at least the experimental ones) allow multiple voltage inputs ... SO the EFIS could in fact run off a little dedicated battery and last LONGER than the VOR radio and CDI.
Finally the EFIS itself could fail for reasons having little or nothing to do with power. No **THAT** failure is one where you would need to be able to revert to the "old stuff". I hope I never have theproblem, but I must say that I always have my Garmin 396 running in parallel for situational awareness, so if I have "other" failures", I am still "aware" at some level and can point the nose towards home or some other safe haven.
James
On 7/18/06, Jeffery J. Morgan <jmorgan(at)compnetconcepts.com (jmorgan(at)compnetconcepts.com)> wrote: | Quote: | Hi all,
" In our TAA Aircraft course completion ride, I use a four airport scenario. The first airport is a VFR arrival at a class D airport with touch and go and a VFR departure. The second airport is an ILS to a published missed approach to a holding pattern. This is where I dim the MFD simulating an alternator failure and watch the pilot try to figure out how to do an intersection hold with no on screen map and just the CDI and DBAR on the HSI. Hmmm, same results time after time. The pilots get lost interpreting the DI and figuring out how to set up the "To" and "From" of the two defining VOR radials. A loss of Electronic Situational Awareness and inadequate working memory of the IFR basics leads to a potentially dangerous situation. I know they were taught it when hey got their IFR ticket, but they obviously are not current using it."
Jeff
This is an alternate email. Please continue to email me at james(at)nextupventures.com (james(at)nextupventures.com) .
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Jul 18, 2006 7:15 am Post subject: Electric failure |
On Jul 18, 2006, at 9:28 AM, Jeffery J. Morgan wrote:
| Quote: | I agree that those are important skills that one should keep up on,
encounter.
I have been thinking about this from the point of view how cockpit
automation (what we are really talking about when we talk about smart
glass displays) affects things when the scenario suddenly changes.
The effect isn't only when you have a systems failure but when you
have a sudden change in routing or weather that involves
reprogramming the automation on-the-fly. There is an excellent
article about this here:
http://www.aviationnow.com/avnow/news/channel_bca_story.jsp?id=news/
glass_0206.xml
I remember hearing a 737 crew grousing to ATC about a rerouting that
was so massive that they had to throw out the flight plan in their
FMS and start from scratch. They even asked ATC to give them a
rerouting that was not so onerous. The funny thing was that the new
routing started with turning direct to a different VOR. How hard
would it have been for them to tune in the new VOR, look at the RMI,
and turn until the needle was on the nose and THEN start messing with
the flight plan in the FMS? The captain could have flow the plane to
the VOR while the FO was working on the next leg of the flight plan
in the FMS. It didn't even occur to them to do that. (And all of this
was on the radio for everyone to hear. Scary.)
I have experienced the problem myself when I was trying to run my
older IFR LORAN while IFR and received three new clearances in the
space of ten minutes. I went head down twice before falling back to
thinking about what needed to be done and just flying the airplane.
We are tending more and more to lean on our "smarter" automation. I
bet everyone here who flies has a GPS and uses that GPS for primary
navigation. It is just so bloody easy to type in "direct to kabc"
than it is to haul out a map and a plotter. The problem is what to do
when that goes away. I have an EHSI and GPS with moving map in my
currently-flying aircraft. It is so seductive to program that, turn
on the autopilot, and just watch.
But I have had too many GPS failures to be comfortable relying on
GPS. I spend as much time seeing to it that my ancient KNS-80 RNAV is
set up as I do my GPS. When I am in the Caribbean I back up my GPS
with ADF. The hard part is making the transition from GPS to my
backup nav system when GPS fails. (Notice my use of the word "when"
instead of "if"? That was intentional.)
I have found that when new routing comes in or I have to make a rapid
change, it is often easier to switch to using raw VOR or ADF as my
primary nav and then go back to reprogram the GPS (or FMS) *AFTER* I
am reestablished and comfortable. There have even been times when I
never did have time to go back to reprogram the GPS so at that point
the GPS was useless for navigation. The only thing it was doing at
that point was feeding position information to the moving map which I
was using as a backup to help me maintain situational awareness.
So, yes, becoming dependent on the automation *is* a two-edged sword.
It can make you a lot more precise when it is working and it can
really mess you up when it is no longer delivering service (for
whatever reason).
So when all else fails, do you know how to fly to a VOR radial
defined intersection and hold?
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
nuckollsr(at)cox.net Guest
Posted: Tue Jul 18, 2006 7:57 am Post subject: Electric failure |
At 08:28 AM 7/18/2006 -0500, you wrote:
| Quote: | Hi all,
the effort.
<snip>
This is typical of the mind-set of most pilots, the folks
who write rules governing the behavior of pilots and still
more folks who write rules on how airplanes should be configured.
Instead of worrying about "what do I do if the panel goes
black", how about considering ways to keep the panel from
going black. This means failure tolerant design in some
form or another. It's a failure mode effects analysis that
considers NOT "what's the likelihood of this part failing?"
but instead "What is my plan-b for when this part does fail?"
We worry about alternator failures because (1) they've got
a poor track record in certified aviation when compared with
automobiles over the past 60 years, (2) we've read too many
dark-n-stormy-night stories involving rare but tense electrical
system failures that have (3) distracted us into unwarranted
concentration on the alternator. This happens at the expense
of crafting a plan-b: Well-maintained battery(ies) and/or
second engine driven power sources.
These narrowly focused, single-minded worries are the byproduct
of designers and particularly legislators that do not take
the system-wide view of reliability. We spec and test the
crap out of items assigned to very important tasks without
considering that design and qualification have only a
small part to play in the product's service life. Then
there are $kilo$ meetings with lots of deer-in-the-headlights
expressions when the "golden" device won't perform in the field
well enough to stay off the top-ten problems list. I can
show you very complex systems and components with design
and qualification numbers that run in the thousands of
hours but in fact don't run 30 hours without lighting a
"fail" light.
The simple idea here is to have at least TWO independent
ways to accomplish any critical task such that no single
piece of equipment becomes critical to the outcome of that
task. One begins by accepting the notion that we can craft
systems wherein NO single item of equipment is critical
such that failure of that item is never cause to break
a sweat. This includes alternators. Architecture, understanding
and reasonable preventative maintenance goes a VERY long
way to avoiding a bad day in the cockpit without spending
the Crown Jewels on super-spec components that can fall
victim to inattention or accident at any time.
So when you read any article that opens with an experienced
or hypothesized single failure that caused a bad day in the
cockpit, the remainder of that article is essentially
useless to consider . . . not because the experiences or
hypothesis are not real but because they're writing about
a collection of hardware that was poorly assembled and/or
maintained. The better article to publish is now one achieves
failure tolerance at reasonable costs. Once achieved,
probability of needing to write (or read) all the other
articles goes very close to zero. This includes the article
you cited no doubt written by well intentioned people
who's salaries and retirements are paid out of our pockets.
In chapter 17 of the 'Connection I offered:
Nuckolls' first law of airplane systems design
sez: "Things break"
The second: "Systems shall be designed so that
when things break, no immediate hazard is created."
The third: "Things needed for comfortable termination
of flight require backup or special consideration
to insure operation and availability"
The forth: "Upgrading the quality, reliability,
longevity, or capability of a part shall be because
you're tired of replacing it or want some new feature,
not because it damned near got you killed."
brian
Posted: Tue Jul 18, 2006 8:52 am Post subject: Electric failure |
On Jul 18, 2006, at 11:50 AM, Robert L. Nuckolls, III wrote:
But the real issue with all the new glass stuff is that we are moving
beyond the realm of being able to prevent the glass from going dark.
When my panel was a collection of small, autonomous devices I could
address the problem by providing overlap of functionality and
redundancy of supporting systems (electrical power mostly). When my
AI went TU I could fall back on needle-ball and airspeed.
Now consider the rate at which Garmin seems to be coming up with new
firmware for the G1000 because it seems to be prone to flaking at
inopportune moments. Garmin has removed my ability to prevent
darkness from falling.
So, plan-B is a very necessary evil and one that seems to be more and
more required rather than less as integration becomes more complete
and complex. This is a problem with monolithic systems design. It is
soo simple because it is all in one integrated box while forgetting
that failure is so complete because it is all in one integrated box.
Now it is back to redesigning for no-single-point-of-failure but now
at a higher level.
Posted: Tue Jul 18, 2006 3:58 pm Post subject: Electric failure |
At 12:46 PM 7/18/2006 -0400, you wrote:
at a higher level.
How about a gps aided wing leveler that is independent of
all other goodies on the panel? Perhaps DUAL wing levelers.
No matter what things on the panel do, the airplane stays
right side up, the pilot has time and low pressure environment
to dig out the hand-helds, or simply compass steer to known
VMC, . . . . whatever.
If I were going to poke long tunnels in clouds, this is
the kind of plan-b that smoothly backs up anything that
glass or gages on the panel decide to do.
brian
Posted: Tue Jul 18, 2006 5:23 pm Post subject: Electric failure |
On Jul 18, 2006, at 7:48 PM, Robert L. Nuckolls, III wrote:
| Quote: | > So, plan-B is a very necessary evil and one that seems to be more and
> at a higher level.
Oh, no doubt it can be done. It is just that I am realizing that all
this complexity is not meeting the promise of reduced cockpit workload.
Posted: Tue Jul 18, 2006 6:18 pm Post subject: Electric failure |
| Quote: | > How about a gps aided wing leveler that is independent of
As long as any operating mode requires a human to observe,
and interpret displays, and react in the appropriate controls
inputs to aviate, then there is nothing anyone can do with either
brass or glass to "reduce cockpit workload". Who ever is promising
lower workloads while leaving the pilot in the loop is blowing
lots of smoke you-know-where.
We used to EXPECT a pilot to belly up to that bar with
the aplomb of Lindbergh and the daring-do of a WWI flying
ace and show us how a "real pilot" does it.
But it's an inarguable, simple-idea that nobody keeps
the wings level tirelessly and more accurately than
a rate gyro, a handful of jelly bean parts and a servo motor.
Add some GPS data and you've got a fantastic recipe for
success. When the bill of materials and lines of software
to do the task are 1/10th that of a panel mounted display
(that depends on the eyeball-brain-hand interface)
I can see no better cost benefit ratio or more elegant
solution for lower complexity. And guess what? It absolutely
guarantees and demonstrates lower cockpit workload.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Guy Buchanan
Posted: Tue Jul 18, 2006 9:21 pm Post subject: Electric failure |
At 07:00 PM 7/18/2006, you wrote:
| Quote: | But it's an inarguable, simple-idea that nobody keeps
Not being smart. Just wondering. Does this exist? If not, why not? If so,
who does it?
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
brian
Posted: Wed Jul 19, 2006 4:54 am Post subject: Electric failure |
On Jul 18, 2006, at 10:00 PM, Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> workload.
Oh, it is quite possible for automation to lower cockpit workload. As
you point out, automation does a great job of tirelessly watching
things and making mindless corrections. Your wing-leveler is a good
point. Engine instrumentation is good too. How annoying is it to
realize that you got distracted and only just looked up to see that
the oil pressure is approaching zero and oil temp is well up past red
line. Much better to have that mindless servant bring it to your
attention than to depend on you remembering to scan the engine gauges.
Part of the problem is the user interface. Most GPS and FMS have
confusing, inflexible interfaces with the human that don't permit
easy changes. The point I was making is that it is a LOT easier to
dial a new frequency into a VOR receiver and then reach up to turn an
OBS to center the CDI, look at the new bearing/radial, and turn the
airplane to a new heading than it is to reprogram even a simple
flight plan in a GPS.
I was just musing aloud on my recent flying (I have racked up 50
hours of international cross-country flight in the last month). I am
finding myself back on the victor airways and using my VORs almost as
much as my GPS. (The GPS gives me ground track information which
helps me do a much better job of adhering to to my desired track than
does the trial-and-error approach of VOR.) I use my charts to decide
where I am going to go so the GPS is no longer absolutely dominant in
my navigation. Navigation automation is not necessarily better under
all conditions.
| Quote: | We used to EXPECT a pilot to belly up to that bar with
Don't forget panache.
No argument there.
Hopperdhh(at)aol.com Guest
Posted: Wed Jul 19, 2006 4:55 am Post subject: Electric failure |
In a message dated 7/19/2006 1:24:51 A.M. Eastern Daylight Time, bnn(at)nethere.com writes:
who does it?
Guy Buchanan
This sounds a lot like my Garmin GPS295 and my Navaid autopilot.
Dan Hopper
RV-7A
Posted: Wed Jul 19, 2006 5:39 am Post subject: Electric failure |
At 10:05 PM 7/18/2006 -0700, you wrote:
who does it?
If anyone is close right now, it's Jim Younkin at
TruTrak. I've had the core components of a design
on the back burner for years and things really took
a turn toward realization when Analog Devices finally
slew the dragons for manufacturing an inexpensive, solid
state rotation rate sensor. See:
http://www.analog.com/en/prod/0%2C2877%2CADXRS401%2C00.html
GPS engines are becomming jelly bean parts too. See:
http://www.rfsolutions.co.uk/acatalog/Embedded_GPS_Module.html
The hardware is a no-brainer. Development of a manufacturable
product takes $time$ and ultimately an airplane . . . both
of which are in my "pretty-hard" pile. But I'm still watching
for opportunities to consider an entry into this market.
Jim would be a most worthy competitor.
brian
Posted: Wed Jul 19, 2006 6:21 am Post subject: Electric failure |
On Jul 19, 2006, at 8:53 AM, Hopperdhh(at)aol.com wrote:
If so,
who does it?
Guy Buchanan
Well, not quite. I see Bob's idea of a device that will hold an
aircraft on its current ground track using input from GPS as soon as
it is turned on. You don't need to enter a flight plan and you don't
need to tell the autopilot what heading to fly. Flip the 'on' switch
and the airplane unerringly locks onto its current ground track.
Pretty simple. Pretty elegant.
glastar(at)gmx.net Guest
Posted: Wed Jul 19, 2006 7:27 am Post subject: Electric failure |
Hello Brian,
I switch my digitrack on and then it does track along the current track
which is supplied from the GPS, i have a left and a right button to
alter the course by a degree on each click, or keep it 3 sec pressed and
it will fly some sort of a standard rate turn (4min on my Glastar)
however I can also decide to use a flightplan from the GPS or without
GPS it does use the current flown magnetic course.
So quite close I would say
Werner (Glastar with digitrack and altrak)
Brian Lloyd wrote:
<brian-yak(at)lloyd.com>
> If so,
> who does it?
> Thanks,
> Guy Buchanan
> K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.
http://wiki.matronics.com
stein(at)steinair.com Guest
Posted: Wed Jul 19, 2006 7:43 am Post subject: Electric failure |
I guess I'm kind of confused here.....why re-invent the wheel at all?!?
There is Navaid, Trio and TruTrak. They all literally do exactly what
everyone is debating here....turn them on and they work - Plain and simple.
What's wrong with the panel mounted displays in the low end AP's right now?
I mean, it takes a total of ONE button push to engage them and one to
disengage them....can it get much simpler?
It's easy to think that for a few bucks you can 'roll your own' which is
entirely true from a hardware perspective. But....anyone who think's
they'll create something to market, sell, support, install, warranty, etc..
is in for a really rude awakening. Bob knows the expense, time, effort and
engergy it takes and mark my words it's not a simple, cheap or quick
undertaking. I'll guarantee you that nobody can produce a servo cheaper
than TruTrak right now, seeing as they make around 50-100 of them per week,
every week. There is a reason they cost what they do...not because they are
getting particularly rich either.
Anyway, I'm just sort of scratching my head wondering why anyone would even
bother trying to recreate something that can readily be had for less that
$1500 today anyway (and from more than one source)? Heck, just the time
debating it, researching components, time to fabricate, etc.. and you've
already blown more than that in time alone.
No flames or insults intended, just trying to be realistic.
Stein
RV6's, Minneapolis
[quote]--
brian
Posted: Wed Jul 19, 2006 7:57 am Post subject: Electric failure |
On Jul 19, 2006, at 11:24 AM, Werner Schneider wrote:
<glastar(at)gmx.net>
Hello Brian,
track which is supplied from the GPS, i have a left and a right
button to alter the course by a degree on each click, or keep it 3
sec pressed and it will fly some sort of a standard rate turn (4min
on my Glastar) however I can also decide to use a flightplan from
the GPS or without GPS it does use the current flown magnetic course.
Sounds like it. I should know better than to open my mouth when I
haven't researched something.
Erich_Weaver(at)URSCorp.c Guest
Posted: Wed Jul 19, 2006 8:30 am Post subject: electric failure |
This has been an informative discussion for me guys - thanks.
I have a GRT EFIS and the Tru-Trak digiflight II (two axis), but no
experience operating or flying with them yet. The EFIS has a built-in GPS
and I additionally have second Garmin 296 that can pop in and out of the
panel. The thought was to have a backup for navigation in the event of
EFIS failure, and also so that I can punch in a flight plan at home and
then be able to hop in the plane whenever and instantly dump the flight
plan into the EFIS to control the autopilot.
Im a VFR kind of guy, but would like to understand what to expect regarding
the autopilot capabilities in the event of EFIS failure. Its my
understanding that the TruTrak has an internal magnetometer that comes into
play if the GPS or other input fails. Does this mean it will hold the
heading that was in use at the time of failure, or just that I could input
a new heading (assuming I remembered what the desired heading was).
Further, I assume that after EFIS failure I would be on my own with respect
to holding altitude, correct?
regards
Erich Weaver
aerobubba(at)earthlink.ne Guest
Posted: Wed Jul 19, 2006 12:44 pm Post subject: Electric failure |
Hi Jeff-
You raise a good question. Predictably, and no offense to any of the many
esteemed folks that have replied so far, the conversation has gone down the
path of system design. The questions you raise are different. As to what
would actually fail when the alt quits, on my plane nothing will. I can't
speak for the plane in question.
I think the issues raised by your article scenario are twofold. First, the
new, complex equipment tends to have a tremendous amount of functionality.
Typically, and unless beaten with a stick, pilots only use a small portion
of the power that is available to them. They then promptly forget how to
use the other 90% of the tools that are still available to them. I suspect
that is the point the storied instructor was trying to make. In other
words, stay proficient, and with your avionics as well.
The other issue is that given the loss of presented data, trying to macho
one's way out of the scenario is the wrong response. A more correct one
would be to inform ATC that they'd lost generation and were partial panel.
Holds are no longer acceptable, and intersection holds are ludicrous. Take
vectors, get out of IMC and onto the ground. It's just that simple. Do
not relinquish your fate to someone else's expectations.
We now return you to your normally scheduled systems engineering.
Feel free to flame away; I leave for OSH tomorrow and won't get scorched
for another 10 days or so!
glen matejcek
aerobubba(at)earthlink.net
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Wed Jul 19, 2006 3:07 pm Post subject: Electric failure |
Hi Bob,
I was wondering if you could clarify your thinking on this. Are you
proposing that you would install a pair of these simple devices for a fully
redundant system. Would this extend to having dual servos as well?
Just curious,
Paul
morgjj
Posted: Wed Jul 19, 2006 6:38 pm Post subject: Electric failure |
Glen and others,
Actually I was asking more about the training and how closely it would
match a likely failure of a system. I was asking if the types of drills
that seem to be coming up for the Technically Advanced Aircraft (TAA)
seem to be built from the ideas of failures of years ago. I think it is
critical to recognize the past and learn from it, without getting to
arrogant to think that things couldn't fail totally. True that at any
time, anything can fail. I didn't say in my previous post, which I am
learning for the future, I was of the mindset that folks are building
systems where a single point of failure isn't really possible.
So try to my main question again, I think I would word like this. Given
that the article is focused on the least likely event (MFD failure) and
requesting an alternate form of navigation be used, does that seem like
it would be a good use of testing/training of pilots? Wouldn't it be
more prudent to drill more likely scenarios that are more likely then
1-5% likely? That is not to say that I disagree with the idea that you
need to keep your skills updates, regardless of what you are using as I
think you should. We do a disservice to other pilots and the public
when we fly into areas that we shouldn't because we lost GPS signal.
As for some of the points I have read over the past few days, I think
that there is merit in many of them. I think we could discuss all of
them at length. The interfaces on the systems are very different, each
with strong points and weak points. I think that I have often thought is
that the radio should have the closest frequencies in a list off the
tuning button as I fly along. I think it would be great to punch a
button and have a list of the closest ATIS or AWOS stations from my
position with a distance and bearing. Same for VORs. On the Garmin's
you can go to the nearest page and select, but it is a lot of dialing to
get there. With VOR's it isn't like I am going to dial much else in the
NAV radio. If I were 5000' or less, a list of airport CTAF or ATC
controlling facilities on the standby list would be helpful too.
Imagine hitting a button on the radio, and scroll though a list with the
frequency, definition, and direction right on the screen, with the
closest ones first... There is a feature that would lighten pilot loads
in difficult times. But all that said, maybe Brian would want it
differently than that. Never would claim that I am normal by any means.
I am building an airplane after all.
I think that part of the fundamental problem is that the folks writing
the rules, doing the check rides, and to a fair extent, doing the
training or still trying to catch up as well. I had that experience in
my flight training where the CFI didn't like to use certain pieces of
equipment, nor talk to ATC, so as a result when I got done, that stuff
was something I had to work on my own to acquire. TAA is flashy, but it
is a lot of work to learn. Maybe the need to demonstrate a VOR when
MFD failure happens is a reflection of that school of thought.
Personally, I would find things like engine failure, fire, gear
problems, control problems, IMC incursions, strong crosswinds, and even
busy airspace to be much more likely issues that people would run into
prior to failure of most of the systems on the plane, yet very few of
these are even discussed about training suddenly.
I would stress again that I strongly believe in training and preparing
for the worst, but think that the worst should be prioritized by most
likely to least likely and trained and tested in a similar order.
