Housai exhaust section needed - updated
AcroTurtle99
PostPosted: Thu Nov 29, 2018 10:41 am    Post subject: Housai exhaust section needed - updated Reply with quote
Our CJ's airplane-right side middle exhaust section for our Housai engine needs to be replaced. Doug Sapp doesn't have one in stock and indicates it will be well over a month before he gets any new stainless assemblies. Does anyone happen to have this section (in workable condition) laying around in your hangar from when you replaced your old stock exhaust with a stainless one? If so, I would greatly appreciate hearing from you. I would also welcome other ideas / suggestions.
 Filesize:  32.72 KB
 Viewed:  6640 Time(s)
wlannon(at)shaw.ca
PostPosted: Thu Nov 29, 2018 12:34 pm    Post subject: Housai exhaust section needed Reply with quote
Hi David;
I have some surplus stock of original NON stainless exhaust segments both
new and used. If you can confirm that the section you need is on the RH
side as viewed from the cockpit I will confirm for you. A photo would be a
good idea.
Walt
AcroTurtle99
PostPosted: Sat Dec 01, 2018 3:11 pm    Post subject: Re: Housai exhaust section needed Reply with quote
Walt - Thanks for the response. Yes, the section I need is on the RH side as viewed from the cockpit. I included a photo in my original post of both the part itself as well as the engine showing where the removed section is missing from - are you not able to view it?
David
wlannon(at)shaw.ca wrote:
Hi David;
good idea.
Walt
A35plt
PostPosted: Sun Dec 02, 2018 8:04 am    Post subject: Re: Housai exhaust section needed Reply with quote
I've got one Acroturtle... PM sent
AcroTurtle99
PostPosted: Mon Dec 17, 2018 11:03 am    Post subject: Re: Housai exhaust section needed Reply with quote
Thanks to everyone who responded to my post regarding our CJ's airplane-right side middle exhaust section for our Housai engine that needed to be replaced. We were able to source a new-old-stock replacement and we are now back operational. The most time consuming part of the whole episode (other than finding the part) was removing the dried cosmoline and paper from the exhaust segment 😃
