peterz(at)zutrasoft.com Guest
Kelvin Weston
Joined: 14 Apr 2010 Posts: 90 Location: Hampshire, UK
Posted: Tue Jan 29, 2019 10:36 am Post subject: Re: GS tailwheel rudder drive mod question. |
Hi Pete
If you put a straight edge on the tip and measure along the inside of the leading edge (next to the hinges), my rudder measures 48 inches from the straight edge to the centre of the pushrod bracket.
Similarly, if you put the bottom of the rudder on the floor and measure up the inside of the leading edge from the floor to the centre of the bracket it is 6 inches.
However, the bracket position is determined by the lower hinge position on the rudder. If you have that in the right place as shown in Chapter 2 of the Build Manual, you should be ok.
Hope this helps.
_________________ Regards
Kelv Weston
Kit 497
kelv@kdweston.co.uk |
