nuckollsr(at)cox.net Guest
Posted: Wed Jul 19, 2006 8:24 pm Post subject: Electric failure |
At 06:01 PM 7/19/2006 -0500, you wrote:
<paul.mcallister(at)qia.net>
Hi Bob,
I was wondering if you could clarify your thinking on this. Are you
proposing that you would install a pair of these simple devices for a fully
redundant system. Would this extend to having dual servos as well?
Just curious,
Paul
Absolutely. A few months ago I related the demise of a good friend of
mine and his golfing buddies in a fatal event over New Mexico. See:
http://www.aeroelectric.com/articles/N79NL.pdf
This airplane had everything . . . including the kitchen sink. The
pilot was highly regarded, took all the Flight Safety refreshers,
keep the airplane up well. He was an engineer and manager of a business
that delivered LOTS of hardware to GA. He was about as far removed
from the Sunday afternoon fair weather, occasional instrument pilot
as you could find.
Nonetheless, he found himself faced with multiple failures of
expensive, certified but sadly INTERDEPENDENT systems that wrote
the script for an upset. After recovery, his abilities as a brass-or-glass
instrument pilot were severely degraded. In spite of having what
everyone considers "more than adequate" backup, he lost the airplane
a second time.
Sitting amongst attendees at his funeral, I recall thinking that
for lack of a redundant, totally independent killobuck wing leveler,
this didn't need to happen. If such a device had been available for
his airplane, I'm sure he would have installed one. At that time,
NavAid was the only game in town. Nowadays, theres a old-kid on the
block with a new game to play. It's called, "How about we never
need to touch the stick when in the clouds?"
The bill of materials for an airworthy device is peanuts. Having
TWO such systems totally independent of each other offers a HUGE
order of SYSTEM reliability over anything flying today, certified
or otherwise. The old-kid's product is a tad more expensive than
I think it needs to be . . . but who am I to bash the business
model of a very successful designer and honorable supplier to
the OBAM community? So, rather than bash, it seems more fitting
that I COMPETE . . .
But in the mean time, my participation doesn't prevent the
OBAM community from taking advantage of the opportunities
in place to help avoid becoming another NTSB statistic.
The neat thing is that hardware considered "unsuitable" for
use in N79NL is entirely suited to the task in OBAM aviation
and available off the shelf right now.
It just seems the logical way to go. I truly believe my friend Terry
would agree.
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Jul 20, 2006 8:31 pm Post subject: Electric failure |
On Jul 19, 2006, at 10:32 PM, Jeffery J. Morgan wrote:
<jmorgan(at)compnetconcepts.com>
Glen and others,
Actually I was asking more about the training and how closely it would
match a likely failure of a system.
Well, since you mention me by name I guess I get to respond, right?
I would probably approach it from the systems failure point of view
first and then train to that. Let's start with the difference between
flying in visual and instrument meteorological conditions. If you are
VFR, the engine is running and you can make power changes, and the
primary flight controls are working, you don't have an immediate
problem. Fly someplace and land. Sort it out on the ground. If you
think about it, you don't need anything in your instrument panel to
work in order to safely fly to a good landing spot and land. You
don't need radios, gyros, or pitot-static instruments. So if you are
a VFR-only pilot, a lot of the redundancy and no-single-point-of-
failure stuff we talk about here is superfluous. The only exception I
see is if you need electrical power to keep your engine running.
If you are getting ready to yell at me about how you need your
airspeed and altimeter instruments, I have an example that suggests
otherwise. I have a student who had an annoying habit of getting head-
down in the cockpit worrying about being on altitude and on airspeed.
He got to where he was chasing the airspeed instead of flying by
reference to the external horizon. I solved his problem by covering
the ASI and altimeter and making him fly the whole lesson with them
covered. He quickly discovered that he could use trim and power
presets (known settings) to get the airplane to perform the way he
wanted. He discovered the he could hear and feel the short-term
airspeed variations. In short, he didn't need those instruments. The
result is that he felt more comfortable leaving his head out and just
flying the airplane.
So, if you are a VFR pilot in a VFR airplane, you just don't need to
worry about things that much.
Now the pilot with the advanced IFR aircraft who plans to fly in IMC
is a different story. Now you become dependent on those things in the
panel in order to safely complete a flight and get on the ground.
I thought Bob's story was rather telling. Here was a guy who had the
training and had redundant systems but still managed to kill himself
and his passengers. What went wrong? My guess is that, when presented
with conflicting information from both working and failed
instruments, he found it impossible to determine what the airplane
was doing so he proceeded to make things worse. That he managed to
get the airplane into a loop and/or a roll just boggles my mind. I
have to think that, had he pulled the throttle to idle, dropped the
gear, let go of the yoke, and used the rudder pedals to stop the
aircraft's rotation, he probably would have survived.
Now we have to assume that, unless he had a trim runaway, the
airplane was trimmed for level flight. If he didn't put in any pitch
commands the airplane would continue to seek its trim airspeed.
Dropping the gear and pulling the throttle to idle was just a way to
get the airplane to descend without gaining a lot of extra speed and
to control speed after he lost it. (Besides, part of standard spin
recovery is "power to idle".) Now if he was spinning using the
rudders to stop the rotation would have stopped the spin. At that
point the airplane would have righted itself and sought its trim
airspeed again.
But this thread started out with what fails and what to do about it.
The increased capability of advanced avionics tends to turn us into
systems managers, not pilots. If you think about someone depending on
their primary flight display (PFD), i.e. the thing that displays your
whole six-pack in one display (as opposed to the multi-function
display that displays moving map, wether, traffic, etc.) and then how
they react when it goes blank on them, you can see why the FAA might
be concerned.
We are putting more and more emphasis on fewer devices, more complex
devices. All our eggs are in one basket so to speak. When the basket
falls we have quite a mess. What do you do?
You know, one of the things I would do is work with a CFI to develop
a scenario-based education program for MY airplane. Jeff, you made an
interesting point about a CFI who won't use the devices in the panel
and won't talk to ATC. You don't want that CFI to help you in this
case. You want one who will sit in your cockpit, learn its
capabilities, and then do the, "what if this thing here failed,"
scenario. He might not even know the answer but will work with you to
find the answer and then work with you to train up on it until you
can deal with that scenario. Then you write it down and it becomes
part of your system failure checklist. It is a lot easier to think
about that stuff on the ground than when you are in IMC conditions
with moderate turbulence.
As for your nearest facility/frequency function, I have that in my
Apollo GX-60. Pretty spiffy. I hit the "nearest" button; select
airport, VOR, or NDB; then scroll through the facilities starting
with the nearest. If I press the "info" button all the information is
there -- frequencies, runway heading and length, etc. It is even fed
into my SL-30 so the VOR frequencies are right there. Select, dial,
enter. (Those are the actual keystrokes.) Pretty neat.
Even though I know how, I almost never use it.
I don't use it because it doesn't help my situational awareness.
Looking at a chart helps my situational awareness because it is a
much better integration of information. Faster access too. I
immediately see where I am and my relationship to all the facilities
around me. Freqs are there too. Selection is easy.
Now if they somehow managed to combine a touch-screen with the VOR
receiver maybe that would work for me. Touch the VOR receiver and
then touch the station on the moving map. POOF! VOR receiver
channelized and the OBS spins to center the needle. That might work.
Same with comm. (But how do you tell it you want tower, ATIS,
approach, or ground?)
Getting on to redundancy. I think my Aztec panel is a good study in
this. I got a bunch of new Apollo gear to put in my CJ6A project.
(GX-60 GPS/comm, SL-30 Nav-Com, SL-70 xpdr, SL-15 audio panel, Sandel
EHSI) Then I got to thinking about how often I planned to fly hard
IFR in my CJ6A. How about "never". It seemed like all that wonderful
gear would go to waste there. So I put it in my Aztec. Quite a nice
panel.
But I did one other thing too. I kept the old KNS-80 RNAV (VOR/ILS/
DME/RNAV). I gave it its own dedicated indicator. These were isolated
from everything else in the panel. I know that if my super-whizzy
stuff goes TU, the KNS-80 and its antiquated cross-needle VOR/LOC/GS
indicator will let me navigate to my destination and then shoot an
approach, including an ILS.
I also kept the old vacuum-driven heading indicator (DG). (Old Bob --
it has a needle-ball, not a TC.) When I am feeling a bit less poor I
will try to talk the FSDO into letting me put a Dynon D10. I don't
plan to replace anything, just have the Dynon there. If the Dynon
fails I will fly the old six-pack.
Going back and reading this (it is already after midnight and my
brain quit an hour ago) I see I rambled all over. Oh well. Hopefully
it will spark some thinking about this. I know I spend entirely too
much time thinking about this.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
morgjj
Posted: Thu Jul 20, 2006 10:01 pm Post subject: Electric failure |
Maybe...But it is good food for thought, I appreciate the feedback/suggestions!
Jeff
Tim(at)MyRV10.com Guest
Posted: Fri Jul 21, 2006 10:19 am Post subject: Electric failure |
Jeff, I don't know if I showed you much of this on the
demo flight, but that chelton system does all of this, and
very well. Hit NRST, and the you can choose from a whole
long list of things, so you've always got the nearest
frequencies, airports, VOR's, WX, and much more, just on
a quick button push. Very neat stuff.
As for some of the points I have read over the past few days, I think
that there is merit in many of them. I think we could discuss all of
them at length. The interfaces on the systems are very different, each
with strong points and weak points. I think that I have often thought is
that the radio should have the closest frequencies in a list off the
tuning button as I fly along. I think it would be great to punch a
button and have a list of the closest ATIS or AWOS stations from my
position with a distance and bearing. Same for VORs. On the Garmin's
you can go to the nearest page and select, but it is a lot of dialing to
get there. With VOR's it isn't like I am going to dial much else in the
NAV radio. If I were 5000' or less, a list of airport CTAF or ATC
controlling facilities on the standby list would be helpful too.
Imagine hitting a button on the radio, and scroll though a list with the
frequency, definition, and direction right on the screen, with the
closest ones first... There is a feature that would lighten pilot loads
in difficult times. But all that said, maybe Brian would want it
differently than that. Never would claim that I am normal by any means.
I am building an airplane after all.
