m(at)grassfam.com Guest
Posted: Sat Mar 16, 2019 3:33 am Post subject: Fitting already built and flown glider wings to a new fusela |
Hello all,
I would like to get some input from the group what the best method would be to fit already flown glider wings to a XS Tri gear fuselage. The fuselage has not yet the wing lift sockets or wing tie bar installed. Also the short wings are not closed.
Normally, as I understand, the process would be to fit first the short wings to the fuselage and then match the glider wings. However, since the glider wings are completely done and already flown on another fuselage, it makes sense to me to reverse the procedure and fit the glider wings first and then match the short wings.
My real question now is:
How to replace the aluminum inserts for the lift pins on the short (or glider) wings. Does anybody know the type of aluminum is used and what the procedure would be?
I believe, since the short wings are still open and it’s fiberglass , it would be easier to perform this job on the short wings instead the glider wings.
Any thoughts?
A266 Tri-Gear
Michael Grass
Sent from my iPad
