pete(at)flylightning.net Guest
Posted: Thu Jul 20, 2006 1:02 pm Post subject: [esqualtalk] Lightning Flight review |
Hi Everyone,
Make sure to stop and see Buz Rich’s Esqual LS (Lightning Stuff) airplane at OSH. It is parked in the first row by the big arch main entrance to the flightline (prime spot!). For sure this is the best looking Esqual ever and the fastest one as well. Certainly worth a look if you at Airventure.
Pete
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
Sent: Sunday, July 16, 2006 8:55 AM
Subject: Re: [esqualtalk] Lightning Flight review
Hi Laurie,
Your glider comparison to landing the Esqual is right on. In fact, flying it is probably somewhat like flying a motor glider that can go really fast. I have never flown a motor glider (I do have a commercial glider rating) but with the relatively long, high aspect ratio wing and the 19 to 1 glide ratio, the Esqual does not want to stop flying. Speed control on final is important to get down and stopped short. Also, down low on a hot bumpy day, the Esqual can be a somewhat uncomfortable ride unless you slow down. Of course that same wing allows you to get high in a hurry and be above the bumpy air and utilize the fast cruise speeds.
Good point on using the Lightning's full 45 degrees of flaps to insure short landings, as you say, into someone's back yard. It would certainly allow a really steep approach. And it is always good to have extra "tricks" in your "bag of tricks" when something goes wrong. The reason I mentioned that is the high drag situation (45 flaps) kind of puts you behind the "power curve" and really took a long time to reestablish a climb rate during my dirty stalls and that could potentially be a problem on a last minute go around. Your mileage may vary. Another thought that I think I failed to mention - the Lightning's rudder authority and rudder pressures are slightly better and slightly lighter than my Esqual. Therefore, I found that slips were a little easier and more effective in the Lightning. So that is another "trick" for your "bag of tricks" that you will have on board.
At this point I would think that the tail dragger Lightning is just a future thought. The guys in Shelbyville are just too busy now to work on the changes, but I am fairly confident that if will happen - sometime. Some future builder may beat them to it. I should be a relatively easy modification once the geometry of the main gear is worked out. I can see two ways to do that - either added to the motor mount angled aft, or added to the central beam assembly (as is the current main gear) at the proper angle. Adding the tail wheel would probably be the easy part. But it sure would be a great looking airplane. Not that it isn't already.
Blue Skies,
Buz
PS: Leg pulling? Maybe a little.
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
sky2000diver(at)yahoo.com Guest
Posted: Thu Jul 20, 2006 1:33 pm Post subject: [esqualtalk] Lightning Flight review |
Can anyone help me with some questions about the
lightning? john
--- owner-lightning-list-server(at)matronics.com
<pete(at)flylightning.net> wrote:
| Quote: | Hi Everyone,
Make sure to stop and see Buz Rich's Esqual LS
| Quote: | at OSH. It is parked in the first row by the big
| Quote: | flightline (prime spot!). For sure this is the best
| Quote: | the fastest one as well. Certainly worth a look if
you at Airventure.
Pete
_____
On Behalf Of
| Quote: | N1BZRich(at)aol.com
Hi Laurie,
right on. In fact,
| Quote: | flying it is probably somewhat like flying a motor
| Quote: | fast. I have never flown a motor glider (I do have
a commercial glider
| Quote: | rating) but with the relatively long, high aspect
| Quote: | glide ratio, the Esqual does not want to stop
| Quote: | final is important to get down and stopped short.
| Quote: | bumpy day, the Esqual can be a somewhat
| Quote: | down. Of course that same wing allows you to get
| Quote: | above the bumpy air and utilize the fast cruise
speeds.
| Quote: | short landings, as you say, into someone's back
| Quote: | allow a really steep approach. And it is always
| Quote: | in your "bag of tricks" when something goes wrong.
| Quote: | that is the high drag situation (45 flaps) kind of
puts you behind the
| Quote: | "power curve" and really took a long time to
| Quote: | my dirty stalls and that could potentially be a
| Quote: | around. Your mileage may vary. Another thought
| Quote: | mention - the Lightning's rudder authority and
| Quote: | better and slightly lighter than my Esqual.
| Quote: | were a little easier and more effective in the
| Quote: | another "trick" for your "bag of tricks" that you
will have on board.
| Quote: | future thought. The guys in Shelbyville are just
| Quote: | the changes, but I am fairly confident that if will
| Quote: | future builder may beat them to it. I should be a
relatively easy
| Quote: | modification once the geometry of the main gear is
| Quote: | two ways to do that - either added to the motor
| Quote: | to the central beam assembly (as is the current main
gear) at the proper
| Quote: | angle. Adding the tail wheel would probably be the
| Quote: | would be a great looking airplane. Not that it
isn't already.
Blue Skies,
Buz
Posted: Thu Jul 20, 2006 2:06 pm Post subject: [esqualtalk] Lightning Flight review |
Ask away!
Pete
Posted: Thu Jul 20, 2006 2:23 pm Post subject: [esqualtalk] Lightning Flight review |
I live near detroit michigan, and would like to find
someone close that can show me a lightning as im
interested in purchasing a lsa.
Ask away!
Pete
Posted: Thu Jul 20, 2006 3:10 pm Post subject: [esqualtalk] Lightning Flight review |
No Lightnings near Detroit yet. Catch us at OSH or visit us in Tennessee.
Pete
Posted: Thu Jul 20, 2006 6:47 pm Post subject: [esqualtalk] Lightning Flight review |
Work load doesnt allow me to get away for a weekend or
during the week. A road trip just isnt possible right
now to check out this aircraft but have taken a demo
flight on the ct by flight design and really like it
but like the written stats of the lightning
better....so, im stuck for now.
Pete
