braided bonding straps
armywrights(at)adelphia.n
PostPosted: Sun Jul 16, 2006 6:32 pm    Post subject: braided bonding straps Reply with quote
I know I can order these to a pre-set length, but I’ve removed probably 2.5’ of braid shield from some RG-58 and wondering what all I can do with it.  I know I can use attach a connector and use it as a circuit ground,
but I’m wondering if it will also work for some of these static charge installations:  aileron to wing, flap to wing, elevator to HS; and some of the heftier installations: engine to firewall stud, battery negative post to airframe, etc.
Rob Wright
RV-10
rvbuilder(at)sausen.net
PostPosted: Mon Jul 17, 2006 5:44 am    Post subject: braided bonding straps Reply with quote
Rob,
  I probably wouldn’t use it for anything too heavy, but it is perfect for static bonding and other lightweight grounds.
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert G. Wright
Sent: Sunday, July 16, 2006 9:28 PM
Subject: braided bonding straps
Rob Wright
RV-10
FLYaDIVE(at)aol.com
PostPosted: Thu Jul 20, 2006 3:28 pm    Post subject: braided bonding straps Reply with quote
In a message dated 7/16/06 10:34:36 PM Eastern Daylight Time,
armywrights(at)adelphia.net writes:
I know I can order these to a pre-set length, but I've removed probably 2.5'
but I'm wondering if it will also work for some of these static charge
to
airframe, etc.
Rob Wright
RV-10
Rob:
Coax shield would work but it is not as heavy a gage as you should obtain
from a place like ACS. I would Guess the gage of shielding is about equivalent
to un-insulated 16 or 14 AWG. It would sure work as a static dissipater.
When picking the proper coax make sure you use the silver color braid type.
This is the one that has the copper braid nickel coated and that will work
well in a moisture environment. The coax you wish to use is RG-58A/U.
If you wish to go to a larger gage wire by going the coax route try RG-8A or
RG-214.
Barry
"Chop'd Liver"
nuckollsr(at)cox.net
PostPosted: Thu Jul 20, 2006 5:12 pm    Post subject: braided bonding straps Reply with quote
Coaxial cable shield is a reasonable material for fabricating
your own braided jumpers. What most folks don't know about the
jumpers we used to sell is that they were THREE concentric
conductors. You can take lengths of braid salvaged off a piece
of coax, bunch it up, slip another length inside. Smooth the outside
over the inside, bunch it again and add another length. This is
how you get enough copper in the conductor to reasonably fill
a 2AWG terminal. The fatter coaxes work for this. RG-8 is single
layer shield. You can use RG-214 or similar (double braid) and
put a second chunk inside the first for total of FOUR concentric
layers.
