jluckey(at)pacbell.net Guest
Posted: Wed Oct 30, 2019 11:17 am Post subject: Brass Current-carrying Calcs |
I want to calculate the current-carrying capability of a piece of brass bussbar.
Once upon a time I had a chart that showed something like circular mil & resistance per foot for brass.
I've Googled for about 20 min but not able to find what I want. (everything I'm finding is about copper & aluminum).
Any help is appreciated,
Jeff
subknave
Joined: 17 Jun 2013 Posts: 17 Location: portsmouth, va
Posted: Wed Oct 30, 2019 11:47 am Post subject: Brass Current-carrying Calcs |
Brass has 28% the capacity of copper but since the runs it will go through are so short and the amperage would be fairly low (<100 amps I am guessing) it is usually not a problem. The question is why not copper?
Rodney Hall
Quote: | On October 30, 2019 at 3:03 PM Jeff Luckey <jluckey(at)pacbell.net> wrote:
Jeff
stinsonwagon(at)yahoo.com Guest
Posted: Wed Oct 30, 2019 12:27 pm Post subject: Brass Current-carrying Calcs |
I think this is the chart you are looking for
see attached pdf
On Wednesday, October 30, 2019, 02:02:28 PM MDT, r.r.hall(at)cox.net r.r.hall(at)cox.net <r.r.hall(at)cox.net> wrote:
Brass has 28% the capacity of copper but since the runs it will go through are so short and the amperage would be fairly low (<100 amps I am guessing) it is usually not a problem. The question is why not copper?Rodney Hall Quote: | On October 30, 2019 at 3:03 PM Jeff Luckey <jluckey(at)pacbell.net> wrote: I want to calculate the current-carrying capability of a piece of brass bussbar.
Jeff
Description: |
 Download |
Filename: |
resistance_chart.pdf |
Filesize: |
335.85 KB |
Downloaded: |
305 Time(s) |
Posted: Wed Oct 30, 2019 12:39 pm Post subject: Brass Current-carrying Calcs |
At 02:45 PM 10/30/2019, you wrote:
Quote: | Brass has 28% the capacity of copper but since the runs it will go through are so short and the amperage would be fairly low (<100 amps I am guessing) it is usually not a problem. The question is why not copper? |
Excellent question. Consider:
https://tinyurl.com/y333wjru
https://tinyurl.com/y3w7swc3
https://tinyurl.com/y5uy46v8
What size(s) are your proposed bus
bar(s)? I may have some pieces
in my 'good scrap' that would suffice.
Posted: Wed Oct 30, 2019 1:59 pm Post subject: Brass Current-carrying Calcs |
Thanks Rod & Bob for your responses.
The short answer to the question of "why not use copper?" is that I've go a whole bunch of brass in my scrap-metal pile.
I did the math using the values for copper then adjusted for brass and the voltage drop at rated current is 37 mV, which I think I can live with
Thanks for the input,
-Jeff
On Wednesday, October 30, 2019, 01:46:38 PM PDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
