FLYaDIVE(at)aol.com Guest
Posted: Fri Jul 21, 2006 11:53 am Post subject: What have you had to fix on the road? |
My Plane:
Impulse coupler - Slick Mag
Dead Battery
Detonation - BAD FUEL - Lousy AvGas! - New Engine - Thank you!
Other people's planes:
Flaps - Failure to retract
Flaps - out of rig
Dead Battery
Battery - Broken cap (sealed battery)
Battery - Corrosion
Position lights - NAV
Alternator Field CB - Burnt - By passed with inline fuse
Alternator Housing - Loose
Alternator Belt - Broke
Alternator B+ - Broke wire
MAG Switch - Internal Ground - Grounded both Mags (P leads)
Boost Pump - Clogged with debris - added auto filter
Nose Strut - Low
Vacuum Pump - Failure - replaced
Strobe Noise - Shielded wire and Radio Shack filter
Master Switch - High internal resistance - replaced
Radio Problems (many) - CLEANED CONTACTS and GROUNDS
I carry a 45 pound tool box --- 'Have tools - Will Travel'
Barry
"Chop'd Liver"
lors01(at)msn.com Guest
Posted: Sat Jul 22, 2006 8:14 am Post subject: What have you had to fix on the road? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Opps, forgot the temporary exhaust system that fell apart in McKenny TX. Fixed with borrowed safety wire. I carry a roll of it when traveling now.
Tracy
