cooprv7(at)yahoo.com Guest
Posted: Thu Apr 02, 2020 12:27 pm Post subject: Pitot heat not heating |
I have a Gretz heated pitot tube that has decided to stop heating. The red “Temp Low” and yellow “heat on” lights come on but no spike in electricity drain and no heat. Before I start the troubleshooting I just wanted to ask if there are any known trend items to check first?
Marcus
Posted: Thu Apr 02, 2020 1:20 pm Post subject: Pitot heat not heating |
In the event my 17 year old pitot tube is toast I found the Garmin heated pitot tube for experimental aircraft at Aircraft Spruce. Much cheaper plus is designed for the G3X which I now have. Any experience with it? It appears to use the Gretz mount but any confirmation?
Thanks again,
Marcus
| Quote: | On Apr 2, 2020, at 4:22 PM, Marcus Cooper <cooprv7(at)yahoo.com> wrote:
Marcus
Tim Olson
Posted: Thu Apr 02, 2020 2:38 pm Post subject: Pitot heat not heating |
On my RV-14 build, I didn't try to even find the Gretz anymore since the
Garmin
is out and the Gretz is harder to come by. So I have the heated Garmin
in my
RV-14 and it works great. I'd buy one in a heartbeat for my RV-10 if my
Gretz
even hiccups. It does use the same mount, I think. I don't remember buying
the mount for the -14 but it was the same mount I used on the 10, which was
the Gretz.
On 4/2/2020 4:15 PM, Marcus Cooper wrote:
Thanks again,
Marcus
> Thanks,
> Marcus
rleffler
Posted: Thu Apr 02, 2020 3:00 pm Post subject: Pitot heat not heating |
Me too, I installed a Dynon heated pitot after the Gretz melted close on a 30 minute flight.
_________________ Bob Leffler
N410BL - Phase I
dmaib(at)mac.com Guest
Posted: Thu Apr 02, 2020 3:28 pm Post subject: Pitot heat not heating |
My Gretz gave up the ghost about 18 months ago. I found a complete Gretz unit on VAF and bought it for a great price. Troubleshooting pointed to the board, so I installed it and it worked great for a few months. Then it failed again, so I bought the Garmin, installed it in the Gretz mount, and all is well. The Gretz served me well for about 10 years of constant use. I could never get any response from Angus Aviation, so it was time to move on.
David Maib
| Quote: | On Apr 2, 2020, at 18:47, Tim Olson <Tim(at)myrv10.com> wrote:
On my RV-14 build, I didn't try to even find the Gretz anymore since the Garmin
is out and the Gretz is harder to come by. So I have the heated Garmin in my
RV-14 and it works great. I'd buy one in a heartbeat for my RV-10 if my Gretz
the Gretz.
> Thanks again,
> Marcus
>> Thanks,
>> Marcus
Bob Turner
Posted: Thu Apr 02, 2020 10:55 pm Post subject: Re: Pitot heat not heating |
I have the Dynon pitot tube with temperature controlled heater and AOA port. Fits in the same mount, I’m pretty sure. No complaints.
_________________ Bob Turner
RV-10 QB |
rleffler
Posted: Fri Apr 03, 2020 1:03 am Post subject: Pitot heat not heating |
I can confirm that both the Dynon pitots do indeed fit in the Gretz mount.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Bob Turner <bobturner(at)alum.rpi.edu>
Sent: Friday, April 3, 2020 2:55:14 AM
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Subject: Re: Pitot heat not heating
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=495570#495570
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; -Matt Dralle, List Admin.
N410BL - Phase I
Kelly McMullen
Posted: Fri Apr 03, 2020 5:35 am Post subject: Pitot heat not heating |
AFAIK most pitot mounts and pitot assemblies conform to the AN standard.
Dynon offers a pitot mount designed for RVs.
https://dynonstore.com/#!/AOA-Pitot-Mount-Bracket/p/65689077/category=13788255
Sent from my TRS-80 Model 100
On Fri, Apr 3, 2020 at 2:07 AM Bob Leffler <bob(at)thelefflers.com> wrote:
[quote] I can confirm that both the Dynon pitots do indeed fit in the Gretz mount
A&P/IA, EAA Tech Counselor
KCHD |
