FLYaDIVE(at)aol.com Guest
Posted: Mon Jul 24, 2006 2:31 pm Post subject: Heated pitot tube connections |
In a message dated 7/24/06 5:55:36 PM Eastern Daylight Time,
will(at)willcrook.com writes:
| Quote: | The terminals are sinply two straight rods extending from the pitot tube
chassis, and I think I could craft some female spade fittings to slip on,
and
| Quote: | securing it with some RTV. Obviously, it would be a sad day if these two
leads were to short, but all of these $88.50's keep adding up. Sometimes,
when the widget looks very straightfoward, I tend to try and get cheap
Thoughts?
Will:
I like the way you think. You will have to do a little hunting but there are
round slip on connectors just like the spade design but only one half and
larger in size to handle the current. The ceramic type is exactly that but with
a ceramic case.
As for them shorting or causing a problem ... Distance is always a great
insulator and you could also make one from a small piece of Teflon ... If you go
this way you will need something that can handle the heat.
Will, you said something that caught my eye ... Ground leads ... Do not use
the planes ground as your return line. Run a separate wire so that you have B+
and Neg wires going out there. THEN if you wish ground the Negative out at
the wing tip. This will greatly help with other wiring such as your Strobe and
Nav Lights. Most problems over time are related to a poor ground.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Bob McC
Posted: Mon Jul 24, 2006 5:04 pm Post subject: Heated pitot tube connections |
Barry;
I may be mistaken, but I believe this advice on grounding is totally contrary to what has been taught on this list for the past several years. My understanding of Lectric Bob's advice and lessons on grounding, are, that local grounds are OK for such things as pitot heat, position lights etc. but that running a ground wire to a wingtip for an accessory, as you suggest, and then grounding it there as well is a no-no as this is likely to create a ground loop. Grounds should be local OR run to the "forest of tabs" ground point on the firewall. They should not be both for any single item. (and local grounds are only used for certain specific items as described in "The Connection".)
Bob McC
[b]---
_________________ Bob McC
Falco #908
(just starting) |
nuckollsr(at)cox.net Guest
Posted: Mon Jul 24, 2006 6:20 pm Post subject: Heated pitot tube connections |
At 08:57 PM 7/24/2006 -0400, you wrote:
| Quote: | Barry;
Bob McC
This needs some clarification. "Ground Loops" ALWAYS exist when
multiple accessories ground to DIFFERENT parts of the airplane.
Ground loops are not always evil. The problems arise when
potential victims (radios, audio systems, instrumentation,
etc) SHARE the airframe (or distributed ground system in a
composite) with potential antagonists like alternators. Alternators
do not become antagonists until they're asked to supply substantial
currents for the purpose of running high power accessories like landing
lights and pitot heaters. Discharged batteries are also "high power"
loads while being replenished. I had a builder complain about alternator
noise in a system that went away after a few minutes of flight . . .
his battery was the major antagonistic contributor to ground loop
noise that went away when the battery assumed recharge.
Now, one may ground all the antagonists you wish to the
airframe or distributed ground 'cause all they can do is
yell at each other and as long as they a deaf . . .
ist macht nicht.
The things that are vulnerable are immune from any yelling
going on elsewhere as long as their respective and collective
grounds DO NOT participate in the noisy ground loop. Best yet,
if all potential victims share a single point (or slightly
distributed single point as shown in the audio systems
chapter) then there will be order in the world.
Hence the suggestion about local grounds. Notice that all the
devices called out are not potential victims and they participate
only in the generation of noise because they're high power
loads for the noisiest device in the airplane, the alternator.
So you may ground them at any convenient location for good
bonding without regard to potential noise issues.
Posted: Mon Jul 24, 2006 6:30 pm Post subject: Heated pitot tube connections |
At 02:44 PM 7/24/2006 -0700, you wrote:
| Quote: | I have a standard heated pitot tube. The instructions call for an AN-3115
connector to terminate the power and ground leads. Alas (I love using
that word...), I don't have this little gem. Looking on the B&C site, I
don't see anything resembling what I need. AS&S has the phenolic
connector, but it is really pricey at $88.50. The terminals are sinply
two straight rods extending from the pitot tube chassis, and I think I
could craft some female spade fittings to slip on, and securing it with
some RTV. Obviously, it would be a sad day if these two leads were to
short, but all of these $88.50's keep adding up. Sometimes, when the
Thoughts?
I have a client who asked me to look into alternative sources
for the AN3115 connector. I've studied some of the connection
science issues and looked at the processes available. Problem
is that the connection at the pitot tube is subject to elevated
operating temperatures + extended 3x inrush currents. Building
a really GOOD AN3115 is not a trivial task.
Problem is that this is such a low volume part that by the time
we tool up to build a decent part, the non-recurring costs
are breathtaking.
If it were my airplane (and if I were supplying pitot tubes) I
would silver solder 12", 14AWG Teflon pigtails onto the pitot
tube pins. Cover the joint in Teflon heat shrink and then make
connections to the airplane at the ends of the pigtails with
some attractive, robust splice. PIDG knife splices covered with
heat shrink tickle my fancy.
Very straightforward, very cheap.
< with experiment. >
< --Lawrence M. Krauss >
fvalarm(at)rapidnet.net Guest
Posted: Mon Jul 24, 2006 6:53 pm Post subject: Heated pitot tube connections |
What about soldering wire female leads to the terminals.
Bevan
RV7A finish kit
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Crook
Sent: Monday, July 24, 2006 2:44 PM
To: aeroelectric-list-digest(at)matronics.com
Subject: AeroElectric-List: Heated pitot tube connections
I have a standard heated pitot tube. The instructions call for an AN-3115 connector to terminate the power and ground leads. Alas (I love using that word...), I don't have this little gem. Looking on the B&C site, I don't see anything resembling what I need. AS&S has the phenolic connector, but it is really pricey at $88.50. The terminals are sinply two straight rods extending from the pitot tube chassis, and I think I could craft some female spade fittings to slip on, and securing it with some RTV. Obviously, it would be a sad day if these two leads were to short, but all of these $88.50's keep adding up. Sometimes, when the widget looks very straightfoward, I tend to try and get cheap
Thoughts?
dsvs(at)comcast.net Guest
Posted: Mon Jul 24, 2006 7:57 pm Post subject: Heated pitot tube connections |
Posted: Mon Jul 24, 2006 8:29 pm Post subject: Heated pitot tube connections |
Posted: Tue Jul 25, 2006 1:21 am Post subject: Heated pitot tube connections |
In a message dated 7/24/06 10:55:02 PM Eastern Daylight Time,
fvalarm(at)rapidnet.net writes:
| Quote: | What about soldering wire female leads to the terminals.
Bevan
RV7A finish kit
Brevan:
Soldering in 99% of the cases is a NO-NO. Even though we are experimental we
still have to follow good building procedures and AC 43-13 A&B. Soldering
creates HARD POINTS that are subject to vibration failure. Do I solder? In
some cases YES But not in this case. Use crimp-ons.
Barry
"Chop'd Liver"
time."
Yamashiada
Posted: Tue Jul 25, 2006 1:34 am Post subject: Heated pitot tube connections |
In a message dated 7/25/06 12:03:08 AM Eastern Daylight Time,
dsvs(at)comcast.net writes:
| Quote: | Bob,
Is the silver solder just for heat resistance? If I am not mistaken silver
solder is not as good a conductor as tin/lead, or is that an old wives
tale?
| Quote: | Don
Don:
There are many Old Wife's Tails out there and the Internet does a tremendous
job at propagating them and producing even more. But, SILVER is a Much, Much
better conductor than tin or lead. Just look at the Periodic Table of
Elements. Silver has more free electrons than the other two. Or just look up the
conductivity of silver. While you are at it check out GOLD, PLATINUM, COPPER and
especially ALUMINUM.
And then consider how good your electrical system is.
Silver solder is around for other reasons other than conductivity. STRENGTH
is its major consideration. It is quite a bit stronger than electrical
solder. Silver solder is broken down into two classifications:
Silver bearing (NO! Not like ball bearings) and Percentage Silver. Unless
you request a particular percentage you will get silver bearing and that is only
3% Silver MAX.
BTW ... If you have purchased solder in the past few years, especially if
you purchased it through Radio Shack you did NOT get Tin/Lead solder ... The
LEAD has been removed. Too many environmentalist chewing on circuit boards.
Barry
"Chop'd Liver"
time."
Yamashiada
Posted: Tue Jul 25, 2006 7:31 am Post subject: Heated pitot tube connections |
At 05:14 AM 7/25/2006 -0400, you wrote:
> Bevan
> RV7A finish kit
Brevan:
No so. See:
http://aeroelectric.com/articles/rules/review.html
http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
Solder and crimp are of equal reliability and, for the
most part, interchangeable wire joining technologies.
Obviously they require different tools and skills but
aside from matters of convenience or personal preference,
there is no reason to pick one technology over the other.
The prejudices against solder are largely fabricated of
misunderstanding of the science and techniques.
Posted: Tue Jul 25, 2006 8:02 pm Post subject: Heated pitot tube connections |
At 05:29 AM 7/25/2006 -0400, you wrote:
> Bob,
silver
tale?
> Don
Don:
up the
COPPER and
Let's consider simple ideas that do not ride on anyone's tales . . .
The amount of solder in series with the electron flow through
any joint is small compared to the total circuit resistance. Yes,
lead has 13x the resistance of copper but consider that when you
twist two wires together, the joint is as good as it will ever get
right at that moment. Adding solder serves to immobilize and encapsulate
the joint to prevent future degradation due to corrosion and loss of
pressure.
In low current, hi impedance circuits (like surface mounted integrated
circuits) the higher resistance of solder compared to the conductors
being joined does not add significant resistance to the system.
| Quote: | Silver solder is around for other reasons other than conductivity. STRENGTH
is only
3% Silver MAX.
To amplify on this, "silver solder" is a term that can apply to
MANY alloys for different purposes. Silver bearing solder is low
temp stuff used in specialized electronics where silver plated
parts are being assembled and you don't want the solder to dissolve
silver from the base metal. An example is seen here:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=093-584
Note the very low melting point of this material. Ordinary soldering
irons do fine.
Hard solders melt at much higher temperatures. Here's an example:
http://www.jewelrysupply.com/index.php?main_page=product_info&cPath=16_25_260&products_id=8243
This pretty cool product combines the flux and powdered silver solder
in a dispensing syringe. Ideal for making the pitot tube pin-to-wire
joints being considered in this thread. Note the higher melting point.
This takes a gas flame.
