Fuel Tank Fittings
rogersheridan(at)mac.com
PostPosted: Wed Jun 17, 2020 2:13 am    Post subject: Fuel Tank Fittings Reply with quote
I hope to find two of these fuel tank outlet fittings originally produced for Graham Singleton in mod 10823.
Please message me direct if you can help.
Many thanks,
Roger
[img]cid:B02050FD-A0AB-4D11-9207-8CCBE67F2D5C[/img]
 Filesize:  720.98 KB
 Viewed:  5882 Time(s)
h&jeuropa
PostPosted: Wed Jun 17, 2020 7:43 am    Post subject: Re: Fuel Tank Fittings Reply with quote
Roger,
If you can't find them in the UK, I'm pretty certain I have them.
Jim
PostPosted: Wed Jun 17, 2020 12:10 pm    Post subject: Fuel Tank Fittings Reply with quote
Hi Jim,
Awesome.
Does that mean you seriously considered alu fuel lines then chose not to!!
I see pro’s & cons to both systems.
What is super disappointing is the fuel smell I get using Gates Barricade from Amazon
https://www.amazon.com/gp/product/B00498G5QC/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
I sometimes wonder if it is counterfeit?
A UK supplier shows white liner which is not noticeable on my hose.
https://www.moss-europe.co.uk/fuel-hose-gates-barricade-ethanol-proof-5-16-id-per-metre-gfh1031x.html
Your opinions are of interest!
Roger.
PS Flew my classic into RAF Waddington today, launch point for the dam buster raids!
[img]cid:D78FD3BA-F082-42DF-87D1-E75854701740(at).home[/img]
On 17 Jun 2020, at 16:43, h&amp;jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> Europa-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>Roger,If you can't find them in the UK, I'm pretty certain I have them.JimRead this topic online here:http://forums.matronics.com/viewtopic.php?p=496882#496882
 Filesize:  2.12 MB
 Viewed:  5855 Time(s)
PostPosted: Thu Jun 18, 2020 6:40 am    Post subject: Fuel Tank Fittings Reply with quote
Whoops that was meant to go direct, not to the list.
On 17 Jun 2020, at 21:06, Roger Sheridan <rogersheridan(at)mac.com (rogersheridan(at)mac.com)> wrote:
Hi Jim,
Awesome.
Roger.
<IMG_5583.jpeg>
rowlandcarson(at)gmail.co
PostPosted: Thu Jun 18, 2020 8:14 am    Post subject: Fuel Tank Fittings Reply with quote
Roger - I turned up my own versions of these from aluminium bar stock - see:
http://www.rowlandcarson.org.uk/aviation/europa_435/making_tank_adaptors.php
and
http://www.rowlandcarson.org.uk/aviation/europa_435/tank_adaptors.php
and
http://www.rowlandcarson.org.uk/aviation/europa_435/tank_adaptor_c_fitted.php
Sorry, I don’t feel I want to spend the time on making them again just now, but if you are really stuck I might consider it!
Alternatively, if you know of or can find a model engineering society in your neighbourhood one of those guys might be happy to do the job for you. I attach my dimensioned drawings of the 3 slightly different adaptors I made. I didn’t bother to mill flats on them as I didn’t have a milling machine at that time and (although possible) it would have been a bit tedious doing the milling on the lathe.
Hope this is of some use.
in friendship
Rowland
tank_fittings.pdf
 Filename:  tank_fittings.pdf
 Filesize:  50.09 KB
 Downloaded:  437 Time(s)
