Posted: Mon Aug 31, 2020 7:58 am Post subject: Revmaster installation manual? |
Does anyone have a .pdf copy of a Revmaster installation
manual for 2300, 3000 engines . . . or both?
If there's a download link for either . . . that would
be fine too.
Thanks!
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Mon Aug 31, 2020 3:16 pm Post subject: Revmaster installation manual? |
At 05:38 PM 8/31/2020, you wrote:
Quote: | Bob
Included is the section from the Revmaster manual that deals with the generator and CDI ignition. I'm looking forward to more from you on the Revmaster problem so I can order a new stator and rewire with confidence that the second time around will be the final time. |
Yeah, I've seen this 'wiring diagram' . . . sad
Everything else I've seen/read about this engine
engenders a lot of confidence. When you pay out
killobux for a modern, strongly promoted engine you
should get something better than this in the way
of installation, performance and system integration.
Can I have your burned stator?
N509RV(at)eckenroth.com Guest
Posted: Mon Aug 31, 2020 4:27 pm Post subject: Revmaster installation manual? |
The stator is still installed in the engine. I am currently flying on battery only. When the solution to the Revmaster debacle is clear, I will get a new stator. Replacement of the stator is not trivial as the engine must be removed from the airframe. However when it is finally removed I will send it your way if still interested.
Paul
On Mon, Aug 31, 2020 at 7:21 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Posted: Mon Aug 31, 2020 7:01 pm Post subject: Revmaster installation manual? |
At 07:22 PM 8/31/2020, you wrote:
Quote: | The stator is still installed in the engine. I am currently flying on battery only. When the solution to the Revmaster debacle is clear, I will get a new stator. Replacement of the stator is not trivial as the engine must be removed from the airframe. However when it is finally removed I will send it your way if still interested. |
Sounds like a deal . . .
Do I surmise correctly that you ran one alternator until
it toasted, then ran the second?
Posted: Tue Sep 01, 2020 8:09 am Post subject: Revmaster installation manual? |
I did run one generator at a time. Unfortunately, when it toasted it also removed the second generator. This also happened to a friend with the same engine and battery. So much for redundancy.
Paul
On Mon, Aug 31, 2020 at 11:12 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Posted: Tue Sep 01, 2020 1:04 pm Post subject: Revmaster installation manual? |
At 11:06 AM 9/1/2020, you wrote:
Quote: | I did run one generator at a time. Unfortunately, when it toasted it also removed the second generator. This also happened to a friend with the same engine and battery. So much for redundancy.
Paul |
Oh . . . the windings share a set of pole
pieces . . . yeah . . . so much for
FMEA as well!
