Paul Weismann
Posted: Tue Jul 25, 2006 12:17 pm Post subject: Workbench layout for avionics/electronics? |
Does anyone have good ideas or fundamental principles for building an electronics workbench?
I have heard use carpet on the worksurface, make sure to have outlets obviously, parts bins etc.
Anyone have pics of their favorite layouts?
look forward to seeing what people are using to work on.
PW
_________________ Rotorway JetExec
Baron B58 |
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Jul 25, 2006 2:24 pm Post subject: Workbench layout for avionics/electronics? |
On Jul 25, 2006, at 4:17 PM, Paul Weismann wrote:
<pw(at)weismannassociates.com>
It all depends on what you are doing. One thing I have done in many
of my benches in the past and still like to do is to put a 1' deep
shelf about 18" above the bench. It should slope forward (part
nearest you lower than the back) but have a cleat on the leading edge
to keep stuff from sliding off the shelf onto your work area. This is
where you put your test gear so it doesn't steal any of your work
space and is at eye level.
One other thing I prefer is a workbench that is high enough to use
comfortably when standing. If I want to sit I use a high stool/chair.
It is amazing how much work you will want to do when standing.
A plug strip along the leading edge of your shelf works well as it is
then easy to reach the plugs.
I tend to keep my parts bins away from the bench itself but that is
probably because my shelf space over the bench (within easy reach) is
already taken.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
FLYaDIVE(at)aol.com Guest
Posted: Tue Jul 25, 2006 4:28 pm Post subject: Workbench layout for avionics/electronics? |
In a message dated 7/25/06 4:30:28 PM Eastern Daylight Time,
pw(at)weismannassociates.com writes:
| Quote: | <pw(at)weismannassociates.com>
PW
Paul:
There are a couple of ideas for you:
1 - I prefer a smooth hard top as apposed to a carpet.
2 - I like the top white in color - Makes things easier to find.
3 - Making things easier to find is also why I do not like the carpet. On a
hard top you can hear things that drop.
4 - Electrical outlets are a must and they should be UNDER the table and set
back about 6". Why? So the power cords are out of the way. Away from the
knees and so you do go dragging them across the top.
5 - You will also need a good Filtered, Stable Power Supply, at least 15 to
50 Amps in this case MORE is better. Add up all the current draws from all
your avionics and use that as a reference. Note: If you have two Coms and each
draws 10 amps Max ... Remember you will only be transmitting on ONE Com at a
time. So use the Receive amperage of the higher of the two units when adding up
all the items.
6 - Table Top Edging - Around the edge of the workbench install a RAISED -
ROUND molding, it is known as 3/4 Round. This will make keeping parts on the
table easier and the power cords slide easier.
7 - A shelf the full length of the workbench. This is where you secure the
solder station UP and Away from fingers. Also a good place for other meters
and lights
8 - Lights - Overhead lighting is a must. As well as a GOOSE NECK / BOOM
light. And if you want to go fancy a florescent Ring Light with a Magnifying
lens in the center ... Got BUCK$ ?
9 - Since you are building an electronic workbench I assume you will be doing
some soldering. Get a REAL GOOD solder station. One that has a linear heat
control.
The solder station should have a few requirements:
a> Silicon - Heat resistant cords, both for the power and the pencil. So you
don't burn them.
b> Long Cords - Long enough cords so you can reach either end of the
workbench OR means to move the station from one end to the other.
c> Means of SECURING the solder station so if you pull on the cord the
station does NOT fall on the bench (avionics).
d> A WET sponge - This is a cellulose sponge that is particular to a good
solder station.
e> SILVER PLATED small chisel solder tip. MUST BE PLATED! It will last
forever.
f> Solder 63/37 Eutectic size: 0.063" Get a Pound, it also will last forever.
10 - VICES - Yes, I have a few, but you might want one or two. The vices are
mounted at the ends of the bench so you can hole two connectors and solder
Plug A Pin 1 to Plug B Pin 1 makes it easier in keeping connectors straight
11 - There are also a few tricks using a dowel (COMB BOARD) board to keep
wires straight.
OK, enough, now I'm getting into techniques and all you asked was about a
workbench.
Best of luck,
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Posted: Tue Jul 25, 2006 5:55 pm Post subject: Workbench layout for avionics/electronics? |
Brian Lloyd wrote:
<brian-yak(at)lloyd.com>
already taken.
When I did consumer electronics repair in another life, I found that a
smooth surface (tempered masonite, formica, etc) & a rectangular carpet
sample worked well. I was working on items that weighed between 5 & 100
lbs, & the loose carpet sample made moving the 'patient' around easy
while protecting it from scratches & dents when I needed to roll it over
or stand it on its side. I agree with Brian about test gear location.
Remote parts location minimizes the number of parts you knock off the
bench & lose.
All the above might not be an issue if you're just fabricating small
items, but the slick bench top & loose carpet are a lot easier to clean
than fixed carpet.
Bench height is very much personal preference. My business partner
always worked standing or on a high stool; my brain stops functioning if
I stand in one place for more than 30 seconds.
Oh yeah, a work bench is like the deck behind your house: you always
wish you had built it just a little bigger......
