draftsjust417(at)gmail.co Guest
Posted: Fri Nov 13, 2020 8:44 am Post subject: fuel qty transmitter, R&R... |
Good morning all-
Fishing for some tips & advice, this time on changing the p/n GUR-7I fuel quantity transmitter, out in the main fuel tanks. Specifically, I plan to soon install a new one in my left-hand, standard main tank w/ 2 new gaskets.
Background: troubleshooting all the wiring shows that the inop L/H red "fuel low" light in both cockpits is owing to the transmitter unit; all wiring, bulbs, sockets test healthy happy & continuous.
Has anyone changed out the fuel qty unit, and has tricks & tips to share?
Traps to avoid? Good or bad experiences?
Thanks, no rush-
Justin Drafts
N280NC
Seattle area
threein60
Posted: Fri Nov 13, 2020 9:07 am Post subject: fuel qty transmitter, R&R... |
Easy to do just make sure you recalibrate the new one properly.Larry
Sent from Yahoo Mail for iPhone
On Friday, November 13, 2020, 08:58, Justin Drafts <draftsjust417(at)gmail.com> wrote: Quote: | Good morning all-
Thanks, no rush-
Justin Drafts
N280NC
Seattle area
Posted: Sat Nov 14, 2020 5:33 am Post subject: fuel qty transmitter, R&R... |
Justin,
You may want to consider adding a JPI FS450 Fuel Flow instrument. Not
only does it provide excellent fuel flow information, especially with
airplane that has a mixture control, it also provides total fuel used,
fuel remaining and time to empty. at the current fuel flow. If
connected to your GPS, it will also provide fuel required to next
destination, fuel reserve when you get to your next destination and
miles per gallon (which you'll find most interesting based on your
mixture and power settings).
Here are 3 links which will help you better understand the FS450.
FS450 on JPI web site - https://www.jpinstruments.com/shop/fuel-scan-450/
Pilot Manual -
https://www.jpinstruments.com/wp-content/uploads/2012/08/PG-FS-450-Rev-G.pdf
Installation Manual -
https://www.jpinstruments.com/wp-content/uploads/2012/08/Install-report-400-A-2-19-131.pdf
You would mount the transducer between the fuel pump output and the
carburetor input.
Dennis
A. Dennis Savarese
334-546-8182
www.yak-52.com
Fishing for some tips & advice, this time on changing the p/n *GUR-7I*
2 new gaskets.
Thanks, no rush-
Justin Drafts
N280NC
Seattle area
hess737(at)aol.com Guest
Posted: Sat Nov 14, 2020 5:49 am Post subject: fuel qty transmitter, R&R... |
Shadin also makes an excellent, easy to use unit. I’ve had one in my Chang for 18 years!
Richard Hess
C 404-964-4885
Quote: | On Nov 14, 2020, at 8:35 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
Justin,
You may want to consider adding a JPI FS450 Fuel Flow instrument. Not only does it provide excellent fuel flow information, especially with airplane that has a mixture control, it also provides total fuel used, fuel remaining and time to empty. at the current fuel flow. If connected to your GPS, it will also provide fuel required to next destination, fuel reserve when you get to your next destination and miles per gallon (which you'll find most interesting based on your mixture and power settings).
Pilot Manual - https://www.jpinstruments.com/wp-content/uploads/2012/08/PG-FS-450-Rev-G.pdf
Installation Manual - https://www.jpinstruments.com/wp-content/uploads/2012/08/Install-report-400-A-2-19-131.pdf
You would mount the transducer between the fuel pump output and the carburetor input.
Dennis
A. Dennis Savarese
334-546-8182
www.yak-52.com
> Good morning all-
> Fishing for some tips & advice, this time on changing the p/n *GUR-7I* fuel quantity transmitter, out in the main fuel tanks. Specifically, I plan to soon install a new one in my left-hand, standard main tank w/ 2 new gaskets.
> Thanks, no rush-
> Justin Drafts
> N280NC
> Seattle area
Clouddog
Posted: Sat Nov 14, 2020 5:53 am Post subject: fuel qty transmitter, R&R... |
Excellent advice on addition of a fuel computer. I have installed one on both airplanes I have owned and I believe the unit is perhaps one of the most important pieces of equipment add on's you can have.
Greg "Clouddog " Wrobel
On Sat, Nov 14, 2020, 07:39 A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Justin,
Pilot Manual -
carburetor input.
Dennis
A. Dennis Savarese
334-546-8182
www.yak-52.com
> Good morning all-
> 2 new gaskets.
> Thanks, no rush-
> Justin Drafts
> N280NC
> Seattle area
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
Posted: Sat Nov 14, 2020 11:06 am Post subject: fuel qty transmitter, R&R... |
Excellent info all, esp on the fuel flow transducer...
Budget crunch (at) moment is keeping my CJ stock, but will store that away for future.
Have used F/F instruments in other aircraft, and they can (literally) be lifesavers!
It's nice to have the time to be able to get to back-burner projects...
Thanks- Justin
On Sat, Nov 14, 2020 at 6:28 PM Greg Wrobel <clouddog22(at)gmail.com (clouddog22(at)gmail.com)> wrote:
Quote: | Excellent advice on addition of a fuel computer. I have installed one on both airplanes I have owned and I believe the unit is perhaps one of the most important pieces of equipment add on's you can have.
Justin,
Pilot Manual -
carburetor input.
Dennis
A. Dennis Savarese
334-546-8182
www.yak-52.com
> Good morning all-
> 2 new gaskets.
> Thanks, no rush-
> Justin Drafts
> N280NC
> Seattle area
FORUMS -
WIKI -
b Site -
threein60
Posted: Sat Nov 14, 2020 11:24 am Post subject: fuel qty transmitter, R&R... |
I have a stock float on the shelf.
On Saturday, November 14, 2020, 11:21, Justin Drafts <draftsjust417(at)gmail.com> wrote: Quote: | Excellent info all, esp on the fuel flow transducer...
Thanks- Justin
Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> Justin, You may want to consider adding a JPI FS450 Fuel Flow instrument. Not only does it provide excellent fuel flow information, especially with airplane that has a mixture control, it also provides total fuel used, fuel remaining and time to empty. at the current fuel flow. If connected to your GPS, it will also provide fuel required to next destination, fuel reserve when you get to your next destination and miles per gallon (which you'll find most interesting based on your mixture and power settings). Here are 3 links which will help you better understand the FS450. FS450 on JPI web site - https://www.jpinstruments.com/shop/fuel-scan-450/ Pilot Manual - https://www.jpinstruments.com/wp-content/uploads/2012/08/PG-FS-450-Rev-G.pdf Installation Manual - https://www.jpinstruments.com/wp-content/uploads/2012/08/Install-report-400-A-2-19-131.pdf You would mount the transducer between the fuel pump output and the carburetor input. Dennis A. Dennis Savarese 334-546-8182 www.yak-52.com On 11/13/2020 11:43 AM, Justin Drafts wrote: > Good morning all- > > Fishing for some tips & advice, this time on changing the p/n *GUR-7I* > fuel quantity transmitter, out in the main fuel tanks. Specifically, I > plan to soon install a new one in my left-hand, standard main tank w/ > 2 new gaskets. > > Background: troubleshooting all the wiring shows that the inop L/H red > "fuel low" light in both cockpits is owing to the transmitter unit; > all wiring, bulbs, sockets test healthy happy & continuous. > > Has anyone changed out the fuel qty unit, and has tricks & tips to share? > Traps to avoid? Good or bad experiences? > > Thanks, no rush- > > Justin Drafts > N280NC > Seattle area =========== List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List =========== FORUMS - eferrer noreferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer noreferrer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution =========== |
cjpilot710(at)aol.com Guest
Posted: Sat Nov 14, 2020 5:53 pm Post subject: fuel qty transmitter, R&R... |
I still have the fuel tanks and the transmitters from when I changed out to bigger tanks. They were working fine when I put them on the shelf some 10 years ago if you're interested. I sell them both for $25.00 + shipping. Jim "Pappy" Goolsby
