rparigoris
Posted: Fri Apr 23, 2021 9:21 am Post subject: Populated Instrument Module weight |
Hi Group
Curiosity question: Whats the weight of your Populated Instrument Module, and what do you have in it?
I know some have went on a weight reduction mission, before and after results would be of interest.
Thx. Ron P.
n7188u
Posted: Fri Apr 23, 2021 11:53 am Post subject: Re: Populated Instrument Module weight |
Ron,
When I pull my panel off for transponder install in the next couple of weeks I will let you know what mine is. I have a bunch of old school stuff so doubt it will be very light but who knows (or that it would be appealing to many pilots out there). The transponder I'm sure will add a lot percentage wise.
Duncan McFadyean
Posted: Fri Apr 23, 2021 12:27 pm Post subject: Populated Instrument Module weight |
20lbs with txpndr and radio. No horizon, no DI. Analogue.
Duncan McF.
| Quote: | On 23 April 2021 at 18:21 rparigoris <rparigor(at)hotmail.com> wrote:
Hi Group
Thx. Ron P.
http://forums.matronics.com/viewtopic.php?p=501480#501480
jeffwill55(at)sbcglobal.n Guest
Posted: Sat Apr 24, 2021 10:56 am Post subject: Populated Instrument Module weight |
Well, rparigor(at)hotmail.com (rparigor(at)hotmail.com), my instrument panel weighs 15 pounds. This is what is on and in it.
MGL Avionics “Voyager” Electronic Flight Instrument System (EFIS)
MGL Avionics “V6" Comm Radio”
Mode S - uAvonix Echo ESX UAT transceiver/Mode S transponder with ADS-B in/out
Magnetic Compass
Pitch Trim Indicator and rocker switch
Flap switch
Rheostat for panel lights
Cabin Light switch
ELT indicator light and reset button
Separate 30A Alternator Breaker (Tyco Electronics W31-X2M1G-30)
Standard Power Panel, Composite Design Inc.(Wayne Lanza), which has eight switches, including a Cessna type split master switch, and 18 circuit breakers.Plug-in jacks for pilot and passenger headphones
Plug-in jack for auxiliary audio
Two warning /caution lights (for battery and EFIS)
Various placards, as required
Panel wiring and associated D-sub connectors.
Jeff Williams
