email(at)jaredyates.com Guest
Posted: Mon Dec 27, 2021 6:07 pm Post subject: Z101b NTE53016 Equivalent, also Switches, Relay Alternatives |
I'm in the process of going through the electrical architecture on an already-flying airplane and need to do some shopping.
Z101b specifies the diode bridge NTE53016 which is available from Digikey. But I'm placing an order from Mouser, and was wondering if this might be a suitable equivalent?https://www.mouser.com/datasheet/2/80/KBPC10005_G_Thru911241__KBPC5010_G_Series_RevB-2506443.pdf
or maybe this one, which is half the cost:
https://www.mouser.com/datasheet/2/169/kbpc3506t-2451205.pdf
Also, I'm needing some switches and B&C is closed until next week, has anyone found good alternative suppliers for the S700 switches or the S704-1 Relay?
For switches, the most likely candidates I can find are the Carling Series F for the single pole and Carling Series G for the double pole. It looks like I'll need two s700-2-10 which B&C calls on-on-on but Carling doesn't use the same terminology in their data sheet for the G series:
https://www.carlingtech.com/sites/default/files/documents/G-SeriesSW_Details_%26_COS.pdf
Which makes me wonder if I'm barking up the wrong tree with the G series.
Although, it looks like their 6GM5B-78 will work for the s700-2-5, which I plan to use for magnetos and starter as per z-figures note 2.
For the S704-1 relay, I haven't found the same one yet, but I wonder if something like this would work?
https://www3.panasonic.biz/ac/e_download/control/relay/vehicle/catalog/mech_eng_cb.pdf
user9253
Joined: 28 Mar 2008 Posts: 1948 Location: Riley TWP Michigan
Posted: Mon Dec 27, 2021 7:22 pm Post subject: Re: Z101b NTE53016 Equivalent, also Switches, Relay Alternat |
A Schottky diode such as DSS2X61-0045A has less voltage drop.
They are out of stock at most major suppliers. But some are available on eBay for less money.
Mouser has 747-DSS2X121-0045B in stock.
_________________ Joe Gores |
