dlm34077(at)gmail.com Guest
Posted: Sat Jun 25, 2022 6:20 pm Post subject: Trutrak Digiflite II flat pack |
My AP has been in my aircraft since 2008 with only an aileron servo overhaul. A problem has developed with the screen backlighting. Sometimes it works and sometimes it does not; I finally determined that the screen seems to be loose in the box. A slight pressure on the left side of the screen makes the backlighting work normally and the display is readable in the daylight. There seems to be a loose connection in the screen to the unit. I found that King is now maintaining TT APs. Has anyone else had this problem? How did you get it fixed? locally or otherwise and how much does it cost?
Posted: Sat Jun 25, 2022 7:04 pm Post subject: Trutrak Digiflite II flat pack |
Mid Continent Instruments is the service center for the TruTrak auto pilots. I’d give them a call and verify they can service that unit. Either way, out of warranty, I would open it up and see if there is a loose plug you can snap into place.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
