johnbright
![](images/avatars/18595951815d6c210ade625.jpg)
Joined: 14 Dec 2011 Posts: 165 Location: Newport News, VA
Posted: Thu Aug 25, 2022 6:57 pm Post subject: flyback diode across fuel pump |
Someone on VAF suggested putting a flyback suppression diode across fuel pump leads like we do with contactor and relay solenoid coils. This was re an automotive fuel pump like SDS/EFII/Airflow Performance/Walbro gerotor GSL series.
What say Bob et Al?
_________________ John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links
Joined: 28 Mar 2008 Posts: 1919 Location: Riley TWP Michigan
Posted: Fri Aug 26, 2022 7:17 am Post subject: Re: flyback diode across fuel pump |
A diode won't hurt anything as long as the banded end is connected to positive.
Van's RV-12 schematic shows an optional 22,000 microfarad capacitor across the fuel pump.
_________________ Joe Gores |
bob.verwey(at)gmail.com Guest
Posted: Sat Aug 27, 2022 12:43 am Post subject: flyback diode across fuel pump |
Why the cap Joe and not just a diode?
On 26 Aug 2022 17:20, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote: Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=507781#507781
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
Posted: Sat Aug 27, 2022 5:03 am Post subject: Re: flyback diode across fuel pump |
Quote: | Why the cap Joe and not just a diode? |
I don't know. Perhaps a capacitor helps to reduces interference to the aircraft electrical system. Maybe Bob N will reply.
yellowduckduo(at)gmail.co Guest
Posted: Sat Aug 27, 2022 5:18 am Post subject: flyback diode across fuel pump |
My thoughts are that a diode with a finite voltage drop does nothing for
quieting noise from the pump that is less than that finite voltage drop
(usually 0.6 volt for silicon diode). Comutated motors put some hash on
the supply line. I'm not aware of it typically causing problems but a
capacitor should help quiet such noise somewhat.
Ken
alec(at)alecmyers.com Guest
Posted: Sat Aug 27, 2022 5:19 am Post subject: flyback diode across fuel pump |
Used to be capacitors were cheaper than diodes, I think.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=507793#507793
Ceengland
Posted: Sat Aug 27, 2022 5:39 am Post subject: flyback diode across fuel pump |
Diodes used as arc suppressors are pennies each. They 'bleed off' the large voltage spikes that happen when contacts open and load is suddenly removed from a circuit.
Capacitors wired as power supply 'filters' typically exist to smooth variations in DC levels. They store energy during low demand, and give it up when demand causes voltage to sag below their charge state. Those variations can come from the 'ripple' in rectified AC supply voltage, or from variations in DC loads. The obvious example of (huge) variation in load would be the starter, causing 'brownouts' of electronic devices, other examples are inrush current to incandescent lamps, DC motors, or for a more repetitive example, a Facet pulse pump (though I wouldn't have expected the draw of a Facet pump to have a significant effect on DC bus stability).
On Sat, Aug 27, 2022 at 8:22 AM Alec <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
Quote: | --> AeroElectric-List message posted by: Alec <alec(at)alecmyers.com (alec(at)alecmyers.com)>
> On Aug 27, 2022, at 09:04, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
> Joe Gores
="noreferrer" target="_blank">https://matronics.com/contribution
_________________ Charlie |
Posted: Sat Aug 27, 2022 6:23 am Post subject: flyback diode across fuel pump |
On Aug 27, 2022, at 9:38 AM, Charlie England <ceengland7(at)gmail.com> wrote:
Quote: | Diodes used as arc suppressors are pennies each.
They are, now.
Ceengland
Posted: Sat Aug 27, 2022 7:23 am Post subject: flyback diode across fuel pump |
They are, now.
How far back do you want to go? I ran a computer repair business in the
1970s/80s/90s, and they were pennies each back then. Electrolytic caps
big enough to work as legit power supply filters were a lot more
expensive back then, too.
www.avast.com
Posted: Sat Aug 27, 2022 10:40 am Post subject: flyback diode across fuel pump |
At 09:57 PM 8/25/2022, you wrote:
Quote: | --> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
Someone on VAF suggested putting a flyback suppression diode across fuel pump leads like we do with contactor and relay solenoid coils. This was re an automotive fuel pump like SDS/EFII/Airflow Performance/Walbro.
What say Bob et Al? |
Did the author cite a noise problem which was
mitigated by adding this component?
I'm mystified by any assertion of added value.
Rotary pumps powered by pm motors have no
'flyback' event. PutPut pumps like the
Facet devices have electronically driven
solenoids that 'cock' a compression spring.
A cruise through the genealogy of exemplar
patents for such pumps . . .
https://tinyurl.com/2e6mmzyr
. . . illustrates commonly applied
technology for mitigating flyback
energies in these devices that include
resistors, diodes and capacitors as
part of the designs dating back over
30 years.
I'm curious as to the history of
the thread.
out of that stuff?"
johnbright
Posted: Sun Aug 28, 2022 5:32 pm Post subject: Re: flyback diode across fuel pump |
nuckolls.bob(at)aeroelect wrote: | At 09:57 PM 8/25/2022, you wrote:
Quote: | --> AeroElectric-List message posted by: "johnbright" <john_s_bright>
30 years.
the thread.
out of that stuff?" |
Hi Bob,
The VAF thread started as “local ground or forest of tabs for fuel pump ground?”, EFI fuel pump, and drifted at post 9 to someone recommending a diode across the pump motor to protect the pump switch. I had never heard of this so I asked here on AEL.
https://vansairforce.net/community/showpost.php?p=1629894&postcount=9
N1921R links |
Posted: Mon Aug 29, 2022 11:46 am Post subject: flyback diode across fuel pump |
John Bright, RV-6A, at FWF, O-360 |
Good show
out of that stuff?"
Ceengland
Posted: Fri Sep 02, 2022 12:19 pm Post subject: flyback diode across fuel pump |
It *could* short, and if it does, it has at least some chance of opening
the circuit protection for the fuel pump wire, before it burns itself open.
Depending on installation techniques, it could conceivably add failure
points to the supply path to the pump.
It'll be very confusing to the guy who has to work on it at some point
(that confused guy could even be you).
If it has no valid upside, it violates the aviation principle that if
you throw it up and it comes down, don't install it.
On 9/2/2022 2:44 PM, Jeffrey Cohen wrote:
Quote: |
is there any downside to installing this diode across the fuel pumps? for example, can a diode short closed and prevent the pumps from operating? Is this a possible failure mode of diodes?
Jeff
> Sent: Sunday, August 28, 2022 at 9:32 PM
> From: "johnbright" <john_s_bright(at)yahoo.com>
> To: aeroelectric-list(at)matronics.com
> Subject: Re: flyback diode across fuel pump
>>> What say Bob et Al?
>> https://tinyurl.com/2e6mmzyr (https://tinyurl.com/2e6mmzyr)
>> 30 years.
>> the thread.
>> Bob . . .
>> Un impeachable logic: George Carlin asked, "If black boxes
>> survive crashes, why don't they make the whole airplane
>> out of that stuff?"
> Hi Bob,
> The VAF thread started as âlocal ground or forest of tabs for fuel pump ground?â, EFI fuel pump, and drifted at post 9 to someone recommending a diode across the pump motor to protect the pump switch. I had never heard of this so I asked here on AEL.
> john_s_bright(at)yahoo.com, Newport News, Va
> https://drive.google.com/folderview?id=1u6GeZo6pmBWsKykLNVQMvu4o1VEVyP4K
www.avast.com
Posted: Fri Sep 02, 2022 10:07 pm Post subject: flyback diode across fuel pump |
At 02:44 PM 9/2/2022, you wrote:
Quote: | --> AeroElectric-List message posted by: Jeffrey Cohen <jcohen(at)post.com>
Jeff |
Diodes are the oldest and most reliable solid state
devices in service. Risk of failure is exceedingly
small. Operational benefit is on the same order as
a paint stripe down the side of your fuselage or installing
white sidewall tires.
out of that stuff?"
