JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sun Feb 26, 2023 4:09 pm Post subject: CKT silencer crack |
This damage looks difficult to repair by welding. The "collar" into which the exhaust header tube is held with springs, has broken the weld most of the way around where it attaches to the silencer box. There are other broken small welds where the other header tubes get inserted.
Throughout the 300 hours total in the air since the silencer was first installed, the carburettors have been kept electronically balanced and the Airmaster propeller is also well balanced. The silencer was suspended with utmost care to avoid strains as the flange nuts got tightened, making sure to tighten the telescopic joint in #1 header tube last.
I'll probably have to replace the whole exhaust system. This topic is just FYI.
 Download |
| Filename: |
CKT silencer crack..doc |
434 KB |
| Downloaded: |
422 Time(s) |
fireflier
Posted: Sun Feb 26, 2023 11:43 pm Post subject: CKT silencer crack |
Morning Jonathan
Hope your keeping well?
I had a very similar failure with my silencer at around the same number of hrs on my aircraft, new silencer was indeed required.
I have just had the number 3 cylinder down pipe fail on friday afternoon whilst flying. The Number 2 down pipe had no more than 30hrs on it before the failure
Hope you can get things fixed soon.
Kind regard's
Donald
Donald
| Quote: | On 27 Feb 2023, at 00:10, JonathanMilbank <jdmilbank(at)yahoo.co.uk> wrote:
http://forums.matronics.com/viewtopic.php?p=510288#510288
http://forums.matronics.com//files/ckt_silencer_crack_189.doc
_________________ Fireflier |
