Trim damper assembly
tonyvaccarella
PostPosted: Sat Mar 11, 2023 3:01 am    Post subject: Trim damper assembly Reply with quote
Hi everyone,
Im wondering if anyone else has encountered this problem with the trim damper assembly as I have.
From Page 19-2 - Figure 2, the TS04A bolt is placed through the support bracket - however, when I installed the Nyloc Nut M10 and putting in safety (only by about 1 thread). The spring is fully compressed and causes binding with operating the electric trim.
I can't see an easy way out of this and I have been thinking of removing the spring and cutting one or two spirals of the spring.
Can anyone kindly offer some wisdom on this?
Many thanks
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
Burrilla
PostPosted: Sat Mar 11, 2023 3:26 am    Post subject: Trim damper assembly Reply with quote
Not had a problem.
Whenever I’ve come across something that’s doesn’t seem to work I always go back to the manual to check I have the right items and assembled them correctly.
For example the thickness washer placed under the head of a bolt instead of the nut meant the shoulder of the bolt did not go all the way through a control rod end resulting in too much play in the control. Corrected and all works fine.
Alan
On 11 Mar 2023, at 11:04, tonyvaccarella <tony(at)weimagine.com.au> wrote:
Hi everyone,
Many thanks
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=510382#510382
