fasilpereira
Posted: Mon May 08, 2023 9:04 am Post subject: VOR/LOC/GS antenna question |
I'm installing a GNS-430W on my composite aircraft. I already have 2 VOR antennas that are currently not in use because I didn't had any NAV radio installed.
I just realized that the GNS-430W requires an input for both VOR/LOC and GS. The common solution for this is to install a Diplexer on a NAV antenna to break the signal 2 outputs, one output for VOR/LOC and other for GS. I have seen that some users reports a loss in VOR range due to the diplexer and I'm worried about it because the VORs are far from each other here where I live.
I'm considering to plug one antenna to the VOR/LOC input of the GNS and the other to the GS. I'm not sure if I'll need to add a diplexer to the GS cable and if I do, can I leave the VOR connector of the diplexer open? Additionally, if a diplexer is necessary, is there any DIY that could be used, instead of the $150-$200 ones?
Thank you,
Fabricio
_________________ Fabricio Pereira
Engineer / Pilot |
Posted: Wed May 10, 2023 7:09 am Post subject: VOR/LOC/GS antenna question |
At 12:04 PM 5/8/2023, you wrote:
Quote: | --> AeroElectric-List message posted by: "fasilpereira" <fasilpereira(at)yahoo.com>
I just realized that the GNS-430W requires an input for both VOR/LOC and GS. The common solution for this is to install a Diplexer on a NAV antenna to break the signal 2 outputs, one output for VOR/LOC and other for GS. I have seen that some users reports a loss in VOR range due to the diplexer and I'm worried about it because the VORs are far from each other here where I live. |
Yes, 'diplexers' are a signal splitting network
that routes energies from a common antenna to two
or more receivers. A well crafted VOR-LOC/GS splitter
should not seriously affect the performace of either
system. Advertised losses through such devices
are generally on the order of 1.0 dB or less.
https://tinyurl.com/2uams5xp
On the other hand, there are VOR-LOC power
'dividers' that optimize the function of TWO
VHF receivers on a single antenna. Of necessity,
these devices route 1/2 of the power from the
antenna to each receiver. Hence, a 3+ dB loss
of signal to each receiver.
Quote: | I'm considering to plug one antenna to the VOR/LOC input of the GNS and
GS cable and if I do, can I leave the VOR connector of the diplexer open? |
Don't need one. The 'barefoot' VOR/LOC
antenna is quite efficient when operated
at the third harmonic of it's fundamental
design frequency 108-118 MHz. GS signals
cover range of 329-335 MHz.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
fasilpereira
Posted: Wed May 10, 2023 9:45 am Post subject: Re: VOR/LOC/GS antenna question |
Bob,
So I understood that I can connect the spare VOR/LOC antenna that I have direct to the GS BNC in the back of the GNS and that will work just fine, with no need of any additional device between. Is that correct? I thought a 1 pF capactitor could be required, but I was not sure....
Thanks again,
Fabricio
Engineer / Pilot |
wsimpso1
Posted: Thu May 11, 2023 10:28 am Post subject: Re: VOR/LOC/GS antenna question |
The expensive commercial splitters and decouplers are one option. The other is building them from Jim Weir's Attenna Reference Text. It is available on this page of his website.at:
http://www.rstengineering.com/rst/products/plasticplaneantenna/plasticplaneantenna.htm
The highlighted Antenna Reference Text has a whole bunch of guidance on the topic and is downloadable as a .pdf file. Page 34 shows both his NAV splitter applying one NAV antenna to two VOR recievers, it also shows the GS splitter to get a GS off that one NAV antenna. Yeah, you have to roll up a couple 16" cables into a little box and stash it someplace, but it is way cheaper than the commercial gadget.
Have fun.
