mike(at)vision499.com Guest
Posted: Thu May 11, 2023 6:50 am Post subject: Z1 Question |
I have mostly used Z1 with the B&C Alternator controller. I have the “BUS” wire connected to terminal 6 protected with a 5 amp breaker on the panel as illustrated.
I am now preparing the POH and would like to know under what scenarios I would want to “PULL” the breaker.
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)
Mike cell: +1 250-885-0554
1-1100 Tulip Ave, Victoria, BC, V8Z 0A2
Peter(at)sportingaero.com Guest
Posted: Fri May 12, 2023 2:24 am Post subject: Z1 Question |
I would suggest none while you are flying.
If you need to turn off the electrics you would use the master switch.
During maintenance to depower the alternator field.
Peter
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of mike(at)vision499.com
Sent: Thursday, May 11, 2023 3:48 PM
Subject: Z1 Question
Mike Pienaar
mikepienaar09(at)gmail.co Guest
Posted: Fri May 12, 2023 8:51 am Post subject: Z1 Question |
Thank you very much, why would I want to depower the alternator field?
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Peter Pengilly
Sent: May 12, 2023 3:24 AM
Subject: RE: Z1 Question
Peter
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of mike(at)vision499.com (mike(at)vision499.com)
Mike Pienaar
email(at)jaredyates.com Guest
Posted: Fri May 12, 2023 9:37 am Post subject: Z1 Question |
It will run down your battery and make the alternator very warm during extended master-on/engine-off situations.
On Fri, May 12, 2023 at 12:55 PM <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
endspeed(at)yahoo.com Guest
Posted: Fri May 12, 2023 9:43 am Post subject: Z1 Question |
Mike, If you had an external power transient (lightning strike) it is possible that in order to regain alternator output, you might have to reset the alternator field breaker.
| Quote: | On May 12, 2023, at 13:00, mikepienaar09(at)gmail.com wrote:
(at)font-face { font-family: Helvetica; } (at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: "Comic Sans MS"; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: rgb(5, 99, 193); text-decoration: underline; } span.EmailStyle20 { font-family: Calibri, sans-serif; color: windowtext; } .MsoChpDefault { font-size: 10pt; } (at)page WordSection1 { size: 612pt 792pt; margin: 72pt; } div.WordSection1 { page: WordSection1; } <![endif]--> <![endif]-->
Peter
Mike Pienaar
Posted: Fri May 12, 2023 11:19 am Post subject: Z1 Question |
Thanks very muchThat is what I was looking for
Keep well
On Fri., May 12, 2023, 10:40 a.m. Jared Yates, <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
| Quote: | It will run down your battery and make the alternator very warm during extended master-on/engine-off situations.
