marcussab(at)gmail.com Guest
Posted: Thu Nov 30, 2023 12:58 am Post subject: ARINC-429 questions |
Hi,
I'm trying to get a handle on wiring my EFIS and incorporating GPS and the use of ARINC-429 modules in my experimental aircraft.
Are ARINC modules interchangeable, as long as you know the pinouts, or are they specific to each manufacturer? I know that If you are running a serial rs232 output to the ARINC module, it converts that signal to the ARINC protocol and that will then work with ARINC compatible avionics. Is rs232 data also standardized? For instance, Is GRT rs232 altitude data the same format as Dynon rs232 data and therefore, any ARINC module could be used? Or does each maker produce and program custom Modules to convert their data?
Cheers.
Marcus Sabathil
